Old 11-04-2013, 07:22 PM
Bigrob126's Avatar
Bigrob126 Bigrob126 is offline
Mein Auto: 2010 328i Coupe Auto
I'm a little confused....
Did an oil change today. Had the front Wheels on ramps, as I've seen in some DIYs. Drained all the oil and changed the filter. The car sat about an hour before I drained it. I only put in 6 & 1/3 quarts of oil in the hopes of having the oil level show less than MAX on the computer readout, so I could get the level exactly where I would want it. Upon completion, I came to find the oil level still showing at MAX? Did all the oil not drain out because of the front being elevated? Or might my oil indicator be bad?
Rob
Old 11-04-2013, 10:43 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
very likely
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 11-04-2013, 11:13 PM
Bigrob126's Avatar
Also....I'm not sure how sensitive the oil level indicator is because this is the 3rd oil change, and it has always shown exactly at the max line, being this last one doing myself with a little less oil. I read somewhere it may take a little time for the indicator to adjust. I only warmed up the car enough to get a reading then parked it. Maybe in the morning I may get a different reading? We shall see.......I want a ----ing dipstick!!
Rob
Old 11-04-2013, 11:17 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
There was a thread here back when talking about how the "indents" work but I can't recall the details. I wouldn't sweat it man. Maybe you'll only need to burn a few drops of oil for the indicator to decide to go to the lower indent. FWIW, I think my last two (and I should also say my first two) DIY changes I only put in 6.0 quarts, and I think it was right where it should be... however some months later I'd have to fill her up with say half a bottle. I'm not sure I ever had to do that with dealership oil changes, but I'm not 100% sure. Age, coincidence, I dunno, but I wouldn't sweat it man.
Old 11-05-2013, 04:32 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
A tip for next time you change the oil Bigrob - don't leave the car for an hour before you drain. Get the engine nice and hot, then drain straight away. The oil will flow much better and ensure as much of the old oil leaves the engine as possible.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 11-05-2013, 05:25 AM
2002-530I 2002-530I is offline
Mein Auto: 2002 BMW 530I Sport
Your worrying WAY too much! Max just means don't add more. Your fine.
Old 11-05-2013, 05:56 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
I think Max is within a half quart, so if you put in 2/3 less than full and there is some left in there, you are close enough to full to indicate full still.
Just drain it well and put in exactly what they call for and you should have no issues.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 11-05-2013, 07:38 AM
Illeagle Illeagle is offline
Mein Auto: e 90
I checked my car same day as well and it was showing empty after the oil change. Two days later it showed max level so I assume it takes some time for the sensor to adjust. Just my .02 cents....
Old 11-05-2013, 10:42 AM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is online now
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
I think the sensor is a "close enough for government work" especially since it only functions with the motor running & oil is suspended in the engine, not all in the pan. The oil will drain on ramps, the plug is at the back of the pan. Filling to spec if you change the filter will no overfill the pan. As was mentioned above change the oil as soon as you shut down to keep the crap in suspension. No point in changing it after all the particulate matter has settled to the bottom of the oil pan.
BTW if you are really really worried about it measure what you take out & if the sensor had been tripped for an oil add you know you can put a bit more back in than came out.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 11-05-2013, 01:22 PM
Bigrob126's Avatar
At least I know it's not overfilled cause I did it! So for that I feel a lot better! Thanks gentelmen!!
Rob
Old 11-05-2013, 02:06 PM
SilverX3's Avatar
don't worry be happy
get some Yoga lessons
stop worrying
Job - Captain
MY11.5 X1 Xdrive25i
