What is this knocking noise? - Bimmerfest - BMW Forums
Old 11-04-2013, 05:52 PM
wildcattc wildcattc is offline
Mein Auto: 740i
All,
I am a little anxious about an odd knocking noise that has just started from my engine. Here is a link to the audio https://www.dropbox.com/s/zy0insojxpq55m6/BMW.m4a the audio starts in the engine bay, then moves to the passenger wheel well, then finally in the interior with door open.
I am fairly adept at mechanical work, but I am new to BMW's.
Thanks for all of your help.
1997 740i with 153k. I am unaware of any history.
Thanks!_a_
Old 11-05-2013, 06:35 AM
ou18 ou18 is offline
Playing Mechanic At Home
Send a message via AIM to ou18 Send a message via Yahoo to ou18
Mein Auto: 1997 740 IL
IT COULD be your timing chain guides failing....
easiest way to see if it is, drop your lower oil pan and look for bits of plastic in it. Also check the oil pump screen, need a pick to get around in there, I pulled chunks out of mine, If you have bits of plastic in the oil, dont drive your car anymore, you could do alot more damage as your timing will get out of whack and cause bigger problems..
You have the m62 non vanos engine in there similar to mine...I had a similar noise. I had found plastic bits in my lower oil pan...Will be a tell tale sign of failing timing guides...
here is a link to a video of what the timing guides sound like when they start going bad, sounds similar. Does the noise speed up when you step on the accelerator...
1997 Black 740IL (w\ badass Phone in console)
Old 11-05-2013, 12:06 PM
FABOCH's Avatar
FABOCH FABOCH is offline
Mein Auto: 2000 BMW 740I SPORT
That's clearly Vanos
2000 740i Sport , Alpina 21`, Alpina Lip, Alpina Deco kit,Dinan 7,Dinan TB, DINAN CAI, DINAN Exhaust, Dinan Stage 5, Dinan 4/5 transmission, Dinan manifold, Highline individual interior,Eibach/Bilstein,Zimmerman Timing guides 08/13
Old 11-05-2013, 12:23 PM
Faboch, he has the same engine as I do, which did not have vanos, or are you saying vanos as a catch all for timing chain guides, etc etc?
Please educate me...
Old 11-05-2013, 12:26 PM
FABOCH's Avatar
oh my bad,
Old 11-05-2013, 12:27 PM
FABOCH's Avatar
1 time i had a tapping sound like that and re checked the torque of my spark plugs and 2 were loose.....Tighten them and tapping sound was gone
Old 11-05-2013, 12:46 PM
I thought for a second maybe i was going crazy with my terminology... lol...
Well wild, based on FABOCHs latest post, i would check those spark plugs first, doesnt cost you anything, which is the best fix of them all..
If that isnt it, check that oil for broken bits...
Old 11-05-2013, 12:51 PM
Mein Auto: 740i
Thanks a lot for the information. I will look into all of those things. BTW, here is a pic.
Old 11-05-2013, 12:59 PM
Nice, looks like mine, just shorter and different rims.
HTML code is Off
