Old 11-13-2013, 01:16 PM
topspeed1991 topspeed1991 is offline
Mein Auto: 535i
HELP BMW Factory Warranty
I own a bmw 535 with the n54 engine and I was at a stop. Started to press the gas because of a green light, the car moved one foot and then hear a loud sound under my foot. Also the car was no longer accelerating, like it reved, but no forward motion. SO I take it to the dealership had to tow it, turns out the drive shaft is broken also the differential and the heat sheald. They said there is a lot of burned rubber in the wheel wells, but my tires actually show very little tread wear. They are rejecting the warranty and also found the DCI in the trunk in a bag that was closed. I have never had a JB4. The was DCI was never installed, it was only in my trunk because I was waiting to put it on after the warranty runs out which is in about a month. I shouldn't be the one paying for this because its been years since I have done burnouts in this car and its still under warranty. They cant prove I physically broke the drive shaft and differential, right? Has anyone experienced this with warranty rejection? because I feel like they try to pull this trick every time I go into the dealership with a problem.
Old 11-13-2013, 01:52 PM
KLR4LIFE KLR4LIFE is offline
Mein Auto: 2008 550i Manual
Maybe the signs of abuse they saw in the drivetrain that made then not want to honor the warranty and the DCI didnt make things any better.
2008 BMW 550i Carbon Schwartz Metallic, 6 Speed Manual, Sport Package, Cold Weather Package, Logic 7, Comfort Access, Active Steering, Sat and HD Radio, Navigation, Comfort Seats and custom coding. Mods - 20 Watt AE, LED License plate lights and HID Fogs, StopTech drilled rotors.
Old 11-13-2013, 02:18 PM
luigi524td luigi524td is online now
Mein Auto: '17 540xDrive; '98 Z3 2.8
Exclamation Warranty question
So this is an on-going problem? Have you ever had BMWNA intervene? After all, not everyone drives a BMW like a little old lady
Is this not the car promoted to enthusiasts I've never had a serious drivetrain warranty claim so I can't comment about how warranty was handled. Mine have been somewhat more in the usual problem areas - battery, IBS, etc.
Hope you get it sorted out because it's not very comfortable knowing that a drive axle on a BMW might be overstressed and fail if all the horsepower and torque available from the engine can't make it to the pavement without catastrophic failure
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive|'13 X1 MSport|'98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link below for cash back savings at on-line stores like Tirerack!
Mr. Rebates
Old 11-13-2013, 02:25 PM
njlou njlou is online now
Mein Auto: corvette/528xi
I think that the key fob tells the sad story!!!
Old 11-13-2013, 05:07 PM
Cre8 Cre8 is offline
That's Rad!
Mein Auto: 05, E60/545i
If you asking if there is some system inside your car that can tell the dealer you did a 1000ft rolling burnout, the answer would be no. It's your word, they take it for what it's worth and it looks like BMW thinks your full of BS.
How much are the repairs?
Old 11-14-2013, 05:36 PM
Mein Auto: 535i
Estimated repair 5000!!!! Said they have to open up the rear differential and maybe we can cover it under factory warranty.....
Old 11-15-2013, 07:23 AM
Tomahawk674 Tomahawk674 is offline
Mein Auto: WTB 528i
I think you could buy a limited slip differential for less than that. That sounds outrageous.
Old 11-15-2013, 08:04 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
+1 on LSD.
but that $5k close to half is probably labor.
Nowadays, with so many parameters logged onto computer, I am not surprise BMW tech can pull any data that support their decision.
I only saw a couple waranty rejections, posted on e90 forums, this is the day when kids start going crazy modding N54, DP, cat removal, meth injector etc.
Old 11-15-2013, 08:15 AM
Be careful>>>>>
They are looking to pull the unit apart and then tell you it's not covered and it will be held ransom. It seems that you will will be paying something - the warranty coverage looks slim. If they will cover you, get it in writing before the wrenches come out. you could probably get a used unit installed much cheaper. These units are probably available.
