Old 10-29-2013, 02:32 PM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Monacoblau mit beige
Mein Auto: E92 330i Manual
Thumbs down Ever had iDrive and multi-function buttons freeze?
Happened tonight where the screen was stuck on "BMW" as soon as I started up. The radio was stuck on, couldn't mute or change volume or station from the steering wheel. To be honest, I didn't check if the dash radio controls worked. Took key out and started over a couple of times, locking car, opening, ignition on etc, but it was frozen exactly as before. I went in and read up about holding in the eject buttons and volume knob to reset the system, but when I went back to do this minutes later, all was well!
Any experiences of anything similar in any iDrive system? Mine is July 07 which is apparently CCC update 1 according to Wikipedia.
330i SE coupé
Manual - N52K 262hp, 232ft-lb
Old 10-29-2013, 02:35 PM
surfcity335i surfcity335i is offline
Mein Auto: 2012 335i M-Sport
I think I know what happened. Your steering wheel is on the wrong side of the car. :-0
Old 10-29-2013, 02:43 PM
B/\/\W's Avatar
But the N52 engine was designed for right hand drive on left hand side driving. The exhaust tips are in close proximity to pedestrians walking by.
Thanks for the constructive feedback though
330i SE coupé
Old 10-29-2013, 07:35 PM
rt-texas rt-texas is offline
Mein Auto: 08 335i Cabrio E93
Yes. I was still under full warranty at the time. Had to do with my battery and the like $500 battery cable. Replaced the cable I know; traveling on biz and I don't remember if I got a new battery as well.
Old 10-29-2013, 07:39 PM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
My CCC has done this too. Normally it's the TCU that hangs and causes the CCC to freeze up.
Did you get any errors in your instrument cluster?
Old 10-29-2013, 07:56 PM
No error codes. Just realized I couldn't do anything thru i-drive. I could adjust volume and stations with the head unit, so that narrowed it down. It was intermittent.
First time I took it in; "they couldn't recreate it".
Second time; went to the dealership service mgr. That's when they volunteered that there had been issues with the cable. Has worked fine ever sense cable was replaced.
All was repaired under the original warranty.
