Removal of iPhone cradle - Bimmerfest - BMW Forums
Old 11-14-2013, 11:44 AM
shortstop shortstop is offline
Mein Auto: 2014 X1 xline
http://www.motor-talk.de/forum/ausba...-t3775402.html
Please be advised i just found this link and have not tried it yet myself. That cradle is both worthless and in the way. Hope this helps.
shortstop
2014 X1 xline
Old 11-14-2013, 01:49 PM
rotherd31 rotherd31 is offline
Mein Auto: M4/YMB/DCT
I was just thinking the same exact thing this afternoon! Trouble is the link is a German site and I can't read german. Any hints?
Old 11-14-2013, 02:24 PM
Here's a link and pics in English. Keep in mind it's the removal for an X3, but my guess is that the removal process will still work. Not sure at this point if the part # for the X1 cubby is the same or not.
http://x3.xbimmers.com/forums/showth...ghlight=cradle
Old 11-23-2013, 07:28 AM
zznalg zznalg is offline
Mein Auto: 2014 X1 35
What is this cradle for?? I have an iPhone and supposedly it's meant to fit. But even the electronic connections seem to make no sense. Am I missing something?
Old 11-23-2013, 08:11 AM
I believe it is just to HOLD the iPhones but you still need an expensive adapter (@$200?)to hook it into the system. I could be wrong but i think that all this allows you to do over the wireless transmission of data is charge the phone. Even the dealers admitted it was a mistake by BMW to add the cradle. I could not get the cradle out of MY14 X1 as per the video above, so i ended up cutting it out with a dremel and razor knife. I left the cables and circuit board intact. Now i can put more stuff in that cubby. I don't know if i can sever those cables or not.
shortstop
2014 X1 xline
Old 11-23-2013, 08:54 AM
Gort Gort is offline
Mein Auto: 2017 X3-35i xDrive
The cradle is meant to hold an adapter specific to your cell phone. See below. It is like $250. It connects you to the car directly, charges the phone, and uses the sharkfin external antenna. To me it isn't necessary.
http://www.shopbmwusa.com/PRODUCT/43...cessories.aspx
Old 11-23-2013, 11:54 AM
I wonder if anybody has this adaptor and likes it -and would recommend it?
Old 11-23-2013, 04:14 PM
Robocheme Robocheme is offline
Mein Auto: 2001 Acura MDX
I have the adapter for my 4S and my X3. The pluses are:
Improved phone reception via the car's attenna
Better iTunes interface
Frees up your USB port
The negatives are
$250
Requires removal of your iPhone cover (no matter how thin it is)
All other functions are available via white USB cord
I think it is waste of money and I won't get one for my 5S.
Old 11-23-2013, 04:16 PM
Does anyone know the part no. for the replacement cubby for the X1?
Old 11-23-2013, 08:30 PM
I was comparing my X3 to my X1 and they're quite different. I wouldn't attempt it on my X1 until someone post how-to-do-it instructions like the link above.
Old 11-24-2013, 01:46 PM
The negatives are
$250
Curious as to what is "better" about the iTunes interface? How is it different?
Old 11-24-2013, 05:15 PM
cradle cables
Is it possible to safely remove the cables and circuit board from the cradle/cubby area?
shortstop
2014 X1 xline
Old 12-17-2013, 05:10 AM
ht2 ht2 is offline
Mein Auto: x1
4 cables are going in to "Telephone cradle, lower section" (see 6 of link below)
http://www.realoem.com/bmw/showparts...38&hg=51&fg=35
If we can remove "Telephone cradle, lower section", I think we can safely remove the cables and circuit board like X3 procedure.
Removing the Cell Phone Cradle from the Center Console X3 version.
http://x3.xbimmers.com/forums/showthread.php?t=836827
Old 12-19-2013, 04:23 PM
Hen49 Hen49 is offline
Mein Auto: X1 sDrive28i
How safely remove phone cradle.
1. Move forward front seats to max. Easy 10min job. I use 2 flathead screwdriver mid & small.
2. Start right bottom of back panel center console (with cigarette lighter).
3. Release snap clips (vertical grove) there are 3 clips on both side.
4. Slide forward the center armrest.
5. Pull back panel center console upward.
6. From right side push axle-pin.
7. From left side pull pin like 4 inch don't remove it.
8. Open cubby and remove phone cradle.
9. Reverse process.
Done.
One more cover hole inside cubby use thin cardboard or plastic + super glue.
Maybe some made few pics and better description how remove back panel of center console.
Old 12-19-2013, 05:59 PM
cables removed!
Thanks to HEN49!!!
i had removed the cradle previously but following your instructions i was able to disconnect and remove all the cables and the circuit board that was left behind after removing the cradle. Now i've got plenty of room in the cubby.
Thanks again
shortstop
2014 X1 xline
Old 12-20-2013, 02:14 PM
Smile
9. Reverse process.
Done.
I know you've already completed the project, but some photos would be great if you have the time to make a few.
Old 01-14-2014, 12:47 PM
MTSe84 MTSe84 is offline
Mein Auto:
Was intrigued by this post until the just finish it off with a little cardboard and super glue on a brand new BMW step.
Old 01-24-2014, 02:35 PM
kepostil kepostil is offline
Mein Auto: 2013 X1 28I
OMG! This phone cradle is the stupidest thing ever. I don't need it, don't have an Iphone and I use my phone via Bluetooth! Why could they just have it clip into the top of the console so it moves out of the way when you open it! That is my biggest pet peeve! I asked my dealer about removing it, and they said they would have to remove the whole console to do it! I think they just didn't want to hassle it. My vehicle is leased or I would do it myself.
Old 01-27-2014, 11:32 AM
MRCW MRCW is offline
Mein Auto: Cars and trucks and boats
I followed Hen49's instructions and it took about 15 minutes to remove and disconnect the wires. No need to disassemble the cradel, etc. just disconnect the harnesses and pass thru the hole.
When you remove the the back panel of the console, you pull out and up at the same time.
Great quick mod... Will likely plug the hole with a piece of thin plastic sheet or vinyl
Thanks to Hen49 for easy directions
2013 X1 3.5i MSport
2006 530xi Touring (gone)
2002 X5 4.6is (gone)
1995 525xit (gone)
Old 01-27-2014, 09:24 PM
9. Reverse process.
Done.
A few questions -
Why do you need screwdrivers to move the seat forward? Is it to get the power seats pass where they naturally stop?
What does "Start right bottom of back panel center console (with cigarette lighter)." mean?
Thanks,
Old 02-28-2014, 09:38 PM
alanintx alanintx is offline
Mein Auto: 2011 F25
Popped off the back console cover very easily.
Then figured out how to disconnect the 2 "antenna" type wires and the big BMW plastic connector with the two other wires.
Now, about that axle pin. Push from the right and pull from the left?
A simple push does not look like it will do the job. May have to whack it with a small nail to get it moving. Does that sound correct?
Old 03-01-2014, 08:23 AM
I pushed it out from right to left ( from sitting in the back seat...)
I used an ice pick and gave the handle a little whack... Pushed out rather easily...
BTW, i found that you can order a cover piece for the hole left in the inside of the console.
it appears to be part number 51162991863
http://www.turnermotorsport.com/p-18...-bmw-part.aspx
I haven't gotten around to ordering it yet though
2013 X1 3.5i MSport
1995 525xit (gone)
Old 03-01-2014, 10:10 AM
mscottc mscottc is offline
Mein Auto: BMW 330i
I could not for the life of me figure out how to disconnect 3 of the 4 wires... any chance you can take a picture or somehow describe how you pulled the plugs apart? I wound up taking the innards apart and pulled the electronics out of the cradle. I then put the electronics back into the back of the console, but they're really stuffed in there very sloppily. Thank you.
Old 03-01-2014, 12:18 PM
Mein Auto: 2011 F25
There were 2 antenna type wires in a white plastic holder.
The bottom one seemed difficult, then I realized it just took a push on a pink part that acted as a lever and released the other side.
The top one has two blue tabs that need to be pushed in to release the other part
The 2 on bottom are connected to a BMW standard connector that has a plastic harness that needs to be slid down over the top.
The Pin... Well, I got it out, but realized it would have been easier if I pushed from the side with the tapered end (by passenger seat) . The other end has some ridges around it (that lock it in place) but I was able to knock it through and replace it.
The piece that covers the hole? Next time that you get an x1 loaner, while your car is in for service.......
Old 03-01-2014, 12:19 PM
Mein Auto: 2011 F25
Should have read this a bit more carefully. I went from left to right. It worked but it would have been easier the other way.
