Old 11-08-2013, 11:26 AM
lovemea740i lovemea740i is offline
Mein Auto: 2001 740i M Sport
740i Smoking, won't start, help please!
Hi,
I was trying to sell my 2001 740i M Sport Classic body style, a buyer took it on a test drive, parked it and the car stopped running. The car turns over, misfires, but won't start. I replaced the crank sensor, but the car still won't start. Smoke comes up from the passenger's side around the ABS Unit.
I replaced the timing chain guide rails about 2 years ago, but now they need to be replaced again. Besides that, the car is in good shape. Any ideas why the car won't start? Thanks!
Old 11-08-2013, 01:16 PM
FABOCH's Avatar
FABOCH FABOCH is offline
Mein Auto: 2000 BMW 740I SPORT
sorry, but thats a nightmare..replaced the guides 2 years agao and need replacing again?
Smoke is usually a sign of a bad OSV but smoke from ABS Unit? What are the CODES?
2000 740i Sport , Alpina 21`, Alpina Lip, Alpina Deco kit,Dinan 7,Dinan TB, DINAN CAI, DINAN Exhaust, Dinan Stage 5, Dinan 4/5 transmission, Dinan manifold, Highline individual interior,Eibach/Bilstein,Zimmerman Timing guides 08/13
Old 11-08-2013, 07:38 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
+1 Get codes. Did you replace the crank sensor because you had a code for it? Either way, did you replace it with a Bosch sensor? When does the smoke occur? If it was after driving, it's probably just oil from a leaking vcg hitting the exhaust.
Saying the guides need done but otherwise.... Many of these cars are junked/parted because of that issue.
Old 11-09-2013, 04:12 PM
ou18 ou18 is offline
Playing Mechanic At Home
Send a message via AIM to ou18 Send a message via Yahoo to ou18
Mein Auto: 1997 740 IL
Wow, something must not have been done right to have to replace those guides again within 2 years.
1997 Black 740IL (w\ badass Phone in console)
Old 11-12-2013, 02:28 PM
Thanks for the feedback. Yeah a nightmare, trusted the wrong, certified foriegn motor mechanic shop and got jacked. $4200 to them for repairs then $2100 to another mechanic to fix their mistakes, now the guardrails, which are plastic, cracked. As far as the codes to see why the car won't start, I just have a OEM Meter, can't start the car to drive it to get it put onto a machine. The crank sensor was a BMW original part.
Old 11-14-2013, 06:23 AM
Code readers are fairly cheap at your local autoparts store. I think i paid maybe 30 bucks for mine. It gives me the codes, then i do a quick search on the inter webs. You could spend alot on one that will tell you what the code is with description, but a cheap one will do the trick just fine. The one i bought even resets and clears the codes for me.
autozone is where i think i got mine. Probably a good investment for you to keep around in your pile of tools...
Old 12-17-2013, 03:30 PM
Thanks everyone for the feedback. Got a code reader(thanks, ou18, didn't know where to look for one), the codes were P0011 Camshaft Position Timing Over Advanced System Performance Bank 1, P0021 Camshaft Position Timing Over Advanced System Performance Bank Bank 2, P0171 System Too Lean Bank 1, P0174 System Too Lean Bank 2. I changed the camshaft position sensors left and right, but I'm still coming up with these codes and the car still won't start and I've already changed out the crankshaft sensor. Any suggestions? Thanks again for your help.
2001n740i m sport for sale
HTML code is Off
