New Issue - Bimmerfest - BMW Forums
Old 10-26-2013, 06:21 AM
Fletch335i Fletch335i is offline
Mein Auto: 2009 335i xdrive
New Issue
Today on the highway, my 335i just gradually stopped accelerating. Had to get it towed to the dealer. I just bought it in March of this yr. 75000km. 2009. Has Dinan Stage 1. Is this a HPFP issue? Will my BMW certified series cover this or will Dinan cover this? Thanks
Sent from my SGH-I337M using BimmerApp mobile app
Old 10-26-2013, 09:21 AM
Leekay07 Leekay07 is offline
Mein Auto: MY12 550I,MY09 X5.
Dinan assume all warranty responsibility of any part that fails because of or in direct relation to a Dinan mod. Up to 50,000 miles or 4 years from in service date.
If you like customer service. Don't look beyond a BMW.
Old 10-26-2013, 09:40 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Prob not HPFP. Why would you think so? No trouble shooting done....could be anything.
Code readout from BMW capable OBDII reader, please. There are but two Generally Recognized As Safe:
1
2
Old 10-26-2013, 09:42 AM
Also, without knowing what's failed, we can't possibly know if BMW warranty, or Dinan's, applies. Or if it's a non-warranty issue.
Old 10-26-2013, 09:52 AM
Re: New Issue
OK. It doesn't look like they'll get any troubleshooting done until Monday. I only figure it was the HPFP because the engine cut out like it was out fuel. And I know the HPFP is known to be troublesome.
Thanks for the replies. I'll update on what the problem is when BMW finds it.
Old 10-26-2013, 01:28 PM
Miller335 Miller335 is offline
Mein Auto: 2007 E92
What recalls have been done to your car?
Wondering if you have the newer pump or not.
Old 10-27-2013, 12:13 PM
danmac86 danmac86 is offline
Mein Auto: 318i 2008
Re: New Issue
What is the triangle and the numbers next to my mileage??????help please
Sent from my HTC One using BimmerApp mobile app
Old 10-27-2013, 01:23 PM
You got-um code....need THIS
Old 10-27-2013, 06:37 PM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
Your car is certified?? They usually wont certify a tuned car. Dinan certifies motor for the 4 year/50,000 miles. Not after that.
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 10-28-2013, 02:21 PM
Re: New Issue
So news is...I need a new water pump and thermostat. The water pump is under warranty but the thermostat isn't. Also getting an oil change and a coolant flush. Total damage is $900 which sounds steep to me.
Old 10-28-2013, 02:52 PM
335IoTwnTrbos's Avatar
335IoTwnTrbos 335IoTwnTrbos is offline
Official 'Fest GIF Guy
Mein Auto: 2008 E92 335i
You're lucky! When my water pump failed, my car showed me the low coolant warning and then immediately the no coolant warning as I was on my way home from work on the I-15S. I though my car was gonna blow up. Ended up being $1300 for me.
"When you can't run, you crawl... and when you can't do that, you find someone to carry you."
|100,000mile Club (E92)2008 335i SGM "Io"- Cobb Tuned |6AT|Premium|Sport|
|AE Performance CBE|AR Design DPs|CF GTR Vented Hood|Cobb AP V2|SP Lowering Perches (F)|M3 FCAs|VRSF 5" FMIC|
|BMS DCI|Niche Targa M129 18x8/18x9.5|BMS Spacers 10mm/15mm|BP Drilled/Slotted Rotors|BP Ceramic Pads|
|Forge DVs|CP-e Upper CP|VRSF Lower CP|BMS Cowl Delete|MR Front Strut Bar|BMS OCC|Custom CA License Plate|
