Old 11-02-2013, 06:40 AM
lanre10 lanre10 is offline
Mein Auto: 320d
Wink 320d short down
Hi guys,
My 320d coupe, has been shorting down completly when it's parked, for the past three weeksand then comes back on by itself 3 to 4 days later. This has happen exactly a week intervals from each incident.
I cannot even open the door with the forb, I have to pull out the key from the forb. No lights at all.
Any advise will be very much appreciated.
Lanre
Old 11-03-2013, 05:47 AM
Mein Auto: '06 AW 330xi
There was a battery cable recall for this positive cable terminal connection at the fuse panel
Call you dealer and see if your vin falls under this recall.
The symptoms you describe sound similar to that of the recall.
