FRM / Footwell module - Bimmerfest - BMW Forums
Old 11-11-2013, 11:12 PM
ZappBrannigan ZappBrannigan is offline
Mein Auto: 2001 X5 35d
So I took my 2010 328i to a local euro shop for a brake fluid service. A few hours later they call and say that the lights aren't working. I had no problems prior to dropping off the car. At the end of the day the shop calls and says I need a new FRM / footwell module and it will cost over $500 to replace (in addition to the brake fluid service).
Needless to say, I am super skeptical about the entire situation. The shop insists that the FRM failure is just a coincidence. They told me that from failure is common. I never had any lighting, window, or other electrical problems before I brought it to the shop.
Currently, I have asked them not to work on the car so that I can take it to the dealership. I don't trust them. At any rate I will likely be out of pocket between $500-$1000.
I tried doing research on frm failures but found very little. Am I being taken? Any know anything about from module failure?
Old 11-11-2013, 11:29 PM
aleks001 aleks001 is offline
Aleks
Mein Auto: 2006 BMW 325i
i've read over the years that a couple have been replaced, so definetly possible, however it seems to be quite rare. Mine has glitch in it, where the scroll wheel to raise and lower the headlights (halogen) sometimes works, but since I don't really care about that function anyway, I've just left it as it always stays in the highest setting anyway. But it's a bit of a coincidence to have just failed exactly when you took it to them, but I still don't know what options you have apart from taking it somewhere else for another opinion.
Old 11-12-2013, 05:12 AM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
I agree it could just be a coincidence but it seems hard to swallow.
When you take it to the dealership ask them if they can determine the cause of failure before you go back to the first shop and raise hell unnecessarily.
Old 11-12-2013, 10:26 AM
Mein Auto: '06 AW 330xi
You can buy a used FRM and code it in. You can even upgrade from your FRM2 to FRM 3. You'll get a couple new features, nothing crazy.
FRM sits in the driver's side footwell, by the OBDII port. It's about the same location under the brake fluid reservoir in the engine bay. I can't say for sure that fluid can leak into the cabin at that location, but I would pull the cover for the FRM module and see if there is any liquid there.
Old 11-12-2013, 01:45 PM
This really sucks. I'll need to take it to the dealer so that means pretty much missing a day of work on top of all the repair costs.
Also the windows are open and cannot be closed. So no lights and windows down. It is cold these days.
Old 11-12-2013, 04:52 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
I would follow fdriller's advice before any evidence you have could evaporate. Should be easy to get to.
I recently did my first brake fluid job in the summer with a pressure bleeder. The cap wasn't sealed 100.00% and a bit leaked out, I was pretty careful with covering a lot of things, but flushed a bit of water down in the area for good measure (because it will eat paint). The water seemed to drip out nearby where the jack point is behind the wheel, FYI.
I don't know about other methods, but I have come across certain DIY mistakes made on other cars where they are nearly "gushing" out brake fluid. If a mechanic did this on accident, I could see them pouring a lot of water down in the area, I'm just dumbly guessing, some of the knowledgeable mechanics here might know what does typically happen.
It is a weird "coincidence". It's one thing if they were fixing a flat tire at the right rear, but that FRM is indeed right in that area where brake fluid goes, and roughly in the path of where my "dripping water" had flowed to.
Old 11-12-2013, 05:14 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Well, let's be fair - coincidences do happen - you may give them the benefit of the doubt.
In other news, shares of the Golden Gate Bridge are, as to TODAY, available for purchase! I am the sole broker, and must be contacted for this ground floor opportunity. HURRY! Shares are expected to triple in valve over the next 7 days and available lots of 100 shares are limited! Par value, for next 32 hours only, expiring midnight tomorrow, are $35/share. Please PM to purchase!!
Now then. Where were we? Footwell module! [VIEW PCB HERE] Looks like - thank God! - a conformal coating has been applied. For those not in the printed circuit board industry, that's a coating, usually clear or black, that protects the board from liquids and dirt. Big question: Will Glycol [brake fluid] compromise the coating? And if so, why on Earth did BMW put a coated board there?
Questions for the mighty Oracle to answer - I make no such claim for myself. But I would like a peek at your board, ZappBrannigan. Whattya say?? Hi res photo front & rear?
Old 11-12-2013, 05:18 PM
I don't have the car right now. I ask for the damaged module.
Old 11-12-2013, 05:20 PM
Be sure they know that early on - fax is good 'cause there's a receive receipt - they can't deny they got it - can't say they didn't know. Demand that board!
Old 11-12-2013, 05:21 PM
Will do.
Old 11-12-2013, 05:25 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
If water or brake fluid is entering the cabin from the vicinity of the brake fluid reservoir, you have bigger/more insidious problems than a dead footwell module.
Rule #1 when repairing consequential damages caused by a leak: You begin by fixing the leak.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 11-12-2013, 05:35 PM
The shop owner says he will pay for the repair cost if the dealer says the shop caused the problem. So this may be something that cannot be proven. Makes me think that fluid did not leak on the module, as that would be obvious evidence.
Old 02-05-2016, 08:49 AM
mf3st mf3st is offline
Mein Auto: bmw
hi, do you know where i can find a diy how to code new frm module to e90? thanks
Old 02-05-2016, 03:12 PM
BMWCCA 149159
Mein Auto: 17Ridge/14JGC/ 17Outback
Having replaced the FRM I can tell you that it isn't much fun since I am a big guy and it was winter when I did it.
Mine was actually fine but I coded the car back to the OEM settings.
It is possible that the FRM failed but for a total failure that is highly unusual. Usually when an FRM fails it is because someone shorted a light or window motor. The FRM 3 I believe can be reset like a fuse.
The only way the dealership can tell if the problem was the shops is if there is a fluid in the wiring harness to FRM that can be detected. I have not seem brake fluid make it inside the cabin when some was spilled before but then again it is impossible to rule everything out.
A serviceable FRM 2 or 3 is not expensive and you can have coding done externally if you have a laptop with wifi connection. Some of our members in the coding section offer this service to members. You might want to check that out.
Again total failure is very rare compared to some areas on the FRM failing...
Old 04-06-2016, 12:17 PM
MWILLE200 MWILLE200 is offline
Mein Auto: BMW E90 323iM
Mr willemse
Which number on the FRM can I use to buy a used one.Can I use a FRM of a 2011 on a 2007 E90
Old 07-23-2016, 05:15 AM
Billy Will Billy Will is offline
Mein Auto: 320i
Hi guys, I recently encountered all my lights signal didn't work, remote locks not expo ding and power windows is not working. What was wrong?
Thanks in advance
Regards,
Billy
Old 02-08-2017, 06:56 PM
Toliv Toliv is offline
Mein Auto: 328i
Foot well module
Just to let you guys know. I replace my module with a used unit from either 2007 or 2008 328i. My vehicle is 2011 328i and had no interior lights, no control over the headlights, Windows wouldn't work ect. Of course after battery replacement. I've read several times throughout the posts that a used unit would require programming. Not sure why or how but all is working normal with my vehicle with no programming. No numbers matched on the unit but the number located in the square. Hope this information is helpful.
Old 02-08-2017, 07:31 PM
There is now an extended warranty out for certain FRM modules
Old 02-08-2017, 10:19 PM
montr montr is offline
Mein Auto: 335d 2010
You can check if warranty extended with this link:
http://www.bmw-rp.com/production/isg...bmw_portal.nsf
Old 12-07-2017, 01:26 PM
monica928 monica928 is offline
Mein Auto: 2011 x5
Frm footwell module
Right after my car left the dealership from them fixing recalls , the Airbag replacement and the Gas Tank the check engine light came on and and guess what the issue is the Footwell Module. Well little did i know BMW FOOTWELL MODULE: LIMITED WARRANTY EXTENSION TO 8 YEARS/125,000 MILES. I am NOW the unhappy owner of not one but 2 BMW vehicles and my 2011 BMW X5 that almost has 125977 miles Footwell Module goes out. I called BMW Warranty and guess what !! They refuse to assist with covering the issue that they know is a problem that will arise!! To many issues with both of my cars 528xi and the x5.
footwell module, frm
