Old 11-06-2013, 09:48 AM
maxpower32 maxpower32 is offline
Mein Auto: bmw x3 e83
bmw x3 e83
bmw wont start have changed grow plugs checked glow plug control .changed fuel filter still not firing up just turning over can any one help
Old 11-06-2013, 09:58 AM
joylove joylove is offline
Mein Auto: 08 e83 LCI
Need more info.
Did you break it? Did you run out of fuel? Was it running rough? Any fault codes stored? Is the fuel pump running? Did you put in petrol or veg oil?
Old 11-06-2013, 10:02 AM
only one code it for fuel pressure only ever put deisel in.and never run out of fuel
Old 11-06-2013, 10:16 AM
If you clear the fuel pressure code, does it come back?
Old 11-06-2013, 07:05 PM
Alex72 Alex72 is offline
Mein Auto: X3 bmw
Smile Rear Wiper arm removal
Success at last came when I took apart the new replacement arm to understand how the broken one needed to be removed. Most helpful reply was to turn wiper motor on and stop when arm was in most upright / 12 o'clock position. With nut and washer removed, I was able to gently pull arm down and it popped off the shaft when spring tension was released. I'm sure the WD40 helped too.
Windscreen intact!:
Old 11-07-2013, 01:05 PM
can0n4 can0n4 is offline
Mein Auto: '04 BMW X3, '04 330xi
Won't start... fuel pressure code. Replace fuel pump.
or replace rear wiper arm.
Old 11-07-2013, 01:24 PM
Could be a fuel filter, or an old code that was once and never came again.
Diesel fuel delivery is a bit different to petrol.
Although N52 has a HPFP these days so less different.
Old 11-07-2013, 05:55 PM
DangermouseX3 DangermouseX3 is offline
Mein Auto: 2007 X3, 2008 X3
bmw x3 e83
Most bizarre thread today!!!
Old 11-07-2013, 06:27 PM
good call, missed that it was diesel. He did say though, If I recall, that he replaced the fuel filter.
Old 11-09-2013, 10:52 AM
have solved the problem it was the fuel was getting to the injectors but when u turned engine os the fuel run back down to the pump andnever stayed up in the fuel rail fitted a one way valve to fuel line now fires up first turn of key thanks
