Old 11-03-2013, 04:19 AM
Spionkop18 Spionkop18 is offline
Mein Auto: E93 3251 convertible
Ticking nose when started from cold??
Hi all. When I started my 2008 325i this morning it was making a ticking nose in the engine bay. It also sounding a bit like a diesel car. Any ideas as I haven't had a BMW before so worried ?? Any help would be good
Old 11-03-2013, 04:23 AM
bmwoem1 bmwoem1 is online now
Past Sponsor
Mein Auto: X3
Sounds like lifters, it's a very common issue with the N52/N52k engine
Old 11-03-2013, 04:27 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
THIS SITE has a distillation of the problem.....
Old 11-03-2013, 07:47 AM
B/\/\W's Avatar
B/\/\W B/\/\W is offline
Monacoblau mit beige
Mein Auto: E92 330i Manual
This is caused by "insufficient air-free oil reaching the hydraulic valve adjusters". Basically it is caused by short journeys. There is a "bleeding" procedure that BMW came up with if you can't put up with the noise.
It isn't a problem and doesn't cause damage to the engine, even if it is annoying. It appears usually after 50k miles has been covered.
Reports suggest the problem is cured by replacing some parts, but others that this doesn't even solve it.
330i SE coupé
Manual - N52K 262hp, 232ft-lb
Old 11-03-2013, 08:04 AM
Ok. I am haveing the car serviced nxt wk is there a oil I can use that would help this prob?. All so noticed a taping noise when pulling off it makes the sort off noise than the car makes when u pull off in a to high a gear but dose it on any gear high or low. ?
Old 11-03-2013, 08:14 AM
B/\/\W's Avatar
Stick with what BMW recommends for oil. If anything, the recommended Castrol oil which is relatively thin, 5W-30, would be better anyway because it would more easily spray around at lower oil pump pressure. I can't imagine the noise you mean, not sure how the noise of an engine straining is a tapping noise.
How many miles on the car?
P.S. What football team do you support? I noticed your name Spion Kop...
330i SE coupé
Old 11-03-2013, 03:01 PM
Mein Auto: '06 AW 330xi
The only way to permanently get rid of the ticking is to replace the engine head with the updated part number or drive for longer distances.
The new head incorporates a check valve to maintain oil pressure when then engine is off. This prevents the lifters from ticking on start up.
If you drive longer distances, the engine will return to normal.
