Old 11-04-2013, 08:50 AM
Banned
Mein Auto: 2007-335 HTC
2007 335I ABS Module rplaced, now new lights
I had my ABS Module replaced last week and this morning my Brake light came on in Yellow
a yellow triangle with a circle around it came on and round circle with half moons on each side came on, after I restarted the car they came back on and then went off,
got to read the codes after work but appears to have to do with the traction control and the anti roll back
why is it you take your car in for one problem and then more lights come
smells fishy to me
Old 11-04-2013, 11:00 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
I think the DSC hydro unit needs coding? That may be why you're having issues.
Old 11-04-2013, 11:04 AM
fun2drive's Avatar
BMWCCA 149159
Dealer should have done that for him and he was code free for a couple weeks.
Got to be something else unless the new unit is failing already which doesn't make sense...
Old 11-04-2013, 12:42 PM
Banned
Well the BMW place installed the unit so I doubt thats the issue
plus the Baverian tech tool says, Steering angle sensor so I recalibrated it and cleared the codes so we shall see what happens
Old 11-05-2013, 08:34 AM
Banned
well the steering angle sensor light came back on so the car is at the BMW place getting the sensor replaced and covered by my extended warranty plus they gave me a new 328d to drive
Old 11-06-2013, 02:31 AM
Banned
Well Car is back, so new ABS unit and New steering wheel angle sensor, calibrated and coded and programed
hopefully that should cover it for a while, unless the wheel speed sensors decide to quit working
so about 2500 worth of work and only cost me 100 dollars in deductible for the Extended warranty
too bad both part didnt go out at the same time it would have only been a 50 dollar deductible
Old 11-06-2013, 05:11 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
smells fishy to me
YOW! Another day at the dealer? You must click on pic - decide who gets that.
