Old 11-10-2013, 10:19 AM
hindswillrox hindswillrox is offline
Mein Auto: 1994 525i / 1999 porsche
M3 Wheels on 335i?
A friend ofmine just traded in his M3 for 650I and he has a extra set of wheels I think they are 8.5 amd 9.5 19s. I would like to put them on the 335i if they fit (correct tire size?). He sent me this oic of a similar wheel.
Old 11-10-2013, 12:36 PM
LongIsland LongIsland is offline
Mein Auto: JB4 335xi Coupe
i asked this question yesterday and somebody told me the M3 wheels wont fit on a 335 but i can't see that being possible...maybe if you put spacers on they will fit. not i'm going to have to buy the OEM CSL Replicas if they really don't fit
Old 11-10-2013, 01:10 PM
floydarogers's Avatar
Pedant and Curmudgeon
The rears simply won't fit. The offset is too positive (spacers increase positive offset) and they will rub a lot, unless you roll the rear fenders big time.
The fronts will fit. Some people put fronts all round for a square setup.
Old 11-10-2013, 01:23 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
I've read a very long thread on this topic. First of all, if those are OEM 359s which they appear to be, they are 19x9 and 19x10, front and rear respectively. The people that ran 275/30R19 on the rear on sedans had rub on the outer edge of the tire. The thread made the point that coupes did better there. On the fronts, people that had 335is and ran 235/35R19s had rub happen between the outer tire circumference and the oil cooler grill within the wheel well. People that had an E90 328 didn't have the cooler grill and thus didn't get the rub. Back to the rears, people that went a skosh smaller at 265/30R19 did not have rub. That said, the 10" rear width really wants the 275 width instead of 265. Another parameter to consider is the tire brand and line itself. Spacers doesn't really help and i would agrue would further hinder the rear quarter panel lip rub. Some people had the rear wheel well lip rolled. I have no direct experience so consider the source of this advice. I will attempt to find the thread and post back in here for you. I was strongly considering going to 19s but held off and stuck with my OEM 18" 193s and just got the michelin pilot super sports for $1000. My reasoning was that the sidewall height was already pretty thin and going to 19" and not getting much bigger diameter (25.5" vs 25.0") wasn't worth it. Since then, i nailed a curb with a rear wheel and paid for it to be repaired ($125). You are fortunate to get a set of 359s and hopefully don't have curb rash. The turn key cost for new 359 and appropriate rubber is on the order of $3500. Yes there are cheap tires out there but why would you do that if you laid $2000 out for the wheels alone.
All that said, the 359 wheels are super cool looking and I druel when i see an M3 with them. iI'll go get the thread for you.
To verify if they are 359's, compare to these part numbers:
front BMW 36-11-2-284-055
rear BMW 36-11-2-284-060
Look on inside of wheel for the part number. best of luck
Old 11-10-2013, 01:38 PM
BB_cuda's Avatar
Here is the thread. I skimmed through it and i might have not quoted correct tire size for fronts but i think i got the rear tire specs right. Its a long read but you don't want to misspend $ for the wrong tires. Hopefully, your friend sold you some 359s. Good luck.
http://www.e90post.com/forums/showthread.php?t=508202
Old 11-11-2013, 08:16 PM
the wheels are RC340s
Ok so the wheels are RC340s 8x19 and 9.5x19, I have an old 255/35/19 that I an going to mount for fitment on the rear.
Old 11-11-2013, 08:19 PM
Here are some pics of the wheels
ID:	407017   Click image for larger version
ID:	407018   Click image for larger version
ID:	407019   Click image for larger version
Old 11-11-2013, 10:27 PM
If they are OEM BMW wheels, the offset of the fronts is 47 (see the IS47?), and the rears is 27 (you evidently didn't take pics of the rears.) The standard offset for the E9x is 34 front, 37 rear IIRC. Because of that, the offset of 27mm for the rears means they will be pushed 10mm to the outside (as if you had a 10 mm spacer). The 9.5 width is already 1" or 25.4mm wider than the sport package 8.5" wheels, so that's a total of (10+25.4/2) 22.7 mm (almost 1") closer to the fender. It's gonna rub, nothing you can do. (At least if my understanding of offset is correct.) Think about your current set (hopefully you have sport package): would putting a 22.7mm spacer cause your tires to rub? On my 335d, it would.
See http://www.tirerack.com/wheels/tech/...9-3f3ad7dc1190
Old 11-12-2013, 07:03 AM
Rears are 341s
You are correct I took two pics of the fronts. The rears read RC341 - IS27. They look to be 15/16 out from the stock wheels. By setting a strait edge across the rims and hooking a tape measure on the mounting face I read 3 1/8" on the stock wheels and 4 1/16 341s.
Old 11-12-2013, 07:14 AM
stock wheels
I attched a pic of the stock wheel, Can some one identafy this wheel and can I upsize the tires? 255 on the rear can I go up to 265? I want to get rid of the run flats.
Old 11-12-2013, 08:21 AM
Those are the stock coupe sport package wheels (Style 189, I believe, my son has them on his 335i). You should be able to oversize to 265 with no problems. Many people are taking the fronts from 225 to 235, too.
Old 11-16-2013, 06:36 AM
for sale
These wheels will not fit my car, I ]got a good deal on them and I an going to sell them on ebay - does any one know khow what cars they will fit? this would help with my listing.
Old 11-16-2013, 08:01 AM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
How much for the rims?
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 11-16-2013, 10:04 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Why tire brand matters is not all 2XX-1x-3x tires are the same physical size. You actually have to measure a brand that fits against what ever you actually choose to use. Some can vary over an inch in width. Tire rack has the charts you need for this.
Overall you are in most cases better off with knock-off 'sthat have the correct backspacing.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 11-16-2013, 11:06 AM
Price
I would like to get $1000 - I have 2 Dunlop Sportmax GT 255/ 35 ZR 19 tires that fit the rear un mounted. I will be posting them on eday in the next day or so. Make an offer?
