e90 OBD Port and Instrument Cluster suddenly stopped working - Bimmerfest - BMW Forums
Old 11-13-2013, 02:42 PM
wiziem wiziem is offline
Mein Auto: e90
Hello I have a 2006 e90 330i. one night i was driving to my friend's house. everything in the car was fine. I turned off the car and locked it. My friend told me that he bought an OBDII scanner and it works great on his car. so I decided to see if it works on my car too. I unlocked my car and plugged the scanner to the OBDII port. It didn't turn the scanner on. so i decided to put the car ignition in the ON position. and still didn't turn on. then i realized my instrument cluster not working. everything else works fine except the instrumental cluster like warning lights, speedometer, nor miles screen. and the OBDII port.
i also realized that the back lights for the inside buttons (the steering wheel buttons, the middle console buttons, and the window buttons lights) stay ON for a while after locking the car
I checked all the fuses in the back of the glove box. everything seemed to be ok.
I also, tried using another scanner and it didn't work either.
anyone has any ideas what would be the problem.
Thank you,
Old 11-13-2013, 03:29 PM
Mein Auto: '06 AW 330xi
Sounds like a faulty FRM to me.
Old 11-13-2013, 06:15 PM
Mein Auto: e90
But isn't the FRM (footwell module) mostly control the exterior lights (headlights, etc. )
Old 11-13-2013, 06:23 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Which scanner was it?
First things first. Fuses.
Old 11-13-2013, 06:53 PM
It also controls instrument dimming and switch lighting as well as window operation.
Old 11-13-2013, 07:16 PM
Mein Auto: e90
the scanner brand name is CEN-TECH
i checked the fuses behind the glovebox. they are fine.
Old 11-13-2013, 07:18 PM
Mein Auto: e90
but my main problem is that OBD port is not working, the cluster not working, neither the service menu in the middle screen.
Old 11-14-2013, 09:03 AM
Harbor Freight? God help you!
Time to get pinouts for BMW OBDII - check voltage. Generic OBDII pinout follows - do you notice the 'Vendor Option' pins? Might have a bearing....
Follow issue upstream. If not equipped, I see an Indy in your future. Oh, and use only THIS or THAT
Old 11-14-2013, 09:15 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Fuse 74 has the OBD and cluster in common
This usually blows when people are changing the battery
with a battery backup installed.
When you say checked them does that mean you measured
them with a meter?
Old 11-14-2013, 01:20 PM
You don't measure anything with fuses. It's a visual inspection.
Old 11-14-2013, 01:31 PM
Banned
Mein Auto: 2007-335 HTC
well you best do a continuity check because I had a fuse blow and you couldnt tell except by using a multimeter
Old 11-14-2013, 04:09 PM
BMWCCA 149159
Mein Auto: 17Ridge/14JGC/ 17Outback
Fuse F2 5A fuse behind glove box is for both of those problems by the way...
Old 11-14-2013, 05:32 PM
Mein Auto: e90
Old 11-14-2013, 05:36 PM
Mein Auto: e90
above is my fuse box legend. it goes up to 70. i checked each one manually by pulling it out looking at it then put it back. i also did it with the tester to double check. some of them didnt light up with the light tester, so the same thing i pulled it out manually and double checked it. that is fine.
I'm starting to think its maybe the relays. but how would you check the relays!!
Old 11-14-2013, 06:00 PM
2 pairs of hands or a set of alligator clips for the multimeter. You want to measure between ground and the pin that receives 12v when the relay's trigger has power, pin 87.
Old 11-14-2013, 06:38 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
I do believe fuse 58 is your instrument panel based on that sheet. If you don't have a multimeter to test it, swap it with one of a similar amperage rating and see if the problem follows the fuse.
Old 11-21-2013, 01:35 PM
Mein Auto: e90
the problem was fuse 58. thank you guys so much for the help.
Old 11-21-2013, 04:02 PM
I have seen several of those fuse maps
and apparently there are some variations but the pictograghs seem consistent.
Old 02-25-2016, 10:34 AM
RhonnyZA RhonnyZA is offline
Mein Auto: e90 facelift
e90 OBD port.
Hi can annyone tell me if this can also be the footwell module? Im from Cape Town, south africa A week ago i had jumper cables to jumpstart my car, after that my instrument cluster stopped working, my front windows doesnt work, i can only control my side mirrors from my driveers door panel, lights switch on when car swith on, central locking dont work, remote dont work? Please help?
Old 09-24-2016, 08:46 PM
kwbmw2006 kwbmw2006 is offline
Mein Auto: 325i 2006
My dashboard lights are dead - I have the same circuitry and fuse diagram as posted by WIZIEM on 11-14-2013. The serial No I presume is : 8 384 529.1 EEF75.U - I have BMW 325i 2006 model.
What fuse number connect the instrument panel? Fuse no 58 is glowing fine when tested with testing light. But the dashboard lights are dead . Please help me !
Old 09-27-2016, 12:58 PM
Zooks527's Avatar
"Glowing fine"? Are you saying if you put a test light to ground on both sides of the fuse the light glows?
Old 09-27-2016, 01:54 PM
Zooks527
Yeah I meant exactly what you just told ! But is it all fixed now I figured it out . BMW 325i 2006 fuse box diagram is lot different to what we actually have( I mean the fuse numbers). BMW is really crappy not giving the correct fuse diagram !
Old 09-27-2016, 02:04 PM
Variations in fuse maps
Yeah, I agree, the ones given by BMW does not necessarily match with the actual circuit - this is BMW 's crappy service- Fuse nos are sometimes not the same .
Old 05-17-2017, 07:29 PM
Sridgway Sridgway is offline
Mein Auto: Bmw 325iu
Help!
What fuse did you end up changing? I am having the same problem on the same car! Thanks for your insight!
Old 09-26-2017, 05:05 AM
Divish Divish is offline
Mein Auto: BMW e90 320i
Hello Guys,
I am new to this forum and I am having absolutely similar issues. OBD and instrument cluster stopped working.
I disconnected my e90 battery last night.
Fuse 58 seems to be fine. I have even tried to swap it with similar amperage ratting, but issue persists.
Can you please help and advise way forward?
Regards,
Divish
