Suspension? - Bimmerfest - BMW Forums
Old 11-04-2013, 07:57 PM
jaj015 jaj015 is offline
Mein Auto: 335i
Suspension?
What is the best setup for the E90?
I hate the way my stock 2011 335i looks with the big wheel gaps.
Thoughts?
Old 11-04-2013, 09:56 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Thoughts?
One: Wheel gap is a pointless concern. Maybe you should trade for a low rider.
What should concern you is performance - stock 335i w/Sport suspension is a pale imitation of what can be. Drive a M3 - same car, diff suspension & differential. Diff engine too, but that's not the point. You'll see.
If you want to mod for performance, I can get your feet wet. If your concern is cosmetic, well, lots of lowering data in the E90POST suspension forum.
Old 11-05-2013, 04:34 PM
Mein Auto: 335i
You said you can help get my feet wet. There is so much data out there I am on overload. Over the next 6 months, I'd like to tune, DCI (bms), new suspension and wheels.
Thoughts on the above?
Old 11-05-2013, 07:11 PM
Yeah, pretty conventional....chip's good, DCI not useful on the street. Most do shocks & springs first - I do LSD before that. Except M3, all models of 3 are much in need of more!
Rubber bushings gotta go - need M3 parts
Iron arms gotta go - need M3 parts
Rear subframe bushings gotta go - Need M3 parts
Front camber should be increased - need camber plates
If you're planning to DIY, check the suspension section at E90POST - HERE's my contribution.
Old 11-05-2013, 07:41 PM
Mein Auto: 335i
That's a fantastic setup & DIY post you've written.
I'm inclined to do the suspension first. Where did you buy your parts from?
Do you have a list of everything that should be replaced?
Appreciate all your feedback
PS,
Why is the DCI worthless for the daily driver?
Old 11-05-2013, 07:45 PM
Mein Auto: 335i
Wheel setup-
Is there a one stop soho where someone can help me with a wheel & tire setup?
Old 11-05-2013, 09:28 PM
PS,
DCI adds no real power [street use] & stock's pretty good; reputed better at cleaning air. Vendors are linked in my DIY. You'll find HP Autowerks and Ground Control were my main suppliers - Sears for tools 'cause they're handy were I am.
Scroll through the DIY for parts list. It's fairly complete. Basically: All arms replaced w/M part equiv. Subframe bushings replaced w/M bushings. Shocks/springs spec'd by Ground Control. Couple o'sources for rear toe arms. Street/School kit packages many needed items. You needn't do the front tower brace - strictly elective. LSD by Wavetrac; installed by local speed shop. Sways are now M but if you're going with high rate rear shocks, may not have rear sway. Talk to Jay at Ground Control.
Old 11-05-2013, 09:31 PM
Wheel setup-
I use Michelin PSS on stock 18" alloy. Unlike nearly all 3rd party stuff, BMW wheels are rated to 150 mph, as are PSS's. Stagger a la Sport option for optimum handling.
