Old 10-30-2013, 12:28 PM
Übel ein Übel ein is offline
Mein Auto: 2008 550i
banglenot,
My first time seeing this posting and this is an amazing assemblage of information. Thank you. Reading the section on the ZF trans would be incentive alone for an after-market warranty. I'm not sure what experience others may have had, but does anyone have a recommended company to go with? Experiences or issues in particular?
My '08 550i was purchased in 2011 with an extended warranty and so far it's paid for itself. Cost about $3500 and covered well over $5000 in repairs. Oh, yeah, the Run Flats are also under warranty.
- 1999 BMW 328iC - black on black - hot buns & topless - 'M3' sport package
- 2008 BMW 550i - carbon black metallic and it's got a lot of **** on it
Old 10-30-2013, 12:34 PM
Scheiß, I just realized my sig tag is way out of date.
Old 10-30-2013, 01:50 PM
ramses718 ramses718 is offline
Mein Auto: 2010 535i Xdrive
Oh I didn't get that done at the dealer. I wouldn't have been able to get those pics let alone walk out with my pants on. I had my indy do it for me. They wanted almost 1600+ and they were supposedly cutting me a deal. The new valve cover comes with a new gasket and all the required bolts
Old 11-02-2013, 01:41 PM
NOTORIOUSe60 NOTORIOUSe60 is offline
Mein Auto: 2012 X5 5.0i Sport
Bangle, very nice. Let me get in on some info for the 550i LCI section...
2012 LCI X5 5.0i Sport - Black Sapphire Metallic
Shadowline trim, Nav, 8-speed Steptronic/flappy paddles, 20" Style 336 wheels, Premium Sound, Comfort Access, HUD, 20-way Seats, PDC, Rearview/Top View Cameras, Cold Weather Package, Active Steering, Panoramic Roof, ARS, Adaptive Drive, Tech Sport & Comfort Packages, Climate Controlled Seats, Rear Entertainment, etc. etc.
R.I.P.
2008 e60 550i sport - carbon black mettalic
Old 11-02-2013, 04:07 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Originally Posted by Übel ein View Post
banglenot,
I have seen route66 mentioned a lot on here--lots of good things. Seems they pay when they're supposed to and aren't a pain to deal with
Old 11-02-2013, 04:30 PM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
Many thanks. Will include as soon as it comes in.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
Old 11-02-2013, 04:31 PM
So You Just Bought an E60...
I personally have Fidelity Platinum (an exclusionary plan) which has at or more coverage than BMW extended warranty/CPO. One of the few exclusionary plans (rather that inclusionary plans that don't cover what you need them to cover).
Definitely worth checking out.
R.I.P.
Old 11-03-2013, 03:20 PM
Hypnos Hypnos is offline
Mein Auto: 2007 530i
Bangle,
Thanks for including the sunroof drainage issue in the document. However, I would add the following fact: the rear sunroof drain tubes are capped with rubber flapper valves, exacerbating the clogging problem, and that these can be removed without discernible harm.
Old 11-03-2013, 04:59 PM
njlou njlou is offline
Mein Auto: corvette/528xi
Thanks for the great information.
Is there any adjustment to mileage intervals based on severity of use?
Old 11-03-2013, 07:51 PM
banglenot's Avatar
Mein Auto: 2007 530
None documented as such. Just that all the intervals imply normal/typical use of a sedan with an engine that is built to cruise at 130 mph all day. If you beat on it, change stuff faster...
Oh, yes; If you use it for short trips, or use it once a week or so, that's also hard on the car. Change the oil more often. Also, need to take it out and get the engine nice and hot at higher revs once in awhile. That's done by cruising at 60-70 in third gear for 10 minutes, to get it to 5K rpm for awhile.
Originally Posted by Hypnos View Post
Bangle,
Thanks!. I'll be more specific next edition.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 11-11-2013, 02:10 PM
ghs235 ghs235 is offline
Desi
Mein Auto: 07 550i SMG, 09 MB ML550
I have a 550i with SMG transmission. Is there any information related to the SMG tranny that should go into this article? Though the SMG owners are in the minority, I'm sure they would appreciate it.
Old 11-12-2013, 02:02 PM
banglenot's Avatar
Mein Auto: 2007 530
Well, I know the N52 and pretty much everything about the 525-530 and some of the 535. Also can cover the universal stuff. But I'm very weak on the 545-550, and the specialized stuff like the SMG. I try to steer clear of things I haven't done myself, though I'll add what's been done so well by others (like schpenxel's work on the ZF actuators) that I can put it in the doc with some credibility.
I'd welcome a paragraph or two on the subject, and I'm glad to give full credit for added items.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 11-12-2013, 02:07 PM
DIY'er
You can mention that every 50K you might as well plan on replacing the SMG pump.. I believe it's about a $4K job.
Old 11-12-2013, 02:34 PM
banglenot's Avatar
Mein Auto: 2007 530
Damn! Nothing like the little things adding up.... Any further details, like DIY possibilities/methods/vids and symptoms of failure?
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 11-12-2013, 04:42 PM
Wreckless Wreckless is offline
Mein Auto: 528ix
Re: So You Just Bought an E60...
Don't mind me, just subscribing.
Old 11-12-2013, 10:26 PM
H F H F is offline
Mein Auto: 2005 545i
I would like to add to the sun roof drains.. There is two more drains that need to be mentioned. They are under the cabin filters and drain out behind the front wheels they also clog and cause problems. A total of six drains three per side, and also the relocation of the modules in the spare tire on earlier models is worth mentioning..
Old 11-13-2013, 06:18 AM
banglenot's Avatar
Mein Auto: 2007 530
I'll add it in the next rev. Thanks!
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 11-20-2013, 08:24 PM
TX550 TX550 is online now
Do you all have any pictures of the sunroof drains?
Old 11-20-2013, 08:29 PM
Check out this thread: http://www.bimmerfest.com/forums/sho...hlight=sunroof
Old 11-20-2013, 08:57 PM
Perfect. Thanks
Old 11-23-2013, 12:23 AM
tonyb.ca tonyb.ca is offline
Mein Auto: Voiture du jour
Thanks for the amazing info!
Now if I only knew what all the codes mean. Old school mechanic's son working in computers and this stuff still bugs me! At 40K, it's good to know that I still have lots of KM before the fun starts, so I can still pour cash at the 3's in the inventory. The ZF section makes me glad I have a 6 speed.
Any word on the X-drive? It's the one thing my "Indy" frowned at.
Old 11-23-2013, 04:04 AM
banglenot's Avatar
Mein Auto: 2007 530
Not many complaints I've seen about X-drive. Just suggest that (as always) there is no lifetime fill, so replacing the transfer case fluid when the differential is done is probably a good idea. Fluids are cheap; worn mechanicals are expensive.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
Old 11-24-2013, 07:47 AM
ESICKTY ESICKTY is offline
Mein Auto: honda
Great read!! Big help!! Thanks so much!!
KISS FRENCH DRESS ITALIAN DRIVE GERMAN
Old 11-24-2013, 08:50 PM
Just an off-topic comment/question: (apologies)
Wish this existed for e46's. If it does, and you know a place I can download a similar PDF, please do share! As I said earlier, this is an amazingly useful document!
Old 11-24-2013, 10:23 PM
jeanrvictor's Avatar
jeanrvictor jeanrvictor is offline
Mein Auto: 2008 BMW 550I Sport
So You Just Bought an E60 (V1.6)....
Thanks for sharing this. Very informative write up. I have already begun changing the fluids out of my 550 because the term "lifetime fluids" just didn't sit right with me. I'm at 58K miles now & I've changed the trans fluid & pan, relocated the electronics & cleaned the sunroof drains, doing the coolant this week. I'll make preparations for the other items soon. I plan on keeping my car for as long as I can.
2008 BMW 550I Sport
Dinan Stage 1
FLRSBM1
PedalBox 3rd Generation
Wincos 45
