Old 11-07-2013, 01:51 PM
shortstop shortstop is offline
Mein Auto: 2014 X1 xline
Have flat on RFT
My new x1 will be delivered Sunday or Monday - got a flat on RFT this morning! 2011 328i w/ 45000.
It went very very flat, refilled w/ air - went back down in about 1 hour - gonna try the slime treatment - Pep Boys said it would last a few weeks.
shortstop
2014 X1 xline
Old 11-07-2013, 04:55 PM
luigi524td luigi524td is offline
Mein Auto: '13 535xDrive; '98 Z3 2.8
Slime :-(
That sounds like a serious cut or defective tire - Slime will destroy your TPMS. You may be on the hook for a replacement tire. I recommend trying to find a used one via the forum ASAP.
My opinions are free - you'll get exactly what you pay for!
Current: 2013 535xDrive | 2013 X1 MSport | 1998 Z3 2.8
Past: 2007 530xi | 2001 740i | 1998 740i | 1994 740i | 1986 524TD
"Seek and ye shall find" ... start with your owner's manual!
Click on the MrRebates logo/link below for cash back savings at on-line stores like Tirerack!
Mr. Rebates
Old 11-07-2013, 06:13 PM
update on flat run flat
Tried fix a flat - did not hold air - you could see the foam leaking out thru the tread. took it to Discount Tire where they quickly repaired the tired gratis!!! happy ending
shortstop
2014 X1 xline
Old 11-09-2013, 02:38 PM
Thumbs up Leaking RFT
Sounds like you lucked out this time
Mr. Rebates
Old 11-11-2013, 10:15 AM
Wolfex Wolfex is offline
Mein Auto: X1
Have flat on RFT
If the car is brand new the dealer will replace the tire. I think they are covered for the first 500 or 1000 miles you drive on it or something like that. If you have the tire insurance they are covered for the duration of the policy.
On my previous Audi I took the car to a local shop and they repaired the RFT for $10. Stay away from the slime for a repair. Use it only for emergencies.
Old 11-11-2013, 11:41 AM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Woo hoo
Happy ending
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 11-11-2013, 11:47 AM
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
Love Discount/America's Tire. They are my go-to flat repair shop, since they always repair for free because I'm a customer, and they patch from the inside, the right way. The only downside is that there are a couple of brands of run-flats that they will refuse to repair based on those companies saying that their tires are 'throwaways'!
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=325723&dateline=1371746393
*NEW* delete pls 1K
3K
11K
Old 11-13-2013, 01:10 PM
dominoaz dominoaz is offline
Mein Auto: 07 Z4, 77 Porsche, 11 528
Discount Won My Business For Life
Their policy of free flat repair earned my business for life. Unfortunately, many RFT's are "NOT repairable" according to the manufacturer. Depending on the damage, good old tire plugs can prove to be highly effective. Theydon't require a rebalance, and are less costly. I recently turned in a set of Conti's with one tire that had three plugs in it. I drove this tire on the front end for another 20K miles, at speeds often over 100 mph. At $600+ per tire, this non-repairable tire would have cost me $1800 ($600 X 3). Plug Kits are $5 at WalMart. Compressors are $10.
Old 11-20-2013, 09:09 PM
CE750Jockey's Avatar
CE750Jockey CE750Jockey is offline
Mein Auto: '16 M235 'vert.
Try Dynaplug. Check it out here: http://www.dynaplug.com I have no affiliation with them. It just works. I keep it in my glove box. Don't believe that crap about RFTs not being repairable. They are.
Old 11-22-2013, 05:12 AM
luvmybeemerbike luvmybeemerbike is offline
BMW bike whore
Mein Auto: 2013 BMW X1
ANY truth to the rumor that a RFT tire has to be removed and replaced at a shop with a special mounting machine?
Old 11-22-2013, 06:57 AM
bighorns's Avatar
Evil cider brewer
I like this one. Add a pump, and you're done.
*NEW* delete pls 1K
3K
11K
Old 11-25-2013, 03:31 PM
Mein Auto: X1
Have flat on RFT
The BMW dealers and some tire shops refuse to repair RFTs. The rubber is stiffer so maybe the tire plug doesn't work as well as on conventional tires. On my previous car I have had flats and the local gas station plugged it up for $10. That tire experienced two more flats in its lifetime so I don't know if they were all related to the same puncture.
Since RFT rubber is stiffer and side walls thicker than conventional tires, I am guessing they need specialized equipment to install them on a rim.
Old 11-27-2013, 10:40 AM
HerrK's Avatar
HerrK HerrK is offline
Mein Auto: 2011 Z4 35i
The tread rubber for a RFT is no different, then the multitude of other tread rubber combinations in non RFT's. That is why some tire life is 15K and some 60+K miles.
The sidewall of a RFT does contain an insert to maintain the sidewall height/stifness in the event of loss of pressure. However no special equipment is necessay to install. Most tire machines have electric motors and mechanical advantage to stretch/install the tire to the rim.
HerrK - Keine Eifelfahrt ohne eine Runde über den Nürburgring
May 2010 ED l 2011 35i l Crimson over Ext'd Coral Red w/brushed Alum l 6sp MT l Prem Sound l Sport Pack l 296's l Comfort Access l Alarm l Power Heated Seats l & Nav.
FrauK - 2014 Q5 TDI - May 2014 ED | Cuvée Silver over Pistachio beige | Premim Plus | MMI | Nav | B&O
Old 11-28-2013, 08:52 AM
BMW bike whore
What did they do to repair the tire shortstop? Plug? Patch? New tire?
Old 11-28-2013, 09:30 AM
assume they plugged it - it was in the tread - not sidewall
shortstop
2014 X1 xline
Old 11-28-2013, 09:35 AM
BMW bike whore
I was curious if they used an actual patch (which they would need to remove the tire from the wheel) or just the common plug.
Old 12-04-2013, 03:57 PM
bighorns's Avatar
Evil cider brewer
Re: Have flat on RFT
America's Tire always removes and patches, then re-balances, which is why I like them.
*NEW* delete pls 1K
3K
11K
Old 01-31-2014, 05:38 AM
BMW bike whore
Goodyear and their affiliates say that the only PROPER and correct way to repair one of THEIR run on flat tires is to use a PATCH and a PLUG and a complete RE BALANCING.
Old 02-02-2014, 12:32 AM
0w40X1 0w40X1 is offline
Mein Auto: 2014 X1 s28i Msport
There is a combination patch with plug that they pull from inside tire to outside. Seals the whole thing up so no water can rust steel belts from outside.
Old 02-03-2014, 03:37 AM
BMW bike whore
Thanks for the update 0w40X1. For some silly reason I thought it was two pieces, an actual plug and a patch? I did a search last night and saw it's a combined patch that has a wire running thru it and it's pulled thru the puncture. It's a couple of extra steps to install one of these plug patches, but looks like the best way to go.
Old 02-03-2014, 12:41 PM
PinkLambo's Avatar
PinkLambo PinkLambo is offline
Mein Auto: BMW X1 - 2012 xDrive28i
I've had run-flat tires repairs before, good luck to you!
"When I lay rubber down the street
I pray for traction I can keep
But if I start to slip and slide,
Dear God, protect my ride."
