Old 11-07-2013, 10:37 AM
alysiawallis alysiawallis is offline
Mein Auto: 2009 323i & 2000 323i
Please help driver side heated seat BURNING MY BOTTOM!
Hello Everyone,
I couldnt find a post with this issue. I purchased my car(2009 323i) in May 2013 and recently have tried to use my heated seat since the cold weather is here. So what is happening is the right side of the seat is getting extremly hot even on the lowest setting, You cant even put your hand on it without pulling away before 3 seconds. Any suggetions for me to try before I send it to the dealership that is going to charge me $153.00 just to diagnose it!
Thank you in advance!
Old 11-07-2013, 12:47 PM
Chop362's Avatar
Chop362 Chop362 is offline
Mein Auto: 2013 335Is
No tricks here looks like you will need a tech to do a look see, $153 not that bad.
Old 11-07-2013, 01:08 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Burned your bottom?
Originally Posted by alysiawallis View Post
Hello Everyone,
Pics or it didn't happen.
Old 11-07-2013, 01:14 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Hello Everyone,
A heated pad under upholstery. Possibly left side open allowing high current right side. Replace.
Old 11-07-2013, 03:57 PM
Banned
Mein Auto: 2007-335 HTC
Cal you are the MAN, you know just about eveything! and I mean that respectively
Banned
is it possible if an open pad, loose wire? Look under the seat with a flash light
Old 11-07-2013, 04:11 PM
luigi524td luigi524td is offline
Mein Auto: '17 540xDrive; '98 Z3 2.8
Exclamation Heated seat issues
Hello Everyone,
BMW has issued several recalls related to heated seats. I recommend hunting these down http://blogs.wsj.com/drivers-seat/20...ectrical-flaw/ before having a dealer burn a hole in your pocket!!
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive|'13 X1 MSport|'98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
Old 11-07-2013, 04:32 PM
Well, thank.....wait....
Old 11-07-2013, 05:54 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
not pics of your burning bottom... we don't want to see you bottom
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 11-07-2013, 06:30 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
okay, heaters. I might know a thing or two about these. It would depend whether the elements are hooked in parallel or series. Cal's idea would not work for parallel as two R's in parallel are less than the one R by itself. If left were open, the circuit would revert back to a single R with a higher R and thus lower current.
R in //: Req=(R1*R2)/ (R1+R2); If R1=R2=8; Req=4
If left and right were in series and left were open, the circuit dies as its open. Me thinks more along the lines of series circuit but a with current feeding to right and then short to ground (imlpying a fault) before continuing on to the left side. This would effectively double the current presuming both sides have same R. Double the current means quadruple the watts as Power =I^2*R. This sounds like the burn your butt mode that you describe.
We had 4 resistors in series on a fuel line heater on STS-43. Workmen accidently had a clamp pinch the circuit between heaters 2 and 3 and it was a dead short to the spacecraft's common ground. As a bonus, the thermostat was on the downstream end of the circuit. So boys and girls, we had the upstream circuit with quadruple power and no thermostat to turn it off and the short took out theromostat out of the effective circuit. That hydrazine line shot up thermally like a rocket and flight controllers had to have crew manually dissable it. We came to know that event as a "smart short". It knew right where to go bad to cause a very severe situation. After that flight, all circuits were changed to put thermostat at front of circuit. It some instances, an overtemp thermostat was also added to stop a runaway condition.
I'm not disagreeing with Cal but it sounds like too high of a current running throught the right side. the series circuit analogy with half way short seems to play. Is the left side normal temp or not heated at all. Cal's picture (guessing from realOEM) shows many heater patches so ther may be multiple circuits to ponder.
Old 11-07-2013, 07:42 PM
gcreese gcreese is offline
Mein Auto: 2010 535i Sports Wagon
In one of my Volvos, the heated seats were fine. Then one day, one got REALLY hot and it failed shortly after. This may be a warning sign that the heating is about to go.
2010 535i xDrive Sport Wagon (April 2009): Deep Sea Blue / Cream Beige / Sport, Premium, Cold Weather Packages
2011 335i xDrive Coupe (April 2011, European Delivery): Le Mans Blue / Oyster-Black / M Sport, Premium, Convenience Packages
Old 11-07-2013, 09:30 PM
Yeah, prob parallel. So. Voltage, she no change. T'dissipate more watts, reduce resistance. Lowish resistance short, hot side.
The great truth: Watts = V*V/R
Wait....what if....not internally shorted, but lowish resistance short to ground mid-circuit, hot side? Voltage divider!
Oy! My butt hurts!
Old 11-08-2013, 02:09 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Originally Posted by SilverX3 View Post
not pics of your burning bottom... we don't want to see your bottom
Speak for yourself. On the other hand, if Alysia isn't a female name, I'm feeling kinda creepy.
There's a thermostat in there somewhere. It's gone bad. The thermostat can be as simple as a feedback loop like those reminders on the dashboard that tell you if you've got a light out. The problem is probably not in the element but in the module. Yup, a simple 'computer' controlling seat heating. The damned things are everywhere, probably over 30 in the car.
Works like this; As the element heats up resistance goes up. As resistance increases the module knows that it is at a particular temperature. When resistance reaches level X, according to the driver's setting on the switch, the module knows that the appropriate temperature has been reached.
A short could cause a problem but there are ways the module should pick up on that. I'm guessing it's the module (the 'thermostat') that's...um...kaput.
Old 11-08-2013, 05:30 AM
What thermostat? If there is one, prob RTD w/chip & switch [transistor], mighty small.
Or, dash button is soft switch w/couple o'resistors.
Old 11-08-2013, 07:33 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Thermostat = Module
Old 11-08-2013, 07:37 AM
Thermostat = Module
What is this module? Show me this module. Or will you run away like the little mouse?
I must see this module. I will show this module who is the boss.
Old 11-08-2013, 09:11 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Geeze get a look at...the brown wingtips Borat's wearing. The man clearly has no sense of style. Black would have gone much better with the, the, whatever it is.
/Now returning thread to subject at hand/
Old 11-08-2013, 09:19 AM
BB_cuda's Avatar
We space peeps now use thermistors which tell a controller to turn off or on. It is closed loop feedback type control.
Yes CAL, P=V^2/R=I^2*R. same thing either way. I used the I^2*R way to demonstrate how power quadruples if current doubles.
Old 11-08-2013, 12:04 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Those aren't brown. They're cordovan.
Old 11-08-2013, 12:43 PM
SilverX3's Avatar
I dont want to see Borat bottom.... ewwww
Job - Captain
MY11.5 X1 Xdrive25i
Old 11-08-2013, 01:03 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Oh, cordovan? Brown with a little ox blood thrown in for good measure. That makes all the difference. I take back everything I said.
Old 11-08-2013, 01:46 PM
Who....who is this Borat of which you speak?
