Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 10-26-2013, 06:07 AM
luthier82435 luthier82435 is offline
Mein Auto: volvo
fuel pump relay
Hello everyone
Have a 1980 320i just bought starter drags when fuel is being pumped to motor. Determined this because when no power to fuel pump the starter cranks over very well. Car ran good on 4 test drives. Drive it home and it don't like its new garage. Seemed to blown the relay so I waited all week for the new one ( car started with jumper installed) put in new one nothing. no power to fuel pump. When install jumper some times works sometimes not. (hear fuel pump running). The oddness is when fuel gets to injectors the starter drags but it starts. I feel its the fuel pump but don't understand why. Thanks for any help in advance.
Old 10-26-2013, 03:40 PM
Hermes's Avatar
Hermes Hermes is offline
ZHP Caporegime
Mein Auto: ist Imolarot
fuel pump relay
How old is the battery
2005 330Ci (ZHP) = Daily Driver 1969 2002 = Project Car
BMW Car Club of America # 427612
Old 10-26-2013, 05:07 PM
Mein Auto: volvo
new battery. With jumper in fuel pump relay starter drags sometimes won;t even turn over Remove jumper and it whirls over easily and if you stand on the throttle it will eventually start I am confused.
Old 11-13-2013, 03:27 PM
BMWFatherFigure's Avatar
Old School
Wierd earth or termination problem. Carefully check battery cables and terminals (both ends). Could be corrosion in the wires/cables.
Current:
E38 Parts Car
Previous:
Old 11-13-2013, 09:45 PM
Mein Auto: volvo
fuel pump relay
Thanks for the input since I posted found out my fuel distributor is not functioning. Causing all the problems.
