335i turbo related issue - Bimmerfest - BMW Forums
Old 11-11-2013, 03:58 PM
Knightmare Knightmare is offline
Euro Enthusiast
Mein Auto: 2007 BMW 335i
Alright so I've found out that my wastegate actuator is going out in one of my turbos. My biggest concern is how long can I expect my turbos to last before something happens and how bad will it be when something does blow? Will there be even more damage done immediately on the road? Another thing is that I've read up on going to the single turbo setup on the 335i but is going from twin to single setup worth the extra money? Extra money being the difference in price of buying oem parts to replace my stock turbos compared to buying a single turbo kit from someone like Vishnu, RB, or someone along those lines. Oh and on a side note is that I'm having a local performance shop install the kit whether it comes down to all OEM parts or going aftermarket single turbo set up because I don't have access to tools and room to work on my car here at college. Car has ~109k miles and I feel like once I fix this and other maintenance parts it'll go for a long time after. Thanks for any input!
Old 11-11-2013, 04:05 PM
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
RB sells an upgraded twin turbo kit that replaces the stock turbos. Don't know what is involved in the install, but have heard great things about them. BMW also has an extended warranty on the turbos for wastegate issues. (8 yrs./82,000 miles)
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=325723&dateline=1371746393
*NEW* delete pls 1K
3K
11K
Old 11-11-2013, 04:24 PM
Euro Enthusiast
Would doing the RB twin setup be better off in the long run? Or will going to the single setup be since they're almost identical in price with the RB twins being just under Vishnu's single setup.
Old 11-11-2013, 06:14 PM
bighorns's Avatar
Evil cider brewer
I think it depends what you want. A big single turbo takes longer to spool up, so it tends to have more lag. I would see if you qualify for a stock turbo replacement under warranty first.
*NEW* delete pls 1K
3K
11K
Old 11-11-2013, 07:48 PM
Euro Enthusiast
Thanks for the advice, I will check out the warranty option and see where that lands me.
Old 11-12-2013, 07:51 AM
fun2drive's Avatar
BMWCCA 149159
Wastegate rattle has nothing to do with turbo life, repeat nothing. Wstegate just controls the amount of boost commanded. Replacing the actuator is not easy but betting there is nothing wrong with your turbos. BMW will under the 8 year 82K mile extended warranty replace the wastegates and most likely the turbos since they come as an assembly.
No need to go to Rob's set up unless you want to. Just be sure you allow the oil to get warm meaning over 160F before beating on it...
Old 11-12-2013, 08:20 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Going out? How do you know? Diagnostic procedure & data, please.
Try adjusting 'em first!
Old 11-13-2013, 01:37 PM
Euro Enthusiast
I've only read up on different threads on here and compared my rattling issue to others saying the same. I don't have diagnostic procedures and data so I can't be 100% sure. If I do adjust them how well and how long will that fix the actuator problem? I've noticed rattling due to (from what I've read) the actuator arm becoming loose and I've gone through more oil recently getting down to Minimum level well before a service is due.
Old 11-13-2013, 02:07 PM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK
Originally Posted by bighorns View Post
i think it depends what you want. A big single turbo takes longer to spool up, so it tends to have more lag. I would see if you qualify for a stock turbo replacement under warranty first.
+1. N4s
