Old 10-31-2013, 07:10 AM
rtysonjohn rtysonjohn is offline
Mein Auto: bmw 325i
overheating
my 06 325i has overheated three times after driving for almost exactly two hours at speeds between 70 80 mph. I checked coolant before the trip each time. When warning light appears I stop, let it cool for a couple minutes and then add more coolant to replace the coolant that spews out when I open the cap. Then I continue my trip. It does not overheat on the return trip. I do not get it
Old 10-31-2013, 07:25 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
have you done anything to the cooling system recently (replace pump, thermostat)?
does it overheat while driving or when you stop?
Old 10-31-2013, 07:45 AM
Mein Auto: bmw 325i
I have done nothing to cooling system. The temp warning appears while driving but only after two hours driving between 70 and 80 mph
Old 10-31-2013, 07:51 AM
Mein Auto: bmw 325i
overheats while driving. car has 60k miles water pump never changed.
Old 10-31-2013, 07:54 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Whoaaaa. If you open the cap and refill it while the engine is hot you are NOT replacing lost coolant, only some of it. You have air in the system and it has to be bled off or you are going to be adding coolant ad infinitum. Learn the proper bleeding procedure and you will have a cooling system with all coolant and no air. Air is deadly and wreaks all sorts of havoc, both mechanical and chemical. For starters, your pump gets air entrained and greatly loses efficiency. Then that coolant that does circulate does its job very poorly due to the air 'insulating' the coolant from the water jacket. Meanwhile the oxygen in the air is acting as a catalyst between dissimilar metals. Think accelerated corrosion.
BTW, you will soon ruin your plastic tanked radiator if you haven't already. Bet you a dollar that the radiator inlet is ready to fall off...
Old 10-31-2013, 09:14 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Well, were you going uphill getting there; turn around to go home?
Old 10-31-2013, 09:19 AM
Maybe not a catalyst. And cooling system inhibitors should prevent corrosion, including galvanic, knowing what system metallurgy is from the factory.
But! If nitrite based, will oxidize to useless nitrate in the presence of oxygen, a well known failing of many closed loop treatments. Silicate was once used to inhibit corrosion with oxygen, but had the unfortunate effect of shredding pump seals. Prob organic protection now.
However. Higher than design temps and oxygen are a tough combination to beat. To wit: What's that radiator inlet made of? And if air in system, gotta look at pump cavitation compounding the issue. Low flow w/high temp may cause deposits; engine overheating. Oh, it's a nasty situation, fraught with traps and pitfalls!
