Old 11-15-2013, 05:38 AM
Legendvo Legendvo is offline
Mein Auto: 2000 Z3 2.8
Major safety warning on z3 2.8
Z3 owners! I just discovered how bad frame quality of Z3 Roadster! The spot where Differencial is mounted is all thourn off! The welds that are holding crassmember that holds differencial mounts are really bad. I could see them coming off when lifted corpet in the trunk. My car never been in the accident, This is what Torqu and Big Tires Do!
ID:	407617   Click image for larger version
Old 11-15-2013, 07:29 AM
wrench13's Avatar
wrench13 wrench13 is offline
Mein Auto: Y2K 2.3 blk; 01 3.0 Cp
That is the #2 most known defect in BMW Z3 history, well documented in the stickys in this and other BMW Z3 forums. Suggest you spend a few hours reading. Once done, Seek out Randy Forbes , the recognized expert on this failure. He has a repair kit you gonna need to have installed. For everyone else: Proof that the problem does not only occur on the M Z3's. This one is a 2.8L.
Y2K Roadstar, w/60K ( motorcycle)
Y2K Z3, 2.3, w/66K, now 92K in 2-1/2 years
2001 Z3 Coupe, 3.0 w/55K - new for me - WHooHoo
Astro 1990 w/290K
Suck, Bang, Blow, that's what it's all about.
Old 11-15-2013, 08:10 AM
don't wanna spend too much time reading and researching, just wanted to get the word out. I was surprised to see how bad that frame is I already fixed it by straightening it all and welding it back on, applyed many new and additional welds to the frame. And reenforced it with more steel. I know for sure it will hold all this load... And yes, this is only Stock 2.8 5sp auto, with 17/45/265 in the back... will be going to 225s
Old 11-15-2013, 12:16 PM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by Legendvo View Post
don't wanna spend too much time reading and researching, just wanted to get the word out... I already fixed it by straightening it all and welding it back on, applyed many new and additional welds to the frame. And reenforced it with more steel. I know for sure it will hold all this load...
The word has been out for more than a decade. The best fix is the kit by Randy Forbes, illustrated here:
http://www.bimmerfest.com/forums/sho...72&postcount=2
The installation is shown here:
http://www.spcarsplus.com/gallery3/index.php/SCC
Old 11-15-2013, 01:22 PM
wrench13's Avatar
Vintage, that's too much reading for the OP !
Astro 1990 w/290K
Old 11-16-2013, 12:34 PM
badvlvo badvlvo is offline
Volvo guy
Mein Auto: 00 z3 2.5, 04 e46 2.5
Some people don't want to do any work themselves, relying on the internet to do all the work for them. I'm sure he fixed it as well as any of the available kits
2000 Z3 2.5 manual
2004 325i auto sport package
1980 Volvo 244 (the race car)
Old 11-16-2013, 06:14 PM
Z3Papa Z3Papa is offline
Mein Auto: 2002 Z3 3.0
He must have climbed out from under a rock.
2011 BMW M3 ZCP in Melbourne Red, Apex wheels (ARC-8 and EC-7's) with Bridgestone RE-71R's.
Old 11-16-2013, 08:40 PM
AB1945 AB1945 is offline
Mein Auto: '01 Z3 & '02 325i Wagon
Legendvo - this is old news but I'm sure you didn't know that. Can you post pics of your repairs please. That'd be a contribution to the board. Thanks.
Old 11-16-2013, 11:49 PM
Sorry, i didn't take any pictures. But All i did is bent everything to it's original, and instead of factory spot weld, i stitch welded everything back on, and added 1/8 thick flat steel in the trunk for extra strength. And i changed rear tires from 265 to 225s, to reduce load, I'd rather spin them ...this is second Z3 that i bought. Not planning to keep it... just to flip it... 1999 Z3 2.8 had damage to front and rear, But didn't have this problem with frame.. tires where 225s all around..
ID:	407853   Click image for larger version
ID:	407854   Click image for larger version
ID:	407855   Click image for larger version
Old 11-16-2013, 11:53 PM
Thank you for the Links, i did a little simpler work, but it will work well for this car, since factory spot welds were able to hold it together for 126k miles... all my reinforcement will be better
Old 11-17-2013, 04:59 AM
vintage42's Avatar
BMW CCA 1405
.... 1999 Z3 2.8 had damage to front and rear...
What is the intake on the driver side of the hood for? I have never seen that before.
Old 11-17-2013, 06:15 AM
Dheilman Dheilman is offline
Dave
Mein Auto: 1998 Z3 Roadster 2.8 5spd
Also in the opening between the license and the fog light?
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=299148&dateline=1349724030
Old 11-17-2013, 08:09 AM
Kornknarr Kornknarr is offline
Mein Auto: -98 Mroadster S50 Estoril
A cold air intake? What happens when you get a bird in there?
Old 11-17-2013, 11:20 AM
HAHA Haven't had that problem Thats 3" tubing going up to Cold Air Intake... Engine air Intake Temp went down by 13 degrees..
Old 11-20-2013, 02:03 PM
vintage42's Avatar
BMW CCA 1405
... Thats 3" tubing going up to Cold Air Intake...
So the thing on top of the hood is not an intake. What is it?
Old 11-20-2013, 03:45 PM
redhotz redhotz is offline
Mein Auto: 98 z-3 2.8l
Looks like a train horn
[/SIGPIC]
Old 12-04-2013, 08:25 PM
tohbi tohbi is offline
Mein Auto: z3 '97 atlanta blue 2.8
sports cars should have frames, not unibody........ you put 225s on the rear?
Old 12-05-2013, 04:11 PM
Yes, i have 225s in the back, i don't mind TCS flashing at me on every turn
