Old 11-09-2013, 04:50 PM
Greggl52's Avatar
Greggl52 Greggl52 is offline
Mein Auto: 2008 BMW 328xi
LED Angel Eyes Upgrade
I just bough a 2008 BMW 328xi and want to convert the halogens to LED. Has you ever done this to your BMW? I am thinking about buying 6000K White Light bulbs instead of new headlights. Also have you ever installed LED headlight bulbs in you car and, Is it a pain to do this? What do you think?
Thanks,
Gregg
Old 11-10-2013, 06:53 AM
Mein Auto: '06 AW 330xi
Don't put led in your halogen reflectors. The LEDs that are needed to achieve the output necessary for night time driving won't be plug and play and extensive modification needs to be done in order to properly dissipate the heat high powered LEDs give off.
You need to replace the headlights if you want xenons or led angel eyes. Slapping an hid kit into your halogen reflector is illegal and you will lose output.
Depo is a popular aftermarket option. The projector are crap though....
Old 11-10-2013, 07:27 AM
Greggl52's Avatar
Is it tough to replace the headlights?
Old 11-10-2013, 07:37 AM
You need to remove the bumper. YouTube it. You should be able to find a guide about removal
You just need a t25 torx bit, 8mm (maybe 10mm if your removing the liner completely) socket, and that's it.
