Old 10-26-2013, 01:16 PM
MasterYoda's Avatar
MasterYoda MasterYoda is offline
Mein Auto: '16 F82 M4
Stock vs. aftermarket Cold Air Intake
Hey Guys just wanted to get some opinions on going aftermarket CAI. Is there really any benefit to installing a CAI vs keeping the stock one on my 335is? After MUCH debate I've decided to go the JB4 route for added power but I'm still unsure about adding a CAI. Ive read a lot of conflicting info on the CAIs: stock is better, aftermarket can harm the engine, no performance advantage, etc etc... I definitely like the added turbo spool sound but is that really all it's good for?
'16 F82 M4 Black Sapphire (Mine)
'16 F30 340 Black Sapphire (Wifey)
'14 F30 335 Mineral Grey (Retired)
'11 E92 335is DCT Black Sapphire Metallic (Retired)
'11 E92 335 Space Grey (Retired)
'08 E90 328 Alpine White (Retired)
'04 E46 325 Silver Grey (Retired)
'03 E46 330 Titanium Silver (Retired)
1st ED - Aug/Sept 2013 - '14 F30 335 Mineral Grey
2nd ED - May/June 2015 - '16 F32 428i (Dad's Ride)
3rd ED - July/August 2016 - '16 F30 340 Black Sapphire & '16 F82 M4 Black Sapphire
Old 10-26-2013, 01:41 PM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Its as compared to what. A 335is with a JB4/BMS Tune & a mix of E85/93 & no other performance equipment has run 11.9 @ 117mph with the stock system. I have always been against them unless you were well up into the 400whp range because the stock system with the high 11 second run strongly suggests the stock unit is OK for 400 odd whp.
That being said I am using an aftermarket charge pipe & found it easier to get a stuff on the drivers side of the engine with the BMS/DCI. Undo two worm clamps & they are out as compared to the more time intensive removal of the stock airbox. So my bottom line is unless you have a reason to remove the stock unit leave it in. The DCI functionally add some intake noise to the car but does nothing for power in a light to middle modified car.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 10-26-2013, 02:01 PM
MasterYoda's Avatar
Thanks Bear. That's what I thought. Just wanted some confirmation. On another topic. What's the deal with the BMS back end flash? I've seen you and others mention it and I wasn't sure if it's something I will need to do at some point.
Old 10-26-2013, 03:17 PM
Its an additional way to get extra power without extra hardware. Key is available fuel, E85 or 100 race gas. If you don't have fuel to mix into 91/93 to raise the overall octane its not a good investment. Unlike the 335i model that can load the flash with a $187 BT cable The 335is requires a COBB unit which is in the range of $700 brand new. There are V2 COBB'S floating around the site at a better price because a V3 unit has been recently released. Either unit is just fine. If you buy new Terry is a COBB dealer & you might be able to get a discount.
Running pretty much everything the same as on my normal Map 6 I am up from 370/375whp to a bit over 400whp on a 50/50 93/100 mix. This costs me about $25/30 extra a tankful since the 100 octane comes from the pump at the gas station not from 55 gal barrels or a gas truck at the track. I can also run the BMS Map 7 if I have straight 100 octane in the tank like you would do for a day at the track. My Map 7 logs are very good but I have not had it on a dyno so I donít know what the actual WHP for 100 is. It is noticeably stronger than the 50/100 mix but its still just a butt dyno so I canít put any numbers to it.
If you canít get the fuel its best to just work at optimizing what you have. 370whp as measured by a DynoJet machine can be expected from your car.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 10-27-2013, 05:57 AM
MasterYoda's Avatar
Running pretty much everything the same as on my normal Map 6 I am up from 370/375whp to a bit over 400whp on a 50/50 93/100 mix. This costs me about $25/30 extra a tankful since the 100 octane comes from the pump at the gas station not from 55 gal barrels or a gas truck at the track. I can also run the BMS Map 7 if I have straight 100 octane in the tank like you would do for a day at the track. My Map 7 logs are very good but I have not had it on a dyno so I don't know what the actual WHP for 100 is. It is noticeably stronger than the 50/100 mix but its still just a butt dyno so I can't put any numbers to it.
If you can't get the fuel its best to just work at optimizing what you have. 370whp as measured by a DynoJet machine can be expected from your car.
Ok Thanks. Sounds like running E85 and the BMS backend flash might be something to get into down the road. It's interesting that with the 335is we need the COBB unit vs the BT cable.
Which maps did you run with just the JB4 on your 335is? I'm thinking about getting downpipes and FMIC at some point just not right off the bat.
Old 10-27-2013, 08:30 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
You may wish to consider this after, say, LSD install. Long after, actually....a Poseur purchase.
Old 10-27-2013, 08:53 AM
Map 6. The default settings from BMS are 335is specific settings. Its designed for 93 octane fuel. Since I run higher octane I increased it .5psi at a time logged it till I had too much boost & was pulling ignition timing & backed it down .5psi.
Yesterday was setting up a test for the BMS charge pipe running 100% 100 octane race gas, available from a somewhat local station at the pump, the computer logs & butt dyno said I was slipping the tires on the 2/3 & 3/4 shifts. This was causing ignition pull but it was still a very eye opening run. It was colder that normal here, low 40's, & my summers had exceeded their level of competency.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 10-27-2013, 08:56 AM
MasterYoda's Avatar
Lol. That's one thing I never want to be! I'm going to throw the JB4 on this week with some new plugs and walnut shell blasting. I just found a place running a special on it for $350.
Old 10-27-2013, 09:07 AM
MasterYoda's Avatar
Ok. The reason I'm asking is because the guys at burger suggested I run map 2 or 5 on the 335is with 93 octane. They also suggested the DCI for additional 10 hp on map 2. I would rather get my info from you guys who are very knowledgable and out there using it. Thanks bear!
