Old 10-28-2013, 12:37 PM
brewder brewder is offline
Mein Auto: 2011 328i xDrive
Thunking...not what I was expecting..
So my 2007 E92 developed a "thunking" noise that I would hear going over small bumps at typically low speeds... I was convinced the sound was coming from the front driver side suspension.. I was further convinced the noise was from a worn control arm bushing...I was "convinced" only by what I have read online, and not any prior experiences...
My service writer just called and informed me the driver side REAR shock is complete out of fluid and "blown out", and the passenger side was "less than new". I'm guessing that was his way of telling me to "replace them both".
They swear this is the fix and cause of the noise...
Any thoughts or experience of this happening to them??
129k on the Odo... original shocks/struts.
//Brew...KCCO
('11 E92 328i xDrive - Deep Sea Blue | '07 E92 328xi - Space Gray)
Old 10-28-2013, 12:45 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
Well you certainly are due for shocks. You'd notice a difference in the ride of your car replacing them even if they aren't the cause of your noise. It's not exactly like needlessly replacing a part.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 10-28-2013, 12:48 PM
Miller335 Miller335 is offline
Mein Auto: 2007 E92
It sucks having to spend the money but you were definitely due either way.
In fact if it were me I'd be happy at their service given that it's more of a performance oriented vehicle.
Old 10-28-2013, 12:49 PM
captainaudio's Avatar
Worlds Foremost Authority
The OEM dampers on the 2007 sports suspension are crap.
Replace all four with Koni FSDs. You wont be sorry.
CA
Drivers Club at Lime Rock
BMWCCA
Cayman Club Nor'Easters
Porsche Club of America
Sports Car Club of America
American Mural Project
Mount Washington Observatory
Old 10-28-2013, 02:00 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
129K!
I've read here that when the shock is starting to leak, it was already way past the point of needing to be replaced.
The bright side with parts failures is that it's the perfect excuse to upgrade!
Personally, I'd look into changing out some susp to M parts if any labor charges would be redundant... oh wait, dunno how that would work out with xi...
Old 10-28-2013, 03:53 PM
Originally Posted by Ilovemycar View Post
129K!
Certainly not worth "M Parts" on a 328xi.... So I opted for OEM BMW.. and yes, the ride is much better now...
//Brew...KCCO
Old 10-28-2013, 05:58 PM
anE934fun anE934fun is offline
Mein Auto: 2010 335d
CA
+1. And, the cost for OEM shocks is probably close to (if not more than) a set of FSDs.
Old 10-29-2013, 04:20 AM
Hmmm... not too sure about that... I paid $857 out the door for diagnostics, and the replacement of both rear dampers.. I believe the dampers were roughly $220 each.
//Brew...KCCO
Old 10-29-2013, 06:39 AM
How much longer do you think your other two dampers would last? Unless you are looking at getting a replacement for your car, new dampers are in your not too distant future. A set of FSDs can be had for around $800. Less when they are on sale.
Old 10-29-2013, 06:43 AM
It's funny the dealer didn't push replacing the fronts.... anyway, yes, i'm going to plan to have them replaced as well...
//Brew...KCCO
Old 10-29-2013, 06:52 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
I would have never replaced just one set of shocks/struts at that mileage; that's just crazy, it can lead to the car porpoising. Also, "thunking" can also be caused by just worn shock mounts, I'm hoping they replaced the rear shock mounts at the same time as these shocks.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 10-29-2013, 07:01 AM
Re: Thunking...not what I was expecting..
Yeah the mounts were replaced as well.
//Brew...KCCO
Old 10-29-2013, 07:03 AM
When I replaced the OEM dampers with FSDs I was told that the originals were still in good shape at about 35,000 miles. The shop that installed the FSDs asked me what I wanted to do with the originals. I told them to throw them away.
CA
BMWCCA
Old 11-02-2013, 05:26 AM
UPDATE:
The noise I'm hearing never went a way... but I think it's the driver side strut/damper. here's why.
When I press up and down on over the passenger side tire, I can hear the damper making a "Pssst....Pssst....Pssst" as I bounce the car. When I do that over the driver side tire, it makes ZERO sound.
When I run the driver tire over those cut-outs in double yellow lines (drift warnings or whatever they are formally called) at say 20 mph, you can hear the rattling like crazy.
Sounds to me like I need to replace the front dampers now too.
//Brew...KCCO
Old 11-02-2013, 05:45 AM
grijo grijo is offline
Mein Auto: 2013 BMW 328i Coupe
UPDATE:
As others have said, when you replace shocks you do all four corners. After 129K miles you cannot expect any more life from the front shocks. I do not like to spend money on parts either, but some items (shocks, tires, brakes, fluids, etc.) just wear out and need to be replaced.
The approach you followed is now going to cost you significantly more than if you had done the 4 shocks at once. Good luck.
2013 BMW 328i
2008 Honda S2000
1972 MB 250C
Old 11-02-2013, 05:49 AM
Originally Posted by grijo View Post
As other have said, when you replace shocks you do all four corners. After 129K miles you cannot expect any more life from the front shocks. I do not like to spend money on parts either, but some items (shocks, tires, brakes, fluids, etc.) just wear out and need to be replaced.
The approach you followed is not going to cost you significantly more than if you had done the 4 shocks at once. Good luck.
I agree 100%... I just was looking for some validation on my "Testing"....
The dealer quoted me $1,700 to replace the front struts.. + $169.99 for an alignment...
//Brew...KCCO
Old 11-02-2013, 06:39 AM
Banned
Mein Auto: 2007-335 HTC
wow that sounds really high to me, I had mine replace at an Indy shop for 400, but I provided the new shocks
nothing special about the job but its a pain, I assume they are replacing the upper strut mount too
Old 11-02-2013, 07:46 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
OP - just one more thing: Koni's carry a lifetime guarantee
If you buy Yellows, you'll find they are rebuildable, recommended every 40k mi for max performance. Dunno about FSD's - Capt'n?
Old 11-02-2013, 08:56 AM
The replacement ones from the dealer carry a lifetime warranty as well. Since its a daily driver soon to be handed down to my son, the oem is good enough.
Thanks everyone for all the feedback! What a great resource these forums are.
//Brew...KCCO
Old 11-02-2013, 10:27 AM
Wait...really? What about the units that came with the car - same, right?
Old 11-02-2013, 10:55 AM
Yep. Lol. I even joked with my Sa. Why didn't they use those to begin with!
//Brew...KCCO
Old 11-02-2013, 11:15 AM
Answer may be in the details. Lifetime warranty for original purchaser of shocks only?
In other words, if sold, bets off....
Old 11-02-2013, 12:13 PM
Two warranty coverages that are not interchangeable. Shocks that came with the car may be the same that carry the lifetime warranty once they are installed after the factory warranty is over. Unfortunately the ones that are installed on the car from the factory only get the 48 month/50K mile coverage. I found this out on batteries. The battery that gets replaced is the same, but with different warranties.
Old 11-02-2013, 12:16 PM
FSDs are not rebuildable. But they do come with the lifetime warranty, so if they fail, a replacement is free (parts only, not labor).
Edit: Cal - if memory serves, you replaced suspension components on your E93 with M units. What Koni Yellow shocks did you use? Those spec'd for the E93 (non-M version)? Or?
Old 11-02-2013, 12:50 PM
Ouch!! Get Konis or Bilsteins, and find a recommended indie to do the work. My indie allows me to bring my own parts and he charges me the % he gets from the autoparts store (which I think it is fair)
2013 BMW 328i
2008 Honda S2000
1972 MB 250C
