The X5 SAV Forum
Old 10-29-2013, 10:03 PM
cnotes628 cnotes628 is offline
Mein Auto: x5 3.0
at my wits end
I have a x5 3.0 06, my check engine light came sand I ran the codes and was a air flow issue. Now the trans failure Prog is coming on. When I drive, I can feel a hard shift between gears and when I slow down to stop, there is a jerk like the truck is skipping gears to get back to first gear
Anyone knows if the two issues are connected
Old 10-30-2013, 01:05 AM
white_lancer white_lancer is offline
Mein Auto: E53 X5 2004 3.0 SPORT
Trans failsafe prog error is to do with the gearbox not air flow problems. I only had this error once and too the truck to an Indy. He told me that it was due to a speed differential picked up by the sensors in the gear box. He flushed and changed the oil in the transmission and replaced the filter - problem sorted.
E61 2.0D Auto
Old 10-30-2013, 04:56 AM
Mein Auto: x5 3.0
Ok will try. Thanks
Old 11-08-2013, 10:53 AM
Mein Auto: x5 3.0
@white lancer
It was the air flow problem that was causing the trans failure program to kick in. I took it to my mechanic and he found a hole in air filter hose. As soon as he repaired that, the codes reset themselves. But thanks for the advice anyway.
