Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 11-18-2013, 07:24 AM
davidriscoll davidriscoll is offline
Mein Auto: 1987 528E
Key and Steering Wheel Jammed
Hi, Help me get moving again. My key cylinder is jammed or the steering wheel is? I heard that I could drill a hole to release a spring to get it working again. It was on a 90's BMW though I have an 87 528 E. Will that still work?
Old 11-18-2013, 10:50 AM
catso's Avatar
catso catso is offline
catso
I don't know, but if you look at an exploded view on www.RealOEM.com you may get an idea of where to drill. The "turning" ignition switch is a well known problem with these cars. You may want to do a search at the www.Mye28.com forum fo more info.
![/I][/FONT]
Old 11-18-2013, 09:05 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
If the steering wheel is locked you might try moving it clockwise and counter-clockwise as you turn the key in the ignition switch towards the "on" position.
HTML code is Off
