Old 11-13-2013, 03:14 PM
xris xris is offline
Mein Auto: 2011 bmw 328 coupe xdrive
winter tires
Hi guys,
I have a 2011 bmw 328 xdrive coupe sport package I was wondrring if its ok to install winter tires and rims with a 205/50/R17? Bmw reccomends 225/45/R17.
Thank you
Old 11-13-2013, 04:38 PM
floydarogers's Avatar
Pedant and Curmudgeon
Originally Posted by xris View Post
Hi guys,
Should be fine; both sizes are the same overall diameter.
Old 11-13-2013, 08:18 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Hi guys,
I tried something similar when I purchased my first set of winter tires from TireRack. They called after I placed the order online and suggested I change to the 225/45/17 tires. IIRC, it had something to do with the load range, weight of the car, and required pressure in the tires I selected.
Sorry to not be more specific, but it was 4 years ago, and the synapses aren't as young as they used to be.
Old 11-13-2013, 08:59 PM
Yeah I have them on my car now they seem fine. But for some rreason I cant get a a straight answer if the car would be ok? :s
Anybody that has more info this please help
Old 11-14-2013, 12:11 PM
cwsqbm's Avatar
cwsqbm cwsqbm is offline
I do'nt make mistakes.
Mein Auto: Quadricycle
Looking at tirerack, with 17" wheels, the 225-45-17 is recommended but the 205-50-17 is an alternative for the E90. Its fine. The only reason for them to recommend the 225/45-17 is that its a factory size and probably a little better on dry pavement.
.................................................. ................................Garrison-Jenner 2016 .................................................. ..........................................
