Old 11-01-2013, 12:43 AM
Girlbunny Girlbunny is offline
Mein Auto: 2007 BMW 328i
Question 2007 BMW 328i Extended Gold Warranty Coverage?
Hi,
I purchased the extended Gold Warranty Coverage for my 2007 BMW 328i and I was just informed that my radiator has a hole in it. The dealer says it will costs $1400.00 to replace?
First question: isn't that covered?
and
Second: $1400.00 seems really high?
I know owning a BMW is expensive, but that is why I bought the extended GOLD Warranty Coverage for over $3000.00
Old 11-01-2013, 06:00 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
That Gold warranty says "Heating/Air conditioning system and Cooling system"dont see why it would not,keep us informed.I have a 2011 328i and must extend the warranty myself and thought "Gold" was the way to go so please let me know what happens,thanks.
Life is a Journey,Enjoy your ride.
Old 11-01-2013, 06:24 AM
Banned
Mein Auto: 2007-335 HTC
take it in give them a copy of your warranty and let them sort it out. Make sure you tell them you will NOT accept a used Radiator, those warranty companies will try their best to put used parts on the car. While they are replacing the Radiator, even if you have to fork out the money have them replace the upper and lower radiator hose and I would do the serpentine belt too
Old 11-01-2013, 08:31 AM
git_yo_own git_yo_own is offline
Mein Auto: 2011 335i Sedan
As long as the hole wasn't a result of a bad job made by non-BMW service, I don't see why your radiator wouldn't be covered. Please let us up to date with what happens.
Old 11-01-2013, 08:46 AM
Norm37 Norm37 is offline
Mein Auto: Chevy half ton pickup
Originally Posted by Girlbunny View Post
Hi,
Just click on cooling system in the link below and it shows what is covered.
http://www.bmwusa.com/Standard/Conte...rotection.aspx
Old 11-01-2013, 08:54 AM
surfcity335i surfcity335i is offline
Mein Auto: 2012 335i M-Sport
Hi,
and
They'll tell you the thermostat stuck and caused the radiator to fail and thermostats aren't covered so neither is the subsequent damage.
Old 11-01-2013, 10:49 AM
3two8iguy's Avatar
Do you know that from experience?I would argue that the BMW "Cooling System" diagram list the thermostat as part of the "system"and if the "system" is covered then the thermostat should be covered as well.
Old 11-01-2013, 11:07 AM
You have to click "cooling system" to reveal the sublist of covered components. Radiator is there. Thermostat is not. My crystal ball says they will blame the non-covered component as the cause of the failure of the covered component, and then point you to the language that says failure of a covered component as subsequent damage to the failure of a non-covered component is NOT COVERED! Seen it a hundred times. I hope it does not happen to BunnyGirl.
Old 11-01-2013, 05:36 PM
Ok, i spoke with the warranty company today, and they are telling me that only the GOLD PLUS covers the radiator, I am digging up my signed agreement with them, once I find it I will know what is covered. I only have had the BMW dealership work on my car since I bought it.
Old 11-01-2013, 07:30 PM
Did you click on Cooling System in the link I gave in my first reply?
It shows the radiator is covered on all three plans.
Platinum Coverage, Gold Coverage, Powertrain Plus Coverage.
Ps. Did you buy the BMW Extended Vehicle Protection plan or some third party plan?
Old 11-02-2013, 09:28 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
Why would a thermostat (which sticks in the open position) cause a hole in the radiator?
Tom
Old 11-02-2013, 07:54 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
From my experience, radiators aren't that expensive unless you purchase from the dealer. A BEHR radiator for your car is $177.00. Usually you disconnect the hoses, pull out the radiator, put in the new one, and reconnect the hoses. I imagine they are charging you for every little thing they have to disconnect and reconnect at dealer prices and then new coolant and freeing they system of any air. I would try an independant BMW repair shop. It should be very basic for them to repair without the extensive dealership charges. Depends on how much you want to battle. My employee at work had a busted radiator in his Mercedes E350. Dealer wanted $1700.00. He got it done for $300.00 total from a mobile mechanic and tipped him $100.00. Has not had a problem in over 1.5 years with it.
Old 11-03-2013, 05:09 AM
Banned
yep I agree you should be able to do it your self, just some plastic covers to remove couple of hose clamps, just make sure you use distilled water when you fill it back up
Old 11-04-2013, 08:52 PM
Unhappy
I bought a third party plan, come to find out. I bought it at the BMW dealership, so I assumed it was a BMW Gold Warranty, a little bit confusing. It is a Gold Warranty just not a BMW Gold Warranty.
It gets worse.... my turn signals are not working, and they told me that I need a new light housing which cost $2600
If I have them do the radiator it is $1400.00, if I want the hoses changed when I put the new radiator in that is $2700.00 for just the hoses. Not to mention the $300 oil change,
$100 warranty co-pay, $195 inspection fee.
The trunk keeps falling on me when I open it, and that is not covered either.
Old 11-04-2013, 09:08 PM
sptt144's Avatar
Re: 2007 BMW 328i Extended Gold Warranty Coverage?
That doesn't sound like an extended warranty at all. Was the car falling apart when you bought it? Did you buy the car from BMW or just the exclusion filled extended warranty?
Sent from my SCH-I405 using BimmerApp mobile app
Old 11-04-2013, 09:16 PM
Trade it in.
Old 11-04-2013, 09:32 PM
Trade it in.
Good advice to consider, based on what the OP has told us.
Old 11-04-2013, 09:34 PM
Sorry I accidentally posted before finishing my thoughts. The OP might want to consider getting a second opinion from an Indy mechanic specializing in bmw's. GL!!
Old 11-04-2013, 10:05 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
nulled
Old 11-04-2013, 10:22 PM
TROLL!
$1400 for a radiator...$2700 add'l for hoses....more....
Let's review. Girlbunny, your opening was not too strong and not too weak - you established yourself as a friendly female possibly being taken advantage of. Strong BimmerFest men gathered to consult and recommend a course of action for this inexperienced, possibly single, soul from California.
But the fire died when you over-amped. Why reveal yourself with outrageous claims?
You had a perfectly good thing going, and you just crushed it. Ground it out with the heel of your shoe.
And that bit about a $2600 light housing because your turn signal didn't work. Where's the finesse? If you'd said your auto-leveling headlights malfunctioned, you'd have scored arousal. But a blinking turn signal?
Girlbunny, you have talent, but need experience. That is my critique - what you make of it is entirely up to you. Luck!
Old 11-04-2013, 10:44 PM
sptt144's Avatar
Originally Posted by CALWATERBOY View Post
TROLL!
What was that all about...???
Old 11-06-2013, 05:13 AM
TROLL!
CALWATERBOY;
I came here for knowledge about other's experience with BMW dealerships and warranties.
Old 11-06-2013, 05:37 AM
CALWATERBOY;
Well, ya never know. That $2700 charge to change hoses was over the top....
Old 11-06-2013, 05:45 AM
The car was fine when I bought it, but had 70,000 miles on it, and it was a non BMW car lot. I did buy the extended warranty from a BMW dealership where I have my car serviced. CAREFREE CAR PROTECTION mechanical failure service contract is the one I bought.
Old 11-06-2013, 05:53 AM
Yes it is way too expensive, so I think I will change it out myself.
