Old 11-05-2013, 04:54 PM
Kael193 Kael193 is offline
Mein Auto: 325i
My radio doesn't work in my 325i 2006
I check all fuses and everything is ok, but the radio doesn't work
Old 11-14-2013, 08:51 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest! I moved your thread over to the E9x forum which I believe is the right chassis code for your car. I believe there is a fuse on the back of the head unit itself and perhaps on the amp in the trunk. Have you checked those? Have you tried searching around for other threads about the same problem to see if you can find someone else who had the same issue and their solution?
Tim
Old 11-14-2013, 12:39 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Is it no sound or dead display.
You are more likely to find answers to audio questions
here.
http://www.e90post.com/forums/forumdisplay.php?f=27
Have you checked the amp if you have a display and no sound.
A common thing that happens is the amp gets wet.
Also it would be good to know if you have idrive or a pro radio and
if you have the hi fi system or logic 7.
Plus options such as bluetooth , SOS or PDC that are attached to the radio or
idrive.
