Old 11-13-2013, 06:58 PM
mortal300 mortal300 is offline
Mein Auto: 2008 BMW 535i (E60)
Headlight condensation after BMW Dealership Service
Hello,
Today has been a terrible day with my 2008 BMW 535i. I picked it up form Sterling BMW only to find a few issues. I took it in for the bearing lifters because the check engine light came on for that. They returned the car to me with headlight condensation and the service engineer forgot to add oil even as the iDrive was bitching about low oil level. Clearly this "service" was not "service".
As far as the headlight problem, I noticed the BACK COVER was broken and slightly open. Not the cover for the angel eyes, the big plastic cover for the headlight. I changed my angel eyes this weekend to the DTEC V7's and everything went fine. I didn't notice the back cover broken. IT must have been from the previous owner. Here is a picture of my condensation, it's pretty damn bad. I've washed the car many times and this has never happened. The seals look ok.
Does anything think this is purely a problem of the back cover not being sealed? Thanks.
Old 11-13-2013, 07:41 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
What are "bearing lifters"
Old 11-13-2013, 07:42 PM
I believe it is part of the Vanos Solenoid. There was a problem with that.
Old 11-13-2013, 07:43 PM
DIY'er
Yeah I don't think that's what it is called.
Old 11-13-2013, 07:46 PM
DIY'er
Also, posting pictures of the back cover you are referring to as broken would be useful information
Old 11-13-2013, 07:53 PM
The left opening is the angel eye cover, the arrow indicates the cover that is open for me. It is about 4cm open. There definitely is some air/humidity passing through that opening...
I'll get you a better picture if needed?
Old 11-14-2013, 07:21 AM
Mein Auto: '06 AW 330xi
Yes the condensation is from the back cover not being sealed.
Old 11-14-2013, 10:58 PM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
I would remove the broken cover, blow a hair dryer on the headlight for a little while to heat it up and evaporate all the condensation, then replace the cover with a new one.
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
Old 11-15-2013, 05:35 AM
DIY'er
Wonder if you could put one of those silica packs in there for a little bit to soak it up
