e92 335i unique "reduced engine power" scenario - Bimmerfest - BMW Forums
Old 11-08-2013, 12:13 PM
Doherty224 Doherty224 is offline
Mein Auto: 08 335i, 06 Cayman S
Hi everyone,
(sorry for another thread)
Im new to the forum and I know there are a million conversations about all the different possible problems we can have when it comes the dreaded "reduced engine power light." Ive had my 08 e92 335i for about 6 months and the car has thrown the light on 3 separate occasions all several months apart. The car first threw the light a day after I bought it. I was driving normally and the car threw the light and entered limp mode. Restarted the car and it was fine. Then a few months down the road it did the same thing, and now again this morning. The odd part about this is that my car has given me ZERO symptoms other then randomly entering limp mode on these 3 occasions. It starts strong, runs strong and seems completely healthy otherwise. My thoughts are maybe a bad sensor? or the computer has just glitched on these occasions? My car is a 6MT, has a dinan exhaust on it and is at 58k miles. Has anyone else had a similar situation? and any suggestions? going to the dealer on tuesday for diagnostics otherwise
thanks guys
Old 11-08-2013, 01:01 PM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Well, you certainly need to pull some codes and see what's going on. There's a $150 OBD Bluetooth module floating around out there that does BMW codes if you don't want to pay the dealer. That being said, "occasional CEL with no further information" pretty much limits the response you can get here.
Old 11-08-2013, 03:22 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Near 60k mi you say?
You got the dirty....
Old 11-08-2013, 05:42 PM
What makes you think this is my issue? like I said it's is very infrequent
Old 11-08-2013, 07:35 PM
Well, without codes, can't say for sure. But typical for your mileage. Even if that's not it, needs doing.
Old 11-08-2013, 08:00 PM
#propaganda #propaganda is offline
Mein Auto: 2007 335i sedan base
Had the reduced power happen to me several times before it finally crapped out. Ended up being injectors. If that's the case.. No bueno.. Dealer charged me 1500..
Old 11-08-2013, 11:14 PM
Coulda removed & rebuilt - ain't hindsight great - guess instead they charged for new injectors and retained the old ones....and had 'em rebuilt to sell as new for the next job. Buy one injector; resell maybe 100 times at new injector price for the cost of inexpensive rebuild.
Mileage?
Old 11-26-2013, 09:41 AM
soccerjj01 soccerjj01 is offline
Mein Auto: 2009 335i
My car went into the limp mode & the end result was two VANOS solenoids replaced @~ $1K
Old 11-26-2013, 10:17 AM
swillkill swillkill is offline
Mein Auto: 335i
mine did that a few times. ended up being low tire pressue - slow leak.
Old 11-26-2013, 01:54 PM
My car ended up being the exhaust vanos solenoid but bmws recommendation to me was to leave it be, and they just threw a new sensor in for free
08, 335i, bmw, e92, engine, hpfp, n54, turbo
