Old 11-02-2013, 10:31 AM
jlsbimmer jlsbimmer is offline
Mein Auto: 325
Undercarriage Noise - oil change ?
Hi, all , E90 2006 330i owner here .. with some tire noise issues ..
Q) Is it possible that during my last oil change that the mechanic forgot to close something up in the Undercarriage area ?
Reason I ask, is that there seems to be a LOT of noise coming from the tires.. I have been living with this for 2 months now ,, and was just assuming my tires had suddenly gotten way noisier (Goodyear F1 all season).
But now that I think of it , something could have been messed with during my last oil change.
Any ideas out there ? I don't think I can prop up the car to see if there is something amiss.
thanks all !
Old 11-02-2013, 11:25 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Any ideas out there ? I don't think I can prop up the car to see if there is something amiss.!
Take it up. Have a look beneath....take a pic....post here!
Old 11-02-2013, 12:36 PM
Mein Auto: 325
I am not able to get a good look under there .. don't have any way of hoisting the car up high enough.
Does anything have to be removed underneath to do a simple oil change ?
Old 11-02-2013, 01:58 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
A little cute trap door is flipped open to access to oil drain plug. This is removed to drain the oil, and then it is reinstalled (best at a specific torque, but many do that finger tight method) with a new crush washer. Short answer: no. (I mean if you were missing a drain plug, you would know in a hurry!)
If you can't access the views underneath, you really only have one option... take it to your local indy for an inspection. If you're paying that small half hr fee and they only look around for a couple of minutes, might as well get your money's worth, ask a few questions, maybe ask their opinion on the state of the suspension, take a few pics, I dunno...
Old 11-02-2013, 04:36 PM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Just look under & see if the drain door is open. It would flap in the wind if not secure. No need to raise the car to look.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 11-02-2013, 05:52 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
tires do get nosier as they wear off, check your tire pressures as well.
Old 11-02-2013, 07:56 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
thanks all !
I can't see any possible connection to an oil change and "sudden" increase in tire noise. You're really stretching things IMO.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 11-03-2013, 07:24 AM
R1200 R1200 is offline
Mein Auto: 328XiT and R1200C
I too doubt that an oil change would cause new noises under the car. The plastic shrouds under the car are held in place by a lot of small screws and missing a few of these would create a vibration at speed of the plastic shroud. Reach under and tap various areas to see if anything is loose.
You may have developed tread separation in one tire totally unrelated to the oil change but at the same timing. Have it checked by a tire shop. I recently had a strip of tread rip off a tire which was pretty scary at highway speed. It's worth checking for separation as it not just a problem of the past.
Don
328XiT Sonora
Old 11-03-2013, 01:51 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Rip the plastic under carriage off... Engine gets cooler, noise will go away, easier to do oil chnage next time around
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 11-03-2013, 02:42 PM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Monacoblau mit beige
Mein Auto: E92 330i Manual
A flood did that for me last year on my 328. The engine bay was filthy with dust in the summer, but otherwise
330i SE coupé
Manual - N52K 262hp, 232ft-lb
