Old 10-27-2013, 07:49 AM
Charlievpr Charlievpr is offline
Charlievpr
Mein Auto: 2009 X5 3.01si
Sticky plastic interiors
Just got a used 2009 X5 3.01si. Upgraded from an x3. Unfortunately I did not notice that the passenger side arm rest was sticky. Its made of plastic and its the only one that has this problem. I've heard of using alcohol to remove the stickiness, but I don't want to damage the leather. Any ideas?
Old 10-28-2013, 03:17 PM
Advocate Advocate is offline
Mein Auto: X5 35d, Z4 3.0i
I'd first try some warm water with gentle soap. If that didn't work I've had good luck with Meguiars leather line. The stuff in my garage was purchased at Autozone. Meguiars Gold Class Leather & Vinyl Cleaner. It's worked for me when the kids spill ice cream on the back seats. Even found a mummified lollipop back there once. Cleans right up. Good luck.
Old 10-28-2013, 05:37 PM
Charlievpr
Appreciate the feedback. I'll try it and let yu know what happens. As additional information I've used soap, alcohol and WD40 (no luck). It seems to get worse with every try. The plastic seems to be melting before my eyes.
Thank
Old 10-28-2013, 09:03 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Post on detail sub forum under best of Bimmerfest. Very helpful and knowledgable peeps there.
Old 10-29-2013, 04:25 AM
Charlievpr
Thanks,
I'll keep you posted.
Old 11-02-2013, 06:56 PM
Charlievpr
Entered the site and followed advice to use 3M product. Ended up with a black strip on the handle (it removed the paint). Does anyone know if I can touch up this area?
Old 11-02-2013, 10:12 PM
ard ard is offline
Resident Curmudgeon
Before you screw something else up, why not post a picture of this part?
IMO you'll probably wan to replace this part....
Old 11-03-2013, 04:45 PM
Charlievpr
The car is at the dealer for a routine inspection. I will post the pictures as soon as possible
Old 11-03-2013, 05:09 PM
3seriesbmw's Avatar
3seriesbmw 3seriesbmw is offline
Mein Auto: 2003 325i
The pull handle on my passenger door turned into sticky goo so I've ordered the new handle and plan to put it on when my running boards and mudflaps come in. This was the inside pad of the door pull on my vehicle and of course I didn't notice it when I test drove the vehicle. Depending on which part it is exactly replacement might be best if it's nothing major.
Thanks,
3series
Vehicle lineup:
2015 Yukon Denali & 2004 BMW X3
Old 11-03-2013, 05:29 PM
Charlievpr
I/ve thought about doing this, but I don't know if its something I can handle. I've taken the door panel off of a Toyota Sequoia, but this may be completely different. Appreciate your help and suggestion. I'll be posting a picture as soon as I get the car back from the dealer.
Old 11-03-2013, 08:42 PM
rh71 rh71 is offline
Among the Proud
Mein Auto: X5 3.0si
I asked a garage to take off and re-seat a door panel on my '08 once and they warned me because of age that if they remove it, there may be brittle wiring (for lights) that may break apart. It turned out fine, but be careful when you remove the paneling that you don't tug it away too far or hard.
'08 X5 3.0si - Alpine White / Saddle Brown interior
Specs: Sport Pkg, Premium Pkg, Tech Pkg, Comfort Access, Aero Kit, Style 433 staggered 20s on Conti DWS
Mods: Carbon 35 tint, LED angel eyes, GP Thunder 7500k fogs, H&R 20mm/25mm spacers, clear reflectors, gunsmoke-tinted taillights
Coded: Digital speedo, windows/sunroof/tailgate close via keyfob
X5 pics at Flickr
Old 11-03-2013, 08:47 PM
3seriesbmw's Avatar
A local garage is going to charge $40 to put the handle on so I'll probably let them take the risk of replacing it! Any garage should be able to handle such a task, but I'd make sure to ask around to see who people use the most!
Thanks,
3series
Vehicle lineup:
Old 11-06-2013, 05:02 AM
Charlievpr
Here's a picture of my dilemma (picture on the right). I am also including a picture of the driver side arm rest, which I would also like to replace.
Name:	X5 Driver Side Arm rest.jpg
ID:	406017   Click image for larger version
Name:	X5 Passenger Side Arm Rest.jpg
Last edited by Charlievpr; 11-06-2013 at 05:05 AM. Reason: Left out part of message
Old 11-08-2013, 06:47 AM
3seriesbmw's Avatar
Same thing happened with mine. Use www.realoem.com/bmw to find the part number for the door pull. It will ask for the last 7 of your vin to identify your vehicle. Once you have the part number plug the number into the search bar on www.bavauto.com and you should be good to go!
Thanks,
3series
Vehicle lineup:
Old 11-26-2013, 08:35 AM
Charlievpr
Ended up doing what you suggested. Looked up the parts and sent for them. Will install shortly. Appreciate the feedback from all of you.
