Old 11-15-2013, 02:25 PM
ObsoletePower ObsoletePower is offline
Mein Auto: '11 BMW E90 328xi
Rims for 2011 328i E90 Xdrive - What should I look for?
Hello everybody,
I am new to the community as I am new to BMW altogether.
I have been searching the forums for suggestions on what rims to get for my car to outfit it with winter tires. The current tires are 225/45/R17 91H Continental run flats and I would like to get a set of rims (off Kijiji or eBay). I am still unclear about what rims would be compatible with my car. I read about offset and I am trying to make an informed purchase as most sellers do not specify this in the descriptions or over the phone. Also, I am still unclear if there is a difference between Xdrive and RWD models. Mine is a 4-door non-sport version with Xdrive. Any help would be greatly appreciated.
Old 11-15-2013, 06:41 PM
stones399 stones399 is offline
Mein Auto: '11 335xi Sport Pkg
As you've already found out, there's a plethora of rims out there for BMW's. Sometimes you can narrow the search down to your specific model. Also, look at the classified section here.
I went through this w/ my '11 335xi a couple months ago. This is what I found out:
- There is a difference btwn RWD and AWD but not exactly sure what since we're only talking about AWD
- Your stock 17" size is good for the snow (thinner is better in snow; no riding on top of snow layer). But if you do want a change, I found this calculator useful.
- I found out that my 18" staggered rims had a 30mm offset up front (8" rim width) and 34mm offset in rear (8.5" rim width). But it looks like you may be at 34mm.
So if you go w/ 17" rims w/ a 34mm offset you should be ok, but definitely comfirm w/ another source. Another way to verify your rims spec's is to take one off and look on the inside for markings similar to pic's attached (though the nomeclature may not be exactly the same). In this case, 7.5Jx17H2 ET45 means this rims is 7.5" wide x 17" tall w/ an offset of 45mm. A thing to remember; usually the smaller the offset, the more the wheel will protrude towards the outside of the car. See here for offset explanation.
Once you've got that, get a set of Nokian Hakkepalitta R2 tires and rip it up!
Oh ya! Check this rim link from E90, it may help.
Lastly, if the seller can't give the spec's; go to another place as they may not know their a$$ from a hole in the ground! Would you want them to work on your new car?
2011 335xi Sport Package, Sapphire Black, Black Dakota Leather
18" Beyern Staggered, Glossy Black Grill, K&N filter, Active Autowerke Signature Exhaust
Old 11-15-2013, 06:53 PM
Hey thanks very much for the info, it's very thorough and will definitely ramp up my search for rims now that I am more familiar.
I would like to stick to the style of rim that came stock with my car. With that being said, I have yet to come across a set on Kijiji but I will definitely look through the classified section on here.
Thanks again!
Btw, your car looks bad-ass!!
Old 11-16-2013, 05:21 AM
Mein Auto: '06 AW 330xi
Just make sure you get a square setup.
There are 2 reasons.
1) if the rolling diameters of the front vs rear tires are not within 1% of each other, there is the potential to lock up the transfer case. You can run a staggered setup but you'll need to stretch tires which reduces sidewall and sacrifices ride quality and rim protection.
2) BMW are setup to understeer from the factory. Xdrive models suffers much more from this. Running a staggered setup increases understeer. Personally this is something I don't want. Some don't care, others have no idea what understeer is and just ignore it.
Old 11-16-2013, 05:31 AM
I am not going to get a staggered setup but rather stick with 225/45/17 on all 4 wheels. Yeah I do agree with you about Xdrive and understeer, I certainly do feel it (having previously owned a RWD car). Thanks for your suggestions!
Old 11-16-2013, 05:48 AM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
Originally Posted by ObsoletePower View Post
Hello everybody,
On ebay it is easy to get BMW replica for cheap. You can even search with keywords BMW wheels 17"
Old 11-16-2013, 12:09 PM
Belvedere2 Belvedere2 is offline
Mein Auto: 328i Coupe
Personally I'd just get a complete set from Tirerack. That's what I did this year. Ordered Mon came on Tues.
Old 11-20-2014, 08:12 AM
Reychurch Reychurch is offline
Mein Auto: BMW X3
You have a detailed good info to follow here. How about the TPMS sensor. Is there an internal sensor to be installed on this 2011-328xi on the tires? Good to see you having a handicap driving this bad-a$$ car. You are after all parked on a handicapped space. Cheers
Old 11-20-2014, 10:50 AM
asus389 asus389 is offline
Mein Auto: 2011 328i
Been pretty happy with my set of Rial Salerno wheels from TireRack. I got the 16" ones for winter, but they make them in 17" if you want. They are 5 spoke and take the BMW center caps. They are also light, which is good because it offsets the reduced fuel economy from running snow tires and low temps. As far as BMW wheels, any BMW wheel that originally came with the e90 will work.
Old 11-20-2014, 11:57 AM
Wongway Wongway is offline
Mein Auto: 2011 E90
TireRack.com was my best bet. You follow along their configurator for winter wheels and you're fine.
I went with a 16" wheel package and they have a list of compatible wheels that fit. If you so choose, you can have the TPMS monitors you buy and the tires mounted/balanced etc. and they'll ship it to a tirerack approved installer. I literally drove in, waited 20 mins, paid my install charge ($20?) and left.
Old 11-25-2014, 11:42 AM
Re: TPMS: yes & no. Yes there's a TPMS your car already has from dealer/factory. No, because my last understanding is there are no laws that require you to have a functioning TPMS (just big gov't agenda & car company CYA). So if you don't mind driving around w/ the TPMS light on, then save the $200 and don't get them. Though I wouldn't recommend switching the sensors as you'd have to replace the o-rings every time and risk the possibility of breaking one.
Ya, ever since I was injured over 21 yrs ago, my family wanted me in a van! Ain't happen! And I'm still bring home the hardware from occasional time trial track days.
Old 11-25-2014, 05:43 PM
gulshan gulshan is offline
Mein Auto: e92-n54
OP, will you be driving in heavy snow where you need dedicated winter tires or will a good all season that can handle medium snow do the job ? have you read the reviews for the Michelin A/S 3 ? They are based on the Pilot sport. If you go A/S 3 no need to swap rims and as added bonus you get to ditch your run flats.. I am very happy with A/s 3 and iam from chicago..
2011, 328i, e90, rims, sedan, tires, xdrive
