The X5 SAV Forum
Old 11-09-2013, 07:50 AM
JOSEMESATOBON JOSEMESATOBON is offline
Mein Auto: BMW 2006 X5
hid bulb in my 2006 x5
Would anyone can help me on how to replace a hid bulb in my headlamps? I was able to remove de bad bulb but couldn't put it back in place. at the base of the bulb there is a metal box that by twisted it should lock in place. Any help would be appreciated and if you have pictures much better.
Old 11-18-2013, 10:04 PM
AJR1982's Avatar
AJR1982 AJR1982 is offline
Mein Auto: 525i 2002 & x5 2002
If you're talking about the Xenon lamps then they will slide in two directions. You'll notice two bumps that need to align with the inserts and try again.
Old 11-19-2013, 08:41 AM
FanofX5 FanofX5 is offline
Mein Auto: 2006 X5 3.0
Are you having a problem getting the high voltage connector to snap back on? I went through this recently and could not get the connector to turn.
Look inside the connector, there will be a plastic ring. Make sure the notches on the plastic ring line up with the notches on the metal connector. It should slip right on if they are lined up.
Old 11-21-2013, 02:22 PM
thank you very much, it was a matter of alignment of the ballast.
Old 11-21-2013, 02:28 PM
IT IS NICE TO KNOW ABOUT ALL YOU GUYS OUTTHERE ALWAYS READY TO HELP. my bmw x5 2006 has developed this weird air conditioned problem: Sometimes after starting the engine, the A/C refuse to work and all of the sudden the compressor kicks in and everything is fine, it cools just fine. what can be causing the compressor not to start normally? I would appreciate any help.
Old 11-21-2013, 03:06 PM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
I would start with a new thread for your a/c you will get more responses .
2003 X5 3.0i
