E36 (1991 - 1999)
Old 11-01-2013, 10:08 AM
short-circuit short-circuit is offline
Mein Auto: 97'328is
328i stroker build.
Hello my engine needs new piston rings and has lost a lot of power so i figured if im gonna take the engine apart might as well make it faster. im going to do it on my christmas vacation(1 month) after i finish university.
id really appreciate it if anyone could help me with what i would need to do , and exactly what parts i need since i need to source the parts and get good prices before the vacation so i can start to work on it immediately.
hopefully the block is still in good condition.
Thank You for all te help
Old 11-03-2013, 11:54 PM
Mjölnir Mjölnir is offline
Mein Auto: E39 540i6, E36 M3/4/5
You should really do a search for stroker info because you will find more than I could ever hope to tell you. It's been discussed many times before and there are different ways of going about it depending on your goals. Most common option is to transplant complete m54b30 rotating assembly (crank, rods, pistons) into your block. This gives roughly 3L displacement with a reasonable compression ratio (don't remember off the top of my head).
Old 11-05-2013, 12:06 AM
Mein Auto: 97'328is
so if i put just the crankshaft of a 330i wouldnt i be changing the stroke without having to change my 328i pistons and rods since they are the same diameter and the rods are both 135mm in lenght?
Old 11-05-2013, 05:09 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
If you change just the crankshaft without changing the rods too, your pistons are going to impact the cylinder head due to the longer stroke. As stroke gets longer, the rods have to get shorter so that the upper position of the piston stays the same.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 11-05-2013, 10:33 AM
Mein Auto: 97'328is
so what would you guys recommend i have till christmas to decide.
cost wise and power wise.
1. rebuild the 328i engine(new piston rings-valve guide seals- hone block...) + m50 manifold + e46 camshafts.
2. rebuild engine + m54b30 internals + m50 manifold + e46 cam
or anything other to suggest or add
Old 11-05-2013, 09:16 PM
jkmeisl's Avatar
jkmeisl jkmeisl is offline
Josh
Mein Auto: Built inze Fatherland 325
I've seen strokers built with the following
M52 b 28 Head
m52 b 28 block
m54 b 30 crank
m52 b 28 rods
m54 b 30 pistons
m54 b 30 Intake cam on intake side
m50 b 25 Non vanos Intake cam on exhaust side
claims to make about the same Hp and tq as the S52
I've not seen a dyno so I cant say
M3GT sedan - my slow progress thread ->http://www.bimmerfest.com/forums/sho...040&highlight=
Old 11-05-2013, 09:33 PM
jkmeisl's Avatar
Josh
here is all the info you will ever need.
lots of pic's on both
http://forums.bimmerforums.com/forum...m52-m54-hybrid
http://forums.bimmerforums.com/forum...r-cheap!!!-DIY
Old 11-05-2013, 09:46 PM
jkmeisl's Avatar
Josh
rods are the same 135 mm, the m54 pistons are 4 mm shorter then the m52 pistons
Old 11-06-2013, 09:35 AM
miles_trail's Avatar
miles_trail miles_trail is offline
I like pie.
Mein Auto: 96 318ti, 93 BMW 325IS
Re: 328i stroker build.
An other advantage of using the entire M54B30 rotating assembly is that it'll already be balanced. You can look at my build in my history.
Originally Posted by E36 Phantom View Post
How do you outcrazy a dude that lifts his engines without a hoist?
Old 11-06-2013, 09:36 AM
Mein Auto: 97'328is
Originally Posted by jkmeisl View Post
thanks for the help very very useful info.
i found a good 328i engine for 1000$ , but that puts me at stock power again,
or do you think i should go ahead with the rebuild with m54b30 internals , it sounds so tempting, and i do want better performance.
also do you think it could be done in about a month.
Old 11-06-2013, 09:54 AM
jkmeisl's Avatar
Josh
could be done in a weekend with a few buddys, but honestly just take your time, a month is a good time frame if you have money in the bank and all the parts bought and ready to go. and you hit very few bumps in the road.
Old 11-06-2013, 11:37 AM
Mein Auto: 97'328is
yeah im hoping to get all the parts before christmas ,when i finish my first semester we have a month of vacation so will take my time to do it properly.
Awsome build miles..........
Old 11-06-2013, 01:41 PM
I like pie.
Thanks. Definitely get all the parts before you do anything stupid like yanking the engine out. I wasted a lot of time and money by jumping the gun and pulling the engine before I'd bought all the little stuff.
Old 11-06-2013, 01:44 PM
dc_wright's Avatar
Roger that. I didn't have time to look up if they did the deck height correction with shorter rods, moving the wrist pin location on the piston, or changing the overall piston height.
First stroker engine I did many years ago was a 1600cc air cooled VW. I had the deck height all worked out and thought it was going to be clear sailing...............until I discovered the piston skirt interference at the bottom of the stroke when I put everything together.
Old 11-09-2013, 01:42 PM
Mein Auto: 97'328is
just have a couple questions, what maf sensor did you use and how much more power did you actually make, could you really feel the diffrerence, and was it worth the trouble.
also can i run another maf sensor on a stock 328i, cause mine is not working?
Old 11-09-2013, 02:19 PM
I like pie.
I used an MAF from an OBDI 740, you'll probably want one from an OBDII 540/740. As for power, I could have gotten more with a better tune and if the head gasked had seated properly (fixing that now), but it was definitely a big jump from stock.
Old 11-18-2013, 09:36 AM
Mein Auto: 97'328is
still waiting for my compression tester, but yesterday i asked a couple guys what they did ti their engines and they recommended i swap my block for a 3.0l block cause it costs around the same, would you guys recommend this
Old 11-18-2013, 09:43 AM
jkmeisl's Avatar
Josh
if you have the money sure. the 2.8 block is bore of 83.94 mm iirc and the 3.0 block is 86.xx mm iirc if you get the euro 3.0 its like 286 hp. thats gunna be way more power then a 2.8 stroker
Old 11-18-2013, 10:57 AM
Mein Auto: 97'328is
well here its the same price to do a stroker or get the block, but im going to be putting the 328 head on which is what is worrying me, will it be a perfect fit?
Old 11-18-2013, 11:13 AM
jkmeisl's Avatar
Josh
it will fit
Old 11-18-2013, 11:22 AM
Mein Auto: 97'328is
it will fit
thank you definitely going for the 3.ol then.
Old 11-18-2013, 02:29 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Wait, I don't think the M52B28 head will fit on the S50B30 Euro engine. The Euro S50 was a dual VANOS, etc., whereas the M52B28 was single VANOS. There are probably numerous other reasons why a 2.8L head won't work on the Euro 3.0L engine, too, including bore.
1998 BMW 328is
1966 Pontiac GTO
Old 12-07-2013, 12:52 PM
Mein Auto: 97'328is
so my compression tester finally arrived. and............
c#1--135psi--140psi
c#2--150psi--150psi
c#3--150psi--160psi
c#4--150psi--155psi
c#5--150psi--150psi
c#6--150psi--150psi
they seem pretty low specially that i was expecting them to be in the 200s
but that is reasonable since the car really really feels underpowered you just dont know how much,,,,,,,,,,i gave my friend a lift the other day and he asked whether it was a 318 or 320.
here are some spark plug pics they dont look right, why do they look like this.
Old 12-07-2013, 01:04 PM
hornhospital's Avatar
D'oh, You Kids!
Good Lord, man, change those plugs! They are all carboned up. I'll bet you notice a huge power improvement immediately. And run some Sea Foam through the engine. Gah! I hate to think what the valves look like.
Quotes to live by:
Old 12-07-2013, 01:15 PM
ZeGerman's Avatar
Warm Leatherette
Yikes, yeah, those plugs are nasty. How long were they in for? Anyway, here is a guide describing various plug scenarios:
1998 BMW 328is
1966 Pontiac GTO
