Old 11-12-2013, 10:05 AM
Morketh Morketh is offline
Mein Auto: 2007 BMW 328i
Power steering fluid low, and coolant is low. What kind?
2007 BMW 328i sedan
I went to get the car inspected and it failed because Power Steering Fluid was low and Coolant was low.
The mechanic told me they didnt have the power steering fluid or coolant that the paper requires that they printed out. I did some research, there are three types of fluid: CHF, LHM oils and ATF. I think a general rule is not to mix, even between CHF versions for example, as stated there. So don't mix ATF in if CHF is in there.
Here's the BMW part number for what is used in cars since 9/91: 82 11 1 468 041. It is for Pentosin CHF 11S.
Also, that is the same part number the mechanic gave me, HOWEVER!!! I look at the power steering cap and it says ATF ONLY. So do I put in CHF 11S or do I go get some Dex III ATF from O'Reilley's and put that in there? I would assume the ATF is what is needed.
The coolant needs part number 82 141 467 704
http://www.ecstuning.com/ES196290/
I just mix this myself with distilled water, 50/50 and then pour it in there I assume.
Old 11-12-2013, 10:22 AM
Mein Auto: '06 AW 330xi
PS fluid....there is sticker on the reservoir. It will tell you which fluid to use. Normally it is Pentosin CHF 11
Coolant....just get the OEM coolant and mix 50/50 with DISTILLED water. Tap water contains minerals that can cake up in the coolant system.
These fluids should never go low. If they are, you have a leak somewhere.
Old 11-12-2013, 10:56 AM
Just checked again, there is no sticker on the power steering reservoir, only the cap that has the writing ATF OIL ONLY on it so I find it odd that CHF is what is recommended. Might just take it to the dealership and ask them, kind of annoying to go there for that though
Old 11-12-2013, 11:59 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Best bet with no id on the car is to buy a qt from the dealer.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 11-12-2013, 12:07 PM
I missed the part about the ATF being stamped on the cap. If you don't have the green CHF 11 sticker on the PS reservoir cap, then use the ATF. It's whatever is printed on the cap.
Old 11-12-2013, 12:08 PM
Roger that, that makes more sense. ATF it is
Old 11-12-2013, 01:11 PM
Will this ATF work right here? I saw some people saying they use DEX III and this is what I found.
http://shop.advanceautoparts.com/web...arts_8130008-p
Old 11-12-2013, 03:14 PM
fun2drive's Avatar
BMWCCA 149159
Yes only if your car uses DexIII which I don't think it does if it is an E90 series since they all use the CHF-11 synthetic Pentosin ATF...
I reecall NAPA can get you Pentosin much cheaper than the dealer...
Old 11-12-2013, 03:24 PM
Why does my cap on the power steering fluid reservoir say ATF OIL ONLY if it is supposed to take CHF? CHF is not ATF, not sure if you are getting that confused.
Old 11-12-2013, 03:26 PM
Its only about a QT why screw around it no one is positive? Looks to be about $11 for factory fill.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 11-12-2013, 03:27 PM
Yea no one seems to know so it looks like im going to have to drive 30 minutes to a dealer
I'm going to see if they can tell me over the phone tomorrow maybe.
Old 11-12-2013, 03:29 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
I don't think he's confused. He knows way more than I do, and I don't know much, but this is the first time I've heard of an E90 that uses ATF. Why the cap says so, I'm wondering if you had a mechanic replace with the wrong one? Maybe they even put the wrong fluid in there. Who knows, I sure don't.
CHF is a dark green, yours is probably almost blackish now but if you pull a little out with turkey baster and squirt on paper towel, you may see some green. ATF is typically (but perhaps not always?) a reddish color.
CHF is not cheap, and if you're buying the whole canister, I would consider getting a second one and just doing a flush, whether "mostly a flush" with the super easy turkey baster method, or more complete and messy ways. Most do TB.
Old 11-12-2013, 03:32 PM
Roger that, I'll just put some on a paper towel and see if I can see the color.
Old 11-12-2013, 03:38 PM
Well it is hard to tell, I just put a paper towel in there and pulled it back out real quick. It doesnt have any red tint to it but it does have the slightest bit of green tint. I think I will just take it to the dealership to be 100% sure.
Old 11-12-2013, 03:44 PM
wooohooo
It's CHF. On the left is about 30K miles, the right is fresh.
Old 11-12-2013, 04:02 PM
Yep that's probably it then, wow what a bunch of douches for putting that ATF only cap on there.
Old 12-09-2016, 08:36 AM
MU5149 MU5149 is offline
Mein Auto: E90 335D
Mine Too!
I've just been sat around trying to figure this out, thinking of ATF as Automatic transmission Fluid, with a cap with no symbol on whatsoever (or the standard engraved steering symbol) and a black oil inside
Hes not the only one and perhaps not a dodgy mechanic... just a dodgy batch of BM caps
Old 12-12-2016, 12:32 PM
jiveturky1 jiveturky1 is offline
Mein Auto: 09 335xi 6MT, 05 M3 6MT
Pretty sure it's Pentosin CHF 11S. That's definitely what my '09 takes. My '05 takes ATF. That didn't make sense to me back when I came across it so I started looking around and found the Mike Miller document, wherein he said that BMW switched to CHF 11S for all 2006 and later models.
