Old 11-13-2013, 01:58 PM
ghs235 ghs235 is offline
Desi
Mein Auto: 07 550i SMG, 09 MB ML550
Does a REAR Hydraulic Sway Bar exist?
2007 550i SMG
The independent shop says my REAR hydraulic sway bar is leaking. But my service agent at the BMW dealership says that he never heard of a rear sway bar for my car.
Who's right??
Old 11-13-2013, 02:47 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
http://www.realoem.com/bmw/showparts...72&hg=33&fg=45
(for a 545i, I would assume similar applies to the 550i as well)
Old 11-13-2013, 04:45 PM
H F H F is offline
Mein Auto: 2005 545i
Just look under the car and see for your self.. If you have an ARS suspention it will look like the part schpenxel posted. Its a hydralic stabilizer bar thats a two piece with a hydraulic torsion mechanizum in the center and not catagorized as a sway bar. Since you have a 550, it most likley has ARS .
Old 11-13-2013, 07:59 PM
Desi
Thanks guys. The car is in the shop right now so I can't look at it and confirm. I'll check under the car tomorrow.
It sucks that it started leaking. A $2000 repair.
Old 11-13-2013, 08:08 PM
DIY'er
Are they just swapping the whole thing with a new one or what?
Old 11-13-2013, 09:37 PM
bimmerfan52 bimmerfan52 is offline
Mein Auto: 545i
The first question I would ask is how badly is it leaking? Are you seeing fluid on the floor in the garage? Have you experienced a low hydraulic fluid level?
The rear ARS sway bar basically works the same as the front sway bar, except that it does not have air lines to allow air into the valve to prevent cavitation noise (BMW figures at the rear of the car you won't hear it).
The ARS system shares CHF11S hydraulic fluid with the power steering rack.
Some of the leaks are so slow that there might only be slight staining on the valve body itself and could be as slow as a quarter of an ounce per year. You have to decide if you can live with a slow leak, but a quart of CHF11S is about $15 and would keep a very slow leak at bay for years (just keeping the hydraulic fluid reservoir topped up).
$tealers are experts at going over a vehicle carefully to search for what on German cars is termed "sweating" or extremely slow leaks which the German cars are famous (or rather infamous) for. Obviously these searches just happen to begin after the vehicle is out of warranty as BMWNA would never pay for these egg hunts that the owner has not specifically complained about.
Old 11-14-2013, 08:54 AM
Desi
That's what the independent shop suggested after a brief conversation. I didn't ask him a lot of details yet and I told him to hold off on it until I gather more information. So, as of now, the repair is on hold.
Thanks for the info. I'll ask the right questions to determine if I can live with it. I also found a few threads here where some ppl did DIY cheap and easy fixes that cost them under $50. Obviously, their leaks are because of a crack in the plastic pieces or something minor like that.
I'll report back once I get more information from the shop. As of now, I do not see any hydraulic related messages in my iDrive.
Old 11-14-2013, 03:31 PM
Mein Auto: 545i
Have you seen any fluid on your garage floor?
Old 11-14-2013, 05:04 PM
Desi
Nothing on the floor. No drops what so ever. I'm just coming back from the shop and he said that I am good to go for a few thousand miles before it gets worse. Right now, there's just a stain and it is not a drip.
So I decided to not change the part right now and wait until the problem gets worse. I'll keep an eye on the hydraulic fluid levels.
Old 11-15-2013, 04:43 AM
ODBmw ODBmw is offline
Mein Auto: 550i
My 07 550i (sport package) has a hydraulic rear sway bar. My front bar was leaking which I fixed by tightening up the metal fittings and putting a hose clamp on one of the hoses. It's still nice and clean 2 months later. Here's the thread that inspired me:
http://www.bimmerfest.com/forums/sho...d.php?t=597901
Old 11-15-2013, 07:04 AM
Mein Auto: 545i
Good to hear that there is a fix for a slow leak.
I researched having the hydraulic sway bar unit rebuilt but never found a place that advertised that they could do it. The natural choice would be a shop that rebuilds steering racks. I think the problem is availability of parts to rebuild them. ZF makes steering rack kits available to rebuilders (we have a good shop in Phoenix), in addition to offering their manufacturer's rebuilding service, but I have seen no reference to rebuild kits for the sway bar.
If anyone knows of a source of rebuild kits for ZF sway bars please update us.
rear sway bar
