Old 11-12-2013, 09:30 PM
morrieschoice's Avatar
morrieschoice morrieschoice is offline
Mein Auto: 2001 3.0 Z-3 ROADSTER
Brake/Rotors Decision
Will probably be doing brake job on my Roadster (3.0) in January. I have started some research on brake packages front & rear. There are two kits I am considering...
(1) Powerstop K2872 Evolution (Z16) $392.00 found on Auto parts Warehouse. The Powerstop/Brake Disc and Pad Kit includes drilled & slotted rotors with ceramic pads. Sensors are included.
(2) Turner Motorsport has a Z3 3.0 Roadster & Coupe package (front & rear) OEM Rotor & Axxis/PBR metal master pads with ATE type 200 Amber brake fluid included $304.00
Does anyone have either of these kits on your 3.0 Z3 ?? I am open for suggestions/advice. I think both of these kits are designed for primarily street driving with quiet braking & little dust left on wheels. That's what I am looking for...no track driving. Thanks for your help/input.
Old 11-13-2013, 12:12 AM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
Take choice 2. Drilled rotors (for the most part) are a cosmetic only option. They do not provide any increase in performance for street use and actually have an increase incidence of cracking through the holes. There is a reason no major racing series runs cross drilled rotors. For performance, most series run slotted rotors. VERY expensive cross drilled rotors are a different story but not the ones you are talking about. I can't comment on the pads as I have not run them but based on the rotor situation, I would be go with option 2.
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
Old 11-13-2013, 07:33 AM
daven daven is offline
Mein Auto: 1999 BMW Z3 Coupe
Contact Vincent @ Bimmerzone (info @bimmerzone.com) He's a great vendor and may be able to beat Turner's price for the same products.
David
Blue Ridge Mntns, NC
1999 2.8l Z3 Coupe
Arctic Silver
Old 11-13-2013, 08:31 PM
Thanks for your input. I feel it will help with my decision making.
