Old 11-07-2013, 02:28 PM
Darknachos Darknachos is offline
Mein Auto: E38 740i
E38 Engine Warm , oil flickers when switchting from Park to Reverse.
I am baffled by this issue, any input would greatly be appreaciated.
When i first turn on my e38 740I on a cold engine start, I can switch from Park to Drive to Reverse, and its good to Go. Run with all its horsepower it has, no problems. Once the car is warm and has been running for about 30mins to an hour, and I shift into reverse. The oil light will flicker rapidly and switch gears, on a few occasions the car has shut off when going into reverse. If it shuts off, i just have to restart the engine then switch gears again so it can go in reverse.
No other symtons... No check engine light.... no nothing.... (BTW Oil is good and full)
I switch the Camshaft sensor for a new one, because i thought it would be buggy... but its still the same...
On a side note, my SRS light came on, its says left side airbag sensor fault.
Where is this sensor at? I want to clean the contacts....
Old 11-08-2013, 04:22 AM
ou18 ou18 is offline
Playing Mechanic At Home
Send a message via AIM to ou18 Send a message via Yahoo to ou18
Mein Auto: 1997 740 IL
I did a quick google search, and some have reported its an oil pressure issue that causes the light to flicker, HOWEVER, these same people have reported the flicker going away when throttle is pressed...
Does this occur for you?
1997 Black 740IL (w\ badass Phone in console)
Old 11-08-2013, 08:07 AM
wiredantz wiredantz is offline
Mein Auto: 740I
Oil light flickers only when the engine has been running, warm, and only for a 1 sec or 2 when switching from P to Reverse. Then goes away. Sometimes when switching from P to R then engine shuts off.
when the engine is warm:
If I am on drive and come to a complete stop, then switch to Reverse the idle needle will jump to 1 and go back down to zero. If I am on P and go to reverse, the Idle needle will dip below zero and go back to 0.
Old 11-10-2013, 11:51 AM
Podmore Podmore is offline
Mein Auto: 2001 BMW 735i
Mmmmmm there's a challenge for we armchair diagnosticians!
At first blush the symptoms would seem to indicate a damaged transmission wiring harness causing a transient short circuit or bridging between two different circuits.
If a poorly functioning oil pump (or worn bearings or low oil level etc) was contributing to low oil pressure then the oil light would come on at idle every time, not just when engaging reverse. Also, likely to get a Low Oil warning from the Check Cluster.
The dip in the tachometer when shifting gears is also a clue, but I'm not sure what that clue is pointing to!
So as with all good diagnostic tests, begin a process of elimination and start by checking the condition of the wiring harness to the trans - especially the connector contacts.
HTML code is Off
