Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 F15 (2014 - Current)
The all new F15 BMW X5 started production August 2013 as a 2014 model year. The new X5 arrives in sDrive35i (RWD), xDrive35i, xDrive50i and a diesel xDrive 35d.
Old 03-13-2014, 11:00 AM
invisihitch invisihitch is offline
Mein Auto: 2012 X3
Originally Posted by obmd1 View Post
Would you suggest ordering directly from you and then heading to the installer, or going through them?
BMW dealers who work with us are often our authorized resellers. Generally the opposite is true for independent installers; they provide installation services only. So if you plan to use an independent installation shop, you would order directly from us. We can then either ship to you or drop ship your hitch to the installation shop.
Daryl
daryl@invisihitch.com
Old 03-13-2014, 11:53 AM
BMWXX55 BMWXX55 is offline
Mein Auto: 2014 BMW X5 35D, BMW 435i
What makes me really nervous id that if I install the invisihitch with active transport will I have any problems with the warranty? Has anyone had problems like this?
Old 03-13-2014, 12:44 PM
jrhubott jrhubott is offline
Mein Auto: X5
When it come to the active harness just make sure your dealer knows what they are doing and that they will enable all of the features when coding the car for the harness.
1. Disable PDC on connection
2. Changes to stability control when towing
3. Enable trailer zoom view on the rear camera
My dealer(BMW of Encinitas) has been unable to achieve this and is now saying that these are not features. I have been able to code the trailer zoom but I'm unable to determine if the other options are enabled.
Originally Posted by invisihitch View Post
I sent you a PM about an installer in your area.
To order the invisihitch, please call in your order at (678) 400-0121.
Here are the differences between the Passive Harness and the Active Harness:
Passive Harness:
The Passive Harness is the standard harness offering in some regions of the world when you add the hitch to a 2014 X5. We import the Passive Harness and offer it here in North America as an alternative to the Active Harness. The Passive Harness simply listens to the vehicle's taillight circuits and, in turn, generates its own independent taillight signals to the trailer plug. It also makes intelligent substitutions in the case of a trailer bulb outage. (For example, should the left-side trailer taillight burn out, the harness will recognize this and it will send a low-voltage signal to the left-side brake light so that the brake light glows dim like a taillight). The Passive Harness does not feedback information to the vehicle's computer; thus it is a "passive device" as seen by the vehicle. With the Passive Harness, you will probably want to manually silence the rear park sensor using your iDrive when reversing with a trailer attached, since the vehicle is unaware that a trailer is attached and it will beep due to the trailer being close to the rear bumper. Since this harness is a passive device, it does not require any reprogramming of the vehicle.
Active Harness:
The Active Harness is the harness that will get installed by North American BMW dealers unless you specify otherwise. The Active Harness carries on two-way communications in realtime with the vehicle. It informs the vehicle when a trailer is connected to the electrical socket, and the vehicle tells the harness when to generate taillight signals to the trailer. In the event of a trailer bulb outage, the harness does not make any intelligent substitutions but instead informs the vehicle that a trailer bulb has burned out. The vehicle then lights a warning on the dash regarding a trailer bulb failure. With the Active Harness, the vehicle automatically disables the rear park sensors whenever it is informed that a trailer is connected. The vehicle also monitors for excessive trailer sway and, in cases of extreme sway, the vehicle applies braking to counteract the sway. Since this harness feeds back information to the vehicle, it requires that the vehicle be reprogrammed to recognize it and communicate with it.
I hope this is helpful.
Daryl
Old 03-13-2014, 02:56 PM
Mein Auto: 2012 X3
No one has ever had a problem like that. From what our customers tell us, the primary reason that many of them spend the extra money for the Active Harness is not for its features but rather to avoid even the remote possibility of any future discussion with their dealer about whether something is or is not covered by warranty. The Active Harness is the exact same harness that a North American BMW dealer would install if they were installing their own hitch on your X5. Likewise, the vehicle reprogramming is identical. There really cannot be much of discussion about whether it is an approved part or approved coding.
As for the hitch beam itself, since the invisihitch is the BMW OE hitch in some regions, it would seem more than a bit odd if BMW were to test and approve the invisihitch for installation by its dealers (which it has) and then later attempt to deny a warranty claim due to its installation. That has never happened either, and the possibility of it ever happening is precluded by BMW's global vendor-approval process.
Daryl
Old 03-14-2014, 08:11 AM
Mein Auto: X5
Forgot to mention. I love the invisihitch over the US BMW option. It rocks!!!
Old 03-19-2014, 03:26 PM
leezer leezer is offline
Mein Auto: 550 xDrive 2011
Just finished the coding so now I have the trailer zoom option. I am very pleased with my invisihitch and what a GREAT company to work with! Thanks again Daryl.
Old 03-22-2014, 06:31 PM
Where would the wiring be for thw trailer when the invisahitch is installed? Does it look like the OEM wiring for trailers??
Old 03-23-2014, 08:15 AM
Mein Auto: 2012 X3
No, it definitely does not look the same. On the dealer hitch, the large electrical receptacle mounts below the fascia and points rearward so you always see it. The invisihitch mounts the receptacle vertically, behind the fascia, where it cannot be seen. You plug the trailer in using an upward motion, just like you insert the ballmount upward into the invisihitch. I'm not sure how clearly you can see this in the attached picture, but the 7-way round receptacle is at the far end of the picture in parallel with our receiver opening.
Daryl
Name:	Under-vehicle view of invisihitch.jpg
Old 03-30-2014, 08:23 PM
ybd2 ybd2 is offline
Mein Auto: 2014 X5 (F15)
Does anyone know of a good mechanic in the San Francisco area to install a Invisihitch to my 2014 BMW X5 35d with m sport package? What is the difference between an active and a passive harness? Where can I order the Invisihitch hitch? Thanks
Maybe you have that other X5 I've seen around town! Can you please share with me the Invisihitch installer recommendation for the SF area, and any other pertinent information? Thank you.
Old 04-12-2014, 01:01 PM
Cristobal1 Cristobal1 is offline
Mein Auto: X5 F15
Need help fenderwell removal
I am trying to install invisihitch. I can't get the fenderwell trim off. I drilled out the rivets but can't find the clips or I don't know how to remove the clips. I am unable to get the first clip exposed like the picture in the directions. Can anyone provide any tips or pictures?
Old 04-12-2014, 01:23 PM
Mein Auto: 2012 X3
After you have drilled out and completely removed the rearmost 3 rivets, insert a plastic pry tool into the seam at the bottom or near the bottom of the fenderwell trim (see photo in the instruction manual). Then pry the trim away from the fenderwell. This may not release the bottom clip but, if not, it will expose the clip enough for you to see exactly where it is. Then, with that knowledge, you can reach through the fenderwell with your hand and push the clip down as you pry. It will release. The first clip can be tough; the rest give way more easily. Don't be afraid to pry. You aren't going to break the trim piece or this particular clip.
Daryl
Old 04-14-2014, 10:54 AM
Mein Auto: X5 F15
Spot on
I finished the Invisihitch install and wanted to provide some observations for those of you who may be hesitant with a self install. First, the directions are 100% spot on, the pictures match up exactly and there is no guesswork because the directions are detailed and accurate. My previous post about a problem with removing the fenderwell trim was caused by me being too cautious with my 10 day old vehicle. As Daryl mentioned, this part is very sturdy and will not break. Just follow the directions provided. I was going to send a picture of the hitch installed but decided it wasn't needed, if you want to see what it looks like installed look at your F15 now and that is what it looks like installed. It really is hidden. My wife drove up just after I finished and thought that I had quit the install and just put everything back together. She had to look under the vehicle because she did not believe the hitch was installed. I would highly recommend Invisihitch products to anyone interested in a tow hitch.
Old 04-26-2014, 07:54 PM
CarolD CarolD is offline
Mein Auto: Cayenne Diesel
Hi Folks... long time lurker since we got our 2011 X5d 4 years ago. I'm not much of a poster, but the way Daryl and Steve treated me, I'm motivated to share this invisihitch experience.
We needed a hitch for the X5. OEM was $$$. Invisihitch was the same price and a better product. After a number of emails back and forth with Daryl--he was gracious and patient--we ordered the invisihitch. Finding a dealership near DC that could install it was a challenge. We settled on Baltimore.
Hitch arrived in the mail 3/19. Hubbie and I went to dinner. On the way home someone hit us. Hard. I called Daryl and explained. What to do?! He said I could wait til I knew more; he would work with me. 10 days later, car was indeed totaled. I called Daryl. What to do? He let me wait til I knew what its replacement would be. We wanted another X5 but perhaps 2014?
The dealership quoted us a price on the 2014 X5 OEM hitch: $1500 parts alone. WHA??? They didn't even know what install would cost because they do so few! Car cost + $2K or more for hitch + first model year concerns = no go. We ended up with a used car that already had a factory tow hitch installed. I called Daryl. We reinforced the box and sent it back. Within a week, he had received it and the money was back in our account.
In the end, we did not end up with the invisihitch. Did we want it? Heck ya. Would I be a repeat customer in the future? Heck ya. Recommend them to others? Already have. You've all done your homework and know the product as well or better than I. But as for customer service, I was downright floored with how helpful, informative, and understanding these two businessmen are. On no fewer than 5 different occasions, I spoke with them, ranging from someone educating herself on hitch options for the first time to a rather desperate customer afraid she'd have to beg for mercy in a situation that was out of her control. On every occasion, they treated me like I was the most important customer they had.
Thanks for the opportunity to share. PM me if you think any of my experiences would assist your decisions.
Best wishes with your hitches.
Carol
Old 05-27-2014, 09:29 PM
ricksterv ricksterv is offline
Mein Auto: e30, e39 and land roverD1
hi from newbie
I have been through this thread due to deciding what my new tow vehicle will be - land rover, Touareg or a 2014 X5 - the subject of the tow is a 4000 lb (empty) travel trailer. All questions have been answered in the thread except my worries of the air suspension. I was leaning toward the X5 as the only one of the three that I can order new and NOT get airbags. Can anyone assist or give a link to threads regarding air bag issues (longevity, failure..) when towing with an X5? I was hitting the third row seating (the wife's request) and the required rear air suspension as I was getting into the order process. Thank to you all!
Old 09-24-2014, 02:07 AM
cali-surf cali-surf is offline
Mein Auto: f15
^ My apologies for the website... I keep hearing that the major re-write will be completed "soon". The 2014 (F15) X5 has not yet been listed on the website... probably because the re-write was scheduled to be completed before the release of the F15. So the pricing you are seeing on the site is for the previous generation (E70) X5. I will try to get the old site refreshed. In the meantime, I'm afraid you will have to phone in orders for the new F15 hitch packages -- (678) 400-0121.
The pricing I published in this thread is the correct pricing. I'm so sorry for the confusion.
Daryl
Daryl, looks like the pricing on website is still screwy. Also, do you have any dealers in LA who sell your hitch? I just need it for a bike rack.
Old 09-24-2014, 09:31 AM
clayhooper clayhooper is offline
Mein Auto: 2011 535i
@Ricksterv,
I currently tow a Travel Trailer that is 5000 lbs empty and comes in about 7400 lbs when fully loaded. The X5's air suspension and DSP work very well together and towing with it is quite nice. Even with the tongue weight right at the limit the vehicle drops maybe 1/8 of an inch. I have probably got close to 3000 miles toying in and the only concern that I have is the lack of really good mirrors. I have learned a few things that will save you a lot of headaches. DON"T use an equalizing hitch with this truck if you are going to be towing a heavy load. It throws off the DSP aspect and if your using a Invisihitch which I highly recommend it was not designed to for them. It moves the load to far away from the hitch and bad things happen. I have the 3.5d and it has plenty of power and I am usually passing other trucks going up hills. If you have any other questions feel free to IM me.
Clay
Old 09-24-2014, 11:36 AM
Mein Auto: 2012 X3
I sent you a PM with our highest-rated LA area installers.
The Rack-Only version of our hitch is $544 plus shipping.
To order, please call the sales office at: (678) 400-0121.
Daryl
Old 09-24-2014, 12:11 PM
MattBianco's Avatar
MattBianco MattBianco is offline
Mein Auto: F15 X5 35D M Sport
Complete Invisi-Hitch install on a 2015 X5D with pics and tips
This is a great post that shows how to instal Invisihitch on an M Sport, which has a trickier bumper: http://www.bimmerfest.com/forums/sho...660&highlight=
I believe the OEM hitch will not work on the M Sport. This works on all the lines.
Amber or Red Rear Turn Signals? Vote and have your say thread LINK Post your MPG L/100km results here LINK X5 F15 Engines Compared LINK
Take the BMW X5 F15 Survey: LINK Survey Results: LINK
Old 09-25-2014, 06:00 AM
2easypilot 2easypilot is offline
Mein Auto: 2010 335i convertable
The dealer is supposedly installing the OEM tow package on my M Sport right now.
Old 09-25-2014, 06:27 AM
MattBianco's Avatar
Please post photos so we can see how it looks. If OEM works that's great.
Old 09-25-2014, 06:35 AM
[QUOTE=MattBianco;8609746]Please post photos so we can see how it looks. If OEM works that's great.[/
They are delivering it to me on Saturday.
Old 10-05-2014, 11:48 AM
kef207 kef207 is offline
Mein Auto: E60
I had the OEM class II hitch installed on my '14 F50. I considered the Invisihitch but in the end it was too much hassle for me to order the parts, find an installer and then go to the dealer for programming. So I opted for the OEM install. It is not 'invisible' but unobtrusive enough and gets the job done. I pull a small trailer loaded with up to six kayaks so the class II hitch is plenty for me. I can also attach a bike or ski rack to the receiver.
A couple of things to note. Previously I pulled the trailer behind an Explorer with factory hitch. With the X5 hitch my safety chains and the wiring harness from the trailer were too short with the removable receiver tube. I managed to squeeze a few more inches of wire out of the trailer frame for the wiring harness to reach but had to redo the ground wire at the four pin connector. I also had to buy new, longer safety chains. Not the end of the world, but an unexpected hassle.
The hitch install went fine, the problems started with the programming. I'm glad to see others have not had any issues, so my experience is unusual. In the end it took 36 days, over $10k in parts, several PUMA sessions with engineers in Germany, replaced back up camera, TPMS and Sat Radio module, broken promises and threats of lawyers, and a customer successfully converted from brand enthusiast to 'won't ever buy another of those lemons' to get all the electrical problems sorted out (I hope). Still don't know if the problem is with the car, the hitch or the install.
In the end, I'm glad I went the OEM/dealer route otherwise we would still be arguing over who is to blame and who pays for what. The electronics on these things are very complicated and apparently very twitchy. Perhaps I can take some pride in thinking I have one of the most expensive trailer hitches in the history of towing.
Next SUV (or SAV) I buy will come with a factory installed hitch. Sorry, BMW, that leaves you out.
I have an X35d, premium, tech, lighting, X-line, mineral silver with ivory/black interior
Old 10-16-2014, 08:04 PM
skalberti's Avatar
skalberti skalberti is offline
It's good to be bad
Mein Auto: 2017 Mineral White M3
I ordered the invisihitch which came with a genuine BMW active wiring harness. It was extremely easy to install and everything was plug and play and works as good if not better than the factory hitch. Only cost me a tad over $1200, a couple beers and a little more than 3.5 hours. According to my dealership my BMW warranty is intact since the wire harness is BMW.
It's good to be bad
2017 M3 Delivered
2015 X5D M Sport - Delivered
2014 535i M Sport - Retired
2012 X5 Msport - Retired
2012 X5 Msport - deceased
2008 335i Dinan stage2, Forged 360 wheels- Retired
Old 04-08-2015, 09:18 PM
hotneutron hotneutron is offline
Mein Auto: TBD
Folks, I am very pleased to announce that we have now completed our invisihitch fitments and electrical testing on all versions of the new 2014 X5. Our new invisihitch for the F15 is now available for every configuration of the vehicle. So whether you are purchasing the 35i, the 50i, or the forthcoming 35d, our newest invisihitch will bolt directly onto it perfectly -- including all M Sport line models and even models with the add-on aero kit.
I am attaching pictures taken after this new hitch was installed on a 2014 X5. Of course, you absolutely cannot tell that a hitch is installed on the vehicle until you snap in the removable ballmount or the removable rack connector. Even the chain-hook eyes and the electrical receptacle are completely hidden. For comparison, I am also attaching photos of the new BMW dealer hitch for the F15. Although they have tried to conceal their hitch, the chain-hook eyes and the electrical receptacle stick out the back permanently, as do the metal prongs that form the entrance to their ballmount connection.
The towing capacity of the new X5 is 7,700 lbs (as rated by BMW Germany) when equipped with the invisihitch. Should you decide to use the dealer hitch instead, the towing capacity of your new X5 is reduced to 6,000 lbs... or even further reduced to 3,500 lbs... depending on which of the two dealer tow options you select.
You can purchase the invisihitch without a trailer-lights wiring harness and without a ballmount if you only want to use a hitch-mounted rack, such as a bike rack.
If towing, we offer two different packages that differ only in the type of wiring harness included. First, there is the inexpensive passive Euro harness, which operates the trailer lights and interfaces passively with the BMW wiring. Then there is the more full-featured active Euro harness that communicates in realtime with the vehicle. The passive harness is more economical and it does not require the vehicle to be reprogrammed. The active harness offers more features, such as trailer-bulb outage notification on the dash, but it is more expensive and it requires reprogramming the vehicle to enable communication with the harness. Our active harness is the exact same harness that U.S. dealers sell with their dealer hitch; we offer it as one of two different harness options with the invisihitch. Our passive harness is also a harness option that is offered by BMW overseas, but the U.S. dealers do not stock this option. If you decide to purchase the dealer hitch, instead of the invisihitch, your only wiring option from the dealer will be the active harness.
Here are the three different invisihitch packages for the new X5 (F15):
Rack-Only Package (no towing) - $544
invisihitch receiver with vertical latching mechanism
detachable 2" square receiver
Both Towing & Rack Capable (w/passive harness) - $863
detachable ballmount for towing up to 7,700 lbs
passive trailer-lights wiring harness
control module for the wiring harness
Both Towing & Rack Capable (w/active harness) - $1,148
active trailer-lights wiring harness
remote vehicle reprogramming via the internet
Thanks to all for your patience while we engineered and tested these new offerings, and thanks especially for your support of our products and our sponsorship here.
Cheers,
Daryl
If install the rack-only package for now. how hard is it to install the wiring harness later? Also how much would it cost to upgrade from package 1 to package 3?
Old 04-09-2015, 06:46 AM
Mein Auto: 2012 X3
^ To upgrade from the Rack-Only package to one of the full Tow+Rack packages, you will have to do almost all of the installation over again. This is because it is not possible to add either of the wiring harnesses without removing & replacing the rear fascia again. And removing/replacing the rear fascia is probably 90% or more of the installation effort & time.
The upgrade kit, to convert a Rack-Only package to a full Tow package with active (OEM) harness is $681.
Daryl
