Old 11-12-2013, 12:32 PM
MikeinOH MikeinOH is offline
Mein Auto: 328i, 981S, RAV4
Aux power input question on 08 E90 w/o iDrive
I've read a number of threads on this on the forum but they mostly involve getting a bluetooth connection without iDrive.
What I'd like to know is whether the Aux Power input will allow Pandora or Iheart to be played over the base audio system via a direct cable setup? thanks for any help.
Old 11-12-2013, 02:16 PM
BimmerBoy1986 BimmerBoy1986 is offline
Mein Auto: 2007 335i Sedan
So long as the device is playing yes it will work. The wife plays her Pandora all the time.
Old 11-12-2013, 05:24 PM
Mein Auto: '06 AW 330xi
You can get a bluetooth adapter like the blackberry stereo gateway and connect that to your AUX port. You'll need a usb cigg lighter adapter and a usb cable to power the BB unit. And of course the 3.5mm AUX cable.
This will allow you to listen to music wirelessly. You control everything from the phone. The car's bluetooth works fine with the BB gateway, simultaneously.
