Old 10-27-2013, 10:44 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Thinking about adding meth
Hello...If I add meth (looking at BMS System) under CPO (43K right now), what will be involved in removing if I need servicing? Is it intricate or pretty straight forward? Hoping Calwaterboy might give me his insight as well. I already have a JB4 I installed myself so was also planning on doing this myself as well.
Old 10-27-2013, 11:50 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by sptt144 View Post
Hello...If I add meth (looking at BMS System) under CPO (43K right now), what will be involved in removing if I need servicing? Is it intricate or pretty straight forward? Hoping Calwaterboy might give me his insight as well. I already have a JB4 I installed myself so was also planning on doing this myself as well.s
I don't recommend installing meth w/charge pipe, tubing, etc., if you're anticipating removing it for dealer service. First, touch shady. Second, PITA!
I do recommend it for that youthful, s**t eatin' grin and confidence of knowing that kick a**, leave-'em-dumbfounded performance is a couple o'button pushes away.
Risks. Your ride has sintered connecting rods - the out of spec, add'l stress at the apex of a down stroke can throw a rod! Think: Beyond Economical Repair. Yup, just ask SneekyDeeky. Also if manual trans, all too easy to over-rev. Can be major. In general you're operating beyond the design envelope of the engine from time to time, but on the upside, you're burnin' twice as bright!
Hey, according to Ian Fleming, Mr. Bond was warned in sobering tones that supercharging his Bentley carried great risk they would not be responsible for. The name was Bond....James Bond.
Old 10-28-2013, 12:17 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Just to add, meth itself is dangerous & needs to be respected. Even a 50/50 mix can burn. Always use first level components & fittings. DO NOT try to cheap out & use the window washer bottle as your meth reservoir. All the cheap kits do this but you should buy a trunk mounted meth specific tank & pump. In other words treat it like you would any fuel (gasoline) & you will be good to go with an abundance of additional power.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 10-28-2013, 07:35 AM
Banned
Mein Auto: 2007-335 HTC
so turning your car into a meth lab!
Old 10-28-2013, 09:00 AM
RobertoCervezas RobertoCervezas is offline
Mein Auto: 2013 335i coupe
I'd do the flex fuel wires instead if you haven't already. Everything I've read says that with E85 there is no need for meth. Only concern would be the corrosive nature of E85, but it would still be much easier.
Old 10-28-2013, 09:08 AM
FCBayern///M4's Avatar
FCBayern///M4 FCBayern///M4 is online now
Extended Euro Delivery
Mein Auto: M4
Re: Thinking about adding meth
I say do it...and when you blow your engine have BMW fix it on their dime, they wont even notice.
2015 M4//B67//ZDB//ZEP//ZEC//2MK//2VF//2VZ//403//688//
Old 10-28-2013, 09:38 AM
TheyCallMeNun's Avatar
TheyCallMeNun TheyCallMeNun is offline
Fest Wrks
Mein Auto: 07 335i coupe
I think about doing meth all the time, then I watch one of those meth baby videos on youtube and have a change of heart. Like they say once you go meth... meth
BMW Owner Since 17
'00 323i
'07 335i coupe
Black Sapphire 6MT
BMS JB+ & DCI
Turbosmart BOV
Old 10-28-2013, 09:43 AM
sptt144's Avatar
Ok...thanks guys. I do not want to blow anything out our ruin my engine so I will hold off on putting in a meth kit. JB4 does well for me now.
Sent from my SCH-I405 using BimmerApp mobile app
Old 10-28-2013, 10:33 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
for half as long?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 10-28-2013, 08:35 PM
Originally Posted by thekurgan View Post
for half as long?
That is an issue....forged rods a la M3 avail for ambitious DIY's.
