Old 11-04-2013, 02:10 PM
prancingman prancingman is offline
Mein Auto: 2006 325i
Windshield Cowl Causing Leak
I have a 2006 325i. I got my windshield replaced through Safelite a couple months ago. It is leaking in the passenger footwell when it rains and when I go through a car wash. After reading through thread after a thread, a common theme I saw was an issue with water leaking into the car when it rained, after having replaced the windshield with aftermarket glass. After running plenty of experiments, I have isolated the problem to the windshield cowl. Compared to other cars, my cowl is extremely loose. In fact, I can pretty much lift the cowl up and look inside to the base of my windshield; because the cowl is so loose, water is getting underneath the cowl and from there it is leaking into the passenger footwell. Every car that I have looked at seems like the cowl is sealed to the windshield. So as a test. I duct taped my cowl to my windshield and ran water on it. Sure enough, it didn't leak. I took the duct tape off and ran water on it, but this time it did leak (as expected) Is the Cowl itself supposed to be sealed to the windshield? Is this Safelite's fault, or do I just need a new cowl? I'm trying to avoid going to a dealership, but I just want my car fixed correctly, as this has been a problem since I first got my car.
ID:	405775   Click image for larger version
ID:	405776   Click image for larger version
Old 11-04-2013, 02:13 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
the cowling doesnt have anything to do with water going in. its not sealed to the glass.
more likely is that there is a bad seal at the bottom of the windshield, the water is getting in past that. the windshield is glued along its perimeter to the frame of the car with urethane sealant. if thats not applied properly, then you'll get water in.
taping the cowling just blocked the water from getting to the faulty seal. take it back to safelite, they should fix for free. they may need to remove and reseal.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 11-04-2013, 02:24 PM
Important note: My windshield originally got replaced a little less than a year ago by Glass Doctor. My car started leaking on the driver's side and a local mechanic said it was the windshield. So glass doctor replaced it for free again and the leak on the driver's side stopped. A month or two later, my car started to leak on the passenger side. After a few months, we just decided to get it replaced by Safelite this past summer, but the leak on the passenger side remains.
Old 11-04-2013, 03:09 PM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
Car ever been in an accident?
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 11-04-2013, 03:40 PM
Not to my knowledge, no. Record was clean when I bought it.
Old 11-05-2013, 06:49 AM
Mein Auto: '06 AW 330xi
This is a common problem on early build e90s. There was a service bulletin released pertaining to this issue. Though this is not an issue with windshield replacement, rather defective cowl or missing trim along the bottom edge of the windshield glass.
On my car, the strip that sits along the bottom edge of the windshield was missing. The cowl snaps into this trim and this is how the pressure is created to seal the cowl to the glass.
Many windshield companies forget to reinstall this trim and that's why your cowl is leaking.
The area under the cowl is exposed to the cabin and water can indeed drip into the footwell. It's also common for the water to drop onto the AC blower motor, rusting the bearings, and eventually seizing/failing.
Old 11-05-2013, 03:13 PM
Any way to find this service bulletin? And can you describe what the piece is that the cowl snaps into that might have gotten left out of the repair? I want to be as informed as possible before I go back to Safelite/BMW. I need some way to prove that it was Safelite's fault.
Old 11-05-2013, 07:54 PM
Any dealer can look up the TSB. I used to have a link to it but bmwtis doesn't allow hotlinking anymore.
It's part #9
Went to double check the part # on ecs so here's the link
http://www.ecstuning.com/Search/Site...33292/ES78180/
Old 11-06-2013, 04:58 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
DUDE! One word to live by: SILICONE
Yes. Versatile and available in many flavors, SILICONE is today's cure for most ills.
But since you asked, HERE
Old 11-06-2013, 06:20 AM
I've already picked up some silicone for the job, I'm just holding off until a windshield expert looks at it. I'm taking it in to get it looked at by someone who isn't Safelite or the dealership. If it turns out to be a faulty windshield job, I'm going to try and squeeze a new A/C blower motor out of them too, since they're liable for any damage to the car.
Old 11-06-2013, 06:22 AM
It's part #9
I think that piece is missing. I think Safelite should be held liable for not replacing that seal, but I'm taking it to get a professional opinion today. I'll let you know how that goes.
Old 11-06-2013, 06:32 AM
Don't use silicone. Yea it will work perfectly when it's dry! But drying takes at least 12 hours, full cure another 12-24 hours.
You have to apply pressure that whole time. Most likely wont be able to use the car while its drying.
The trim is $9.
I understand this isn't something you should have to deal with, and I agree, safelite should have known to swap this peice over, but I would just bite the bullet and install it yourself.
Old 11-06-2013, 07:10 AM
jayb328i jayb328i is offline
Mein Auto: 328i
Are you sure it is the cowl. That would not be possible in may year 328i. I have changed them and the cowl sites on top of the window glass and the metal car frame that supports the wipers. It does not in anyway waterproof, or prevent water. Even when it is tight in place, it is not water tight and water just run under it onto the windshield. But if the windshield is not sealed properly--that is where the leak is, not the cowl (in cars I have seen)
Old 11-06-2013, 07:15 AM
We're referring to the cowl cover, not the cowl itself. You are most likely referring to the micro filter. The cover sits above the AC blower motor which is basically a large vent into the cabin, through the firewall. That's where water goes in.
If your cowl cover is lifted and not tightly sitting against the glass, it's not doing its job.
Like I said, this was common on early build e90s. My car had the trim missing from the factory...
Old 11-06-2013, 08:02 AM
The trim is $9.
Good news! Permatex Flowable Silicone, recommended to seal windshields, requires no pressure to be applied. Simply squeeze in on whereupon it flows into voids; wait 24 hr for full cure.
Done! But there IS a cost....massive cost, I'm afraid....$3.25
Old 11-06-2013, 08:54 AM
It's not really about costs. It's about repairing the issue correctly.
Why use silicone when you can fix the issue with the oem parts for cheap? Maybe 30 minutes of labor and no worry about drying times or whether or not you fully sealed the cover to the glass.
Silicone may also have a difficult time adhering to the rubber seal that meets the glass on the cover. And with a 1/2" or so gap like that, alot of silicone will need to be used. Something will also need to be placed under the cover so the silicone doesn't droop into the cabin.
Old 11-06-2013, 09:19 AM
ehawes1 ehawes1 is offline
I too am having this issue. Replaced a blower motor about a month ago. No rain since so have bought myself a little time. With the cold season upon us in the South I must fix mine ASAP! I don't need water in there freezing and thawing everyday.
Fdriller9-I'm not sure if it is referred to as the "cowl" but the plastic piece that sits on the windshield under the wipers on my 2006 325i is also just slightly lifted off the glass so it isn't sealed. What part exactly do I need to fix this? I am confident that as said above 30 minutes and a DIY will get this done correctly.
Old 11-06-2013, 12:01 PM
Well, I would do it myself, but I'm not sure exactly how I'm supposed to do it. Also, if it's safelite's fault, then they are responsible for my A/C motor blower failing as well (when it does) and need to pay for that replacement too. I'm not trying to freeload off them, I'm just trying to get my car fixed in one swoop
Old 11-06-2013, 12:03 PM
I posted the link to the part above. It's #9 in the diagram. Link to the part is below the diagram. It's like $10
Check if it's missing first. You may just need to clip it back on.
Also make sure the cowl cover is not warped. That will also prevent a proper seal.
BMW refers to it as a "cover, windshield"
Part # 13
http://realoem.com/bmw/showparts.do?...40&hg=51&fg=20
Old 11-06-2013, 08:32 PM
Whasis? We speak of OEM parts already installed, but there's leakage, somewhere along the line.
So, seal it! No worries.
Otherwise we must remove the windshield & replace OEM parts....another thing altogether....
Old 11-06-2013, 08:33 PM
Hey don't be shy - let us know how that turns out....
Old 11-07-2013, 04:18 AM
Windshield doesn't need to be removed.
All you do is remove the microfilter, then the cowl, then the cowl cover can come off, then you just slip the trim peice on the bottom edge of the glass, and reinstall everything.
Old 11-07-2013, 04:37 AM
I'm all for DIY, but because my A/C blower is probably rusting because of the leak, I want all of it done in a shop. I took my car to my mechanic yesterday and he agreed that the cowl was just installed incorrectly. So, I'm taking my car back to him on Monday and Safelite is sending the service technician that replaced my windshield out there to confirm that the leak is their fault. Safelite vs. Local Mechanic, everyone keep their fingers crossed for the mechanic.
Old 11-10-2013, 10:49 AM
Video evidence?
I took my microfilter off today so I could see how the leak happens. I recorded this video:
I apologize for the poor filming. See what you guys think
Old 11-10-2013, 01:05 PM
Mein Auto: 328i
You got a big problem. I would remove all that I could around the cabin filter housing, and the housing--and get you BLACK caulk out and seal everything. Especially look for openings in the fire wall.
I would first, however, see from inside the car if you can see if the leak is coming through the filter channel housing---do the same from the hood side. If that is the case, may need to creat a new opening on bottom of filter area to allow water to get out, and use caulking to channel a path out for the water.
windshield cowl leak 2006 325i
