Old 11-08-2013, 03:29 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
Originally Posted by jferzacca95 View Post
Do you have double pane glass or single pane glass in the windows? I have a '98 750IL and want to start replacing the glass because of lamination problems. How about your washer pumps, are they operational and what type of electrical connector is it? Please send pictures of it. Thanks!
Single pan windows. What washer pumps are you referring to, windshield or headlights? I am not familiar with the setup for headlight washers but I know this car has, or had, the nozzles for it.
Old 11-08-2013, 03:37 PM
Originally Posted by BigRed87 View Post
i am interested in the lcm and the module from the driver seat are they still good and do you know if they would work in a 97 740i? and how much do you want for them?
Any LCM will work from 09/95 forward so yes, it would be the same. The facelift models have the LCM III that allows you do code things our LCM won't if you are going to upgrade your headlights and such. LCM usually requires coding and it also stores the VIN and mileage and not sure the mileage can be changed.
Drivers seat module should be the same unless you have sport seats. The drivers seat moves as it should I believe but will put it on the list to check this weekend.
Cats would be costly to ship. Add that to the generous amount I can get for them here and I doubt it would be worth your while. The Magnaflows are cheap online. I live in a non-smog state so I put 94105's on mine. Think I paid $80 shipped for each.
HTML code is Off
