E34 (1989 - 1995)
Old 10-30-2013, 10:41 AM
Mitch Malakas Mitch Malakas is offline
Mein Auto: 1994 BMW 525i
Steering wheel binding and loud noise. Need Help
Ok so in my 10+ years of fixing, restoring, and upgrading my cars I have never run into this problem. I pulled my steering wheel to pull the dashboard in my 94 525 and when I went to put everything back together the steering wheel binds and makes a loud noise like you are snapping a piece of plastic in half. I have probably pulled a steering wheel off a car about 300+ times and never run into this problem. Is there so trick to these cars or did I break something? Everything went in really smooth and I didn't have to muscle anything in place. Let me know if anyone has a fix for this
Old 10-30-2013, 07:22 PM
Xlr8tin Xlr8tin is offline
Mein Auto: 2000 740i M-Sport
Did you turn the shaft with the wheel off? My mechanic was telling me the other day that there is a spring somewhere in there. I also have done that too. I can't remember what it was exactly, but I want to say my issue was it rubbing on some plastic from like the dash or something.
Old 10-30-2013, 07:53 PM
No I never moved the car with the wheel off. Do you remember what you did to fix the issue?
Old 11-05-2013, 09:06 AM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
It sounds like the clock spring in the wheel is buggered..
It plugs in for horn/buttons i believe.. Anyways.. Theres like a tab fir it that sticks into the column i beleve to wind the spring as you turn..
Pull the wheel off and check this maybe..
Bone stock 95' 540i/6 Blk/blk w/ ram style C.A.I / JBR LWFW/ DUDMD tune/ straight pipe /545 SSK /3.15 LSD / Rev-shift motor mounts/stage 4, 6 puck clutch/ K Sport coil overs/Eibach sway bars/ VAC under drive pulleys/weight reduction /sparco 368, Recaro seats, sparco harnesses, NX wet kit, M/T E/T streets.
"Skill can only get you so far, then comes money!"
R . I . P Paul Walker - 1973 - 2013
Old 11-05-2013, 09:08 AM
Resident e34 Racer
Does it actually feel like the steering is binding up when you drive? Or just audible clicking noise no feeling?
Old 11-05-2013, 10:36 AM
It was binding and making the loud snapping noise. I pulled the wheel and reinstalled it and it went away. I dunno BMWs are weird. Thanks for the reply.
