Injectors - Page 2 - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 12-22-2013, 03:15 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Soon after swapping to M50 injectors, my car wouldn't idle in D and was surging in P, but ran like a champ above idle. It felt like I had a massive vacuum leak, but I had to drive her to work and back, and in a few days, the issue had resolved itself. She idles great now.
Robert at E30 MotorWerks clued me in to the fact that the OE M20B25 injectors are 14.5lb. It takes the DME 75 miles or so to adjust / calibrate to the M50 units.
HTH.
Old 05-05-2014, 11:54 PM
cmac2012's Avatar
cmac2012 cmac2012 is offline
Renaissance Dude
Mein Auto: '87 325i, '86 MB300SDL
Originally Posted by markseven View Post
cmac, sorry to hijack your thread, but this is crazy. I don't know how my old injectors were flowing anything but maybe a dribble of gas.
Finally got around to swapping in the new/rebuilt M50 greenies. My blue tops looked similar to yours but not quite as bad.
Sweet Jesus. If there was some learning going on in the DME, I wasn't aware of it. I felt the extra zippiness right out of the gate and on two fill ups I've gotten a bit more than 23.5 mpg. Never got that high before. Was usually 21 to 22. Not a giant improvement but I will take it with a big smile on my face.
Thank you MEPEH. You put out a fine product. I should have done this years ago.
Old 07-14-2015, 04:56 AM
mojorojo mojorojo is offline
Mein Auto: 325i
Originally Posted by MEPEH View Post
I'll chime in
First of all, i'll tell you about the challenge of accurately testing an injector. There are hundreds of companies that test/refurb injectors and they all use different equipment and testing fluids.
I use an environmentally friendly degreaser just because i don't feel like using dangerous chemicals in my home garage, But others use other fluids and all these fluids are different from real gas. Even the gas at the pump will have different fluidity in different parts of the world
So the same injector will show different results tested with different fluids. That's why the manufacturer suggests that your 6 injectors should flow equally with a 2% error margin. They also suggest the flow rate but it's just a guidance.
It is important to have balanced injectors and less important to have that flow rate exactly as mentioned by the manufacturer
Both M20 and M50 injectors are considered 17 pound injector.. it's about 160 cc/min. In real life you will have somewhere between 150cc/min to 170 cc/min. That's why we flow match to get a set of 6 injectors that are within 2% of each other (per mfg recommendations)
The difference is the spray pattern and since M50 injectors have better atomization (they mix air with fuel better in the chamber) you will get bigger explosions and more energy generated from the same mix of fuel/air.
What matters to your engines is keeping the stock Air Fuel Ratio in a stock configuration. Since vehicles operate at different altitude and use different fuels, the DME is able to tune the ignition to maintain a stable AFR
I don't remember precisely, but it can adjust about 2-5%
I test injectors in pulse mode and i can see how challenging it is for a DME to maintain the same flow rate on 6 injectors under different RPMs .. needle type injectors especially (M20 blue tops or ETA gray tops)
M50 injectors do a way better job at keeping a stable flow rate in different modes. I test them at way above your car's RPMs sometimes just to see how well they perform and Green Top M50 injectors are just superior.
I scrap about 20 injectors a week and a lot of times i put them to stress test... FOR FUN
I run them at 7-8 of fuel pressure at 10k RPM to see where and what injectors will fail... and i'll tell you that the stock M20 injectors are just Sad to watch, especially the ETA gray tops.. those are like watching 80 yo old grandpa racing on a sport bike in the canyons
And lastly.. experience... I've sold over 1000 injectors last year just for this upgrade. Shipped all over the world to people with M20 engines that wanted the M50 injectors. There are people running this upgrade at different altitudes and different climates
I've had 0 complains so far and 0 issues testing emissions on any of those cars.
If any of you purchase this upgrade from me and feel that you are not satisfied with the results, i will exchange that set for a stock rebuilt M20 set without charging you any extra. I used to remind people about it all the time, but stopped doing it because everyone seems happy with the upgrade.
Here's one of the latest reviews about this upgrade
http://www.r3vlimited.com/board/show...&postcount=240
I had a request for a set of 6 stock M20 715 blue top injectors this weekend and i knew i had 12 of those and was confident that i could pick 6 good ones out of 12..
Well, i scraped 10 injectors and was able to keep only 2 out of 12 that i had. Failure rate is just ridiculous on those, especially if the car has been sitting for over 2-3 months
Do you sell the M50s already refurbished orr ... B/c I have the M20 engine & my #4 cylinder injector is totally out & at the shop its now theyre quoting astronomical prices . If this is an opportunity for me to upgrade to M50 injectors Im totally open to the idea
Old 07-16-2015, 12:50 PM
MEPEH MEPEH is offline
Mein Auto: M3
Yes, here's the link for single pieces
http://www.mepeh.com/one-rebuild-bmw...641730060.html
And this is for the set
http://www.mepeh.com/6-rebuild-bmw-m...641730060.html
Get your Injectors Cleaned HERE
Old 07-16-2015, 03:35 PM
Mein Auto: 325i
Thank You very much
Old 11-08-2015, 04:11 PM
cmac2012's Avatar
Renaissance Dude
Does make you wonder. Check out some of these original blues I just pulled out of my 2nd car:
Bentley refers to a BMW part - an injector solvent additive that is recommenced for occasional use. Could be one of the aftermarket blends would be just as good at a lower price. Mght have to look into that for regular usage.
If I need to renew the intake manifold gaskets in this car in about 100K as I did in my first car, I think I'll take the opportunity to put in refurbished injectors then as well. Would be easy with the manifold out of the way. Tricky with it in place though I did emerge victorious.
I passed smog a few weeks back - barely - with a CAT that was 4 years old (every two years you have to smog in Cal). I was only getting two years on the Chinese cheapies (false economy). That I will more than likely get six years from a more quality unit (the cheap ones are illegal now) is nice, I suspect the green injectors had something to do with the most recent pass.
