P0174 (and sometime P0171) what next? - Bimmerfest - BMW Forums
Old 10-27-2013, 09:59 PM
Hatzenbach Hatzenbach is offline
Mein Auto: 2015 i3 & 2006 X3
Hi,
I am getting either P0174 or P0174 AND P0171 every other day (I read and then delete then with a code reader)
I already replaced the intake boot a few thousand miles ago when I had the same symptoms which took care of it (until now)
Next thing I did was to clean the MAF which didn't help
The car feels down on power
What are the next logical steps to do?
O2 sensors?
Replace MAF?
Old 10-27-2013, 11:04 PM
wowturtleswow wowturtleswow is offline
Mein Auto: x3
try checking the intake manifold for a leak in the gasket, letting air seep through.
Old 10-28-2013, 03:29 AM
todd92 todd92 is offline
Mein Auto: 13 X3 3.5, 05 ZHP
There are plenty of threads on lean codes. Search.
It can only be intake leaks (which can occur multiple other places than the intake boot), fuel pump failing or pre-cat O2 sensors getting lazy.
If the codes appear at start up/idle it's leaks or fuel pump. The idle may also be rough. If the codes appear during cruise it's most likely the O2 sensors.
I don't get why people clean MAF sensors and/or replace them. They almost never fail and you can damage them cleaning them incorrectly, creating a new problem in the process.
Old 10-28-2013, 03:49 AM
joylove joylove is offline
Mein Auto: 08 e83 LCI
You have to be quite a gorilla to break them once you know they are a bit fragile. A cotton Q Tip and a dose of IPA or other electircal cleaner turns contacts that look like the image below, into bare metal wires.
[Yes this is from a Toyota, and yes there is a second hidden sensor on this unit]
The difference in the functionality between a clean sensor and a contaminated one can be significant, which is not surprising considering how they work and the power they have over the A/F mixture.
Old 10-28-2013, 04:15 AM
How do suppose a MAF gets dirty? Unless you're driving around with no air filter and then you've got much bigger problems.
Old 10-28-2013, 07:04 AM
Is there a way to check O2 sensors, or is it basically just replacing them?
I am at 90k miles, so they're probably at the end of their lives
About the MAF: I cleaned it with electronics spray cleaner and I did this as in my other car (Boxster) they are notorious to get dirty, so figured why not?
Old 10-28-2013, 07:29 AM
Burning2nd's Avatar
Under the lift arms
Couple of things ... Forget the o2's your looking in the wrong spot
Don't clean your maf in the future ... It's a sure fire way to be buying a new one
Fix your air leaks ... You have vacume leaks that is all
15486372<-----
Old 10-28-2013, 10:09 AM
codog2 codog2 is offline
Mein Auto: 5
I was getting the 171 & 174 codes (came on twice this summer (july)within two weeks of each other).
Cleaned the MAF with MAF spary I bought at Autozone - CEL hasn't come back since.
Old 10-28-2013, 07:31 PM
Ishniknork's Avatar
Ishniknork Ishniknork is offline
I hate doing dishes
Mein Auto: '05 X3 3.0i
Hatzenbach-
More than likely you have a cracked intake boot. The cracks are usually on the pigtail that goes to the idle air control valve.
The second place to look is the CCV valve hoses. There are 4 of them but the most likely one to fail is the bottom one that drains oil back to the dipstick.
Check out this thread for the intake boot replacement...
http://www.bimmerfest.com/forums/sho...d.php?t=499471
...and here's some video and pictures of the CCV stuff
http://blog.bavauto.com/8003/diy-vid...lation-system/
'05 X3 3.0i Alpine White/Gray Leather/Alum. Trim
Sport/Steptronic/Servotronic/Panoramic
Premium Sound/Staggered Style 114 18"ers
Old 10-28-2013, 09:59 PM
Originally Posted by Ishniknork View Post
Hatzenbach-
Thanks,
as I wrote in my initial post I replaced the intake boot a couple thousand miles ago, so I rule that one out. OK, replacing CVV looks like a major PITA
Old 10-29-2013, 02:01 AM
Mein Auto: x3
to answer your question about checking the o2, you can check it by reading the voltages right at the o2 sensor or by observing them with a scan tool. but check for leaks first. KISS keep it simple stupid
Old 10-29-2013, 07:19 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Can you pull the DISA out and visually inspect the flap? That may be a culprit and its a free and easy check.
Old 10-29-2013, 08:05 PM
what's a good range for the voltage?
sounds easy enough, thanks
Old 11-01-2013, 04:39 PM
quick update:
couple of days ago it occurred to me that I forgot to reset the SES light after cleaning the MAF. (I thought I had, but going down memory lane I am now pretty sure that I forgot).
Low and behold: I reset the SES a couple of days ago and no new SES light since (usually it came back within 24h), keeping fingers crossed....
Old 11-02-2013, 10:28 AM
Mein Auto: x3
on a warm engine, it should fluctuate between 200-800 mV, and never over 1V
