Old 11-03-2013, 07:23 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
Can I run OEM staggered wheels on a 325xi?
Hey all,
I'm looking into picking up some style 162's for my 325xi because my current wheels have brand new snow tires on them and I don't feel like changing them over because i'm not fond of them anyways.
So I took to the internetz and found some 162's and then realized they come staggered. I learned, while working as a technician for Subaru that different sized tires on an AWD system will make quick work of smoking the center diff/ t-case, or so I thought.
I know that the all wheel drive system on the E90 is essentially just a glorified 4x4 type of system with open diffs front and rear with a non selectable range t-case right off of the transmission. Since there's really no viscous coupler or center diff in the BMW, this would make running staggered wheels okay, right? In any case as long as the sidewall heights were the same there'd be no difference in rotational speed and the system would be unaffected.
If anyone knows for sure, or is running staggered wheels on an xi/x-drive with input i'd love to hear it.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 11-03-2013, 07:43 AM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
162s were a factory option for my car & been running fine for 52k.
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
Old 11-03-2013, 07:58 AM
Mein Auto: '06 AW 330xi
Rolling diameter of the front and rear wheels needs to be within 1% of each other.
Old 11-03-2013, 10:02 AM
Kdoherty's Avatar
Excellent, thank you both
keeping the diameter should be as simple as having the same aspect ratios front and rear and i can always just go to the owners manual and find the stock tire size.
  • '06 325xi 6MT
Old 11-03-2013, 11:59 AM
Norm37 Norm37 is offline
Mein Auto: Chevy half ton pickup
The aspect ratio will be different front and rear on a set of staggered tires.
Tire Calculator.
http://www.discounttire.com/dtcs/infoTireMath.dos
The owners manual is your best bet.
Old 11-03-2013, 12:20 PM
Kdoherty's Avatar
Tire Calculator.
yeah the owners manual says that the 325/330xi can run 225/40/18 front and 255/35/18 rear. That's probably the way i'm going to go.
  • '06 325xi 6MT
